tman 47 Posted May 2, 2015 Posted May 2, 2015 Having upgraded both of my Emby for WMC installations to beta 265, I've observed an odd problem. Essentially, it appears that the 'Play' option has stopped working. By this, I mean that if I select 'Play' in movie details, nothing happens (or I eventually get a warning that the program is not responding). If I select 'Quick Play', MPC-HC launches ok and the movie plays. Both my installations use; Subdued theme MPC-HC as external player I'm using the latest Emby Server (5597.1) I use cinema mode, which has worked fine before Very odd, and it's only started since the last update. Any ideas?
ebr 16334 Posted May 2, 2015 Posted May 2, 2015 Please provide a log from when the problem occurs. How to Report a Problem
tman 47 Posted May 2, 2015 Author Posted May 2, 2015 Ok, this is the tail of the log file from Emby classic after I click 'Play' on a movie; 2015-05-03 00:03:55.8826,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/8d2d0b3e3f623aeee5e2deb1beee16e9/Intros?format=Json,1,Application2015-05-03 00:03:57.3957,Info,,Playing 3 Intros before The Secret Life of Walter Mitty,1,Application2015-05-03 00:03:57.4567,Info,,Internal Player about to play (http://wdmp.rd.llnwd.net/wdsmp/BigHero6/TeaserTrailer1/BigHero6_Trailer1R_720.mov) ,1,Application 2015-05-03 00:03:57.4707,Info,,Internal Player playing ,1,Application2015-05-03 00:03:57.4787,Debug,,Calling MediaCenterEnvironment.PlayMedia: Microsoft.MediaCenter.MediaCollection,1,Application2015-05-03 00:03:57.5777,Debug,,Error playing item: PlayMedia returned false,1,Application2015-05-03 00:03:58.2777,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Items/8d2d0b3e3f623aeee5e2deb1beee16e9/Images/Backdrop/2?maxWidth=1280&Quality=90&tag=c7070720834fc0e168789835230f5a09,22,Net Image loader-Worker 2015-05-03 00:03:58.2777,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Items/8d2d0b3e3f623aeee5e2deb1beee16e9/Images/Backdrop/1?maxWidth=1280&Quality=90&tag=c5134105130c5df82104ccd0cb457ea7,21,Net Image loader-Worker 2015-05-03 00:04:24.1732,Debug,,Keep alive call,, IsCurretntlyVisible=True,1,Application2015-05-03 00:04:35.0618,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Items/Counts/?userId=3ab3d063-61f5-ce61-86f5-68a7ecd9b343&format=Json,1,Application2015-05-03 00:04:35.7769,Debug,,Nav To Last. Index: 6 Subtile: 2,1,Application
ebr 16334 Posted May 2, 2015 Posted May 2, 2015 Much better to attach the entire log file as described in the post I linked but it looks like that trailer is gumming up the works. I imagine it will work fine if you disable cinema mode. Why the trailer won't play or it doesn't just move on I'm not sure but I'd be sure that your codecs are correct to be able to stream that trailer.
tman 47 Posted May 3, 2015 Author Posted May 3, 2015 Yeah, sorry about that. I'll get the whole log to you. So, just to confirm. Two installations, both using Emby Classic, same server. This has been working perfect for months. If I enter the URL of the trailer directly into a browser, it plays fine. Both installs now hang with cinema mode enabled. If I disable cinema mode, then use 'Play', everything works ok. Codecs are fine, everything checks out. No changes on either PC that have been working ok for a long, long time. 2015-05-03 10:32:26.0631,Debug,,Attempting to wake server at address 90-2B-34-9D-64-3E,1,Application2015-05-03 10:32:26.0691,Debug,,Wake command sent,1,Application2015-05-03 10:32:26.0821,Debug,,=========System looking for assembly: System.Data.SQLite,, Version=1.0.61.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1,Application2015-05-03 10:32:26.0851,Info,,System.Data.SQLite,, Version=1.0.61.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139 is being resolved to System.Data.SQLite,, Version=1.0.88.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1,Application2015-05-03 10:32:26.0911,Info,,==========Using new SQL Repo========,1,Application2015-05-03 10:32:26.3761,Info,,Playstate initialization took 0.01 seconds.,1,Application2015-05-03 10:32:26.4131,Info,,Successfully loaded fastload data for : C:\ProgramData\MediaBrowser-Classic\Cache\playstate MediaBrowser.Library.Entities.PlaybackStatus,13,Worker thread for FastLoadLoader2015-05-03 10:32:26.4421,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\strings-en.xml,1,Application2015-05-03 10:32:26.4531,Info,,Total Kernel Init took 0.40 seconds.,1,Application2015-05-03 10:32:26.4991,Info,,Finished validating : C:\ProgramData\MediaBrowser-Classic\Cache\playstate MediaBrowser.Library.Entities.PlaybackStatus,13,Worker thread for FastLoadLoader2015-05-03 10:32:26.4991,Info,,Dictionary loading and validation took 0.12 seconds.,13,Worker thread for FastLoadLoader2015-05-03 10:32:26.5371,Info,,Information DisplayText: Welcome to Media Browser,1,Application2015-05-03 10:32:26.5561,Info,,Media Browser (version 3.0.265.0 ) Starting up.,1,Application2015-05-03 10:32:26.5561,Info,,Startup parameters: ,1,Application2015-05-03 10:32:26.5691,Debug,,Having to get media experience by reflection due to bug in Windows 7,1,Application2015-05-03 10:32:26.5701,Debug,,GetMediaExperienceUsingReflection was unsuccessful,1,Application2015-05-03 10:32:26.6941,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/System/Info/Public?format=Json,1,Application2015-05-03 10:32:40.3859,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/Public?isDisabled=False&format=Json,1,Application2015-05-03 10:32:40.4899,Info,,Connected to server mbserver at http://192.168.0.10:8096,1,Application2015-05-03 10:32:40.4899,Info,,Server version: 3.0.5597.1,1,Application2015-05-03 10:32:40.5579,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/SplashPage,1,Application2015-05-03 10:32:40.6029,Info,,Application Init took 14.15 seconds.,1,Application2015-05-03 10:32:40.6089,Info,,Information DisplayText: Welcome to Media Browser,1,Application2015-05-03 10:32:40.6539,Debug,,Sending Http Post to http://192.168.0.10:8096/mediabrowser/Users/3ab3d06361f5ce6186f568a7ecd9b343/Authenticate?format=Json,24,Worker thread for Common 2015-05-03 10:32:40.7059,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/System/Configuration?format=Json,24,Worker thread for Common 2015-05-03 10:32:40.7719,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/System/Info?format=Json,24,Worker thread for Common 2015-05-03 10:32:40.8489,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Plugins?format=Json,24,Worker thread for Common 2015-05-03 10:32:40.8599,Info,,*** Theme in use is: Subdued,24,Worker thread for Common2015-05-03 10:32:40.8629,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Packages?packagetype=UserInstalled&targetsystems=MBClassic&format=Json,26,Worker thread for Common 2015-05-03 10:32:40.8699,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.137.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application2015-05-03 10:32:40.8699,Info,,Plug-in reference to MediaBrowser,, Version=3.0.137.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.265.0,1,Application2015-05-03 10:32:40.8729,Debug,,Added Plugin assembly: BDScreenSaver,, Version=2.0.0.4,, Culture=neutral,, PublicKeyToken=307c6ce4e08b837b,1,Application2015-05-03 10:32:40.8759,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.260.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application2015-05-03 10:32:40.8759,Info,,Plug-in reference to MediaBrowser,, Version=3.0.260.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.265.0,1,Application2015-05-03 10:32:40.8769,Debug,,Added Plugin assembly: Chocolate,, Version=3.0.8.2,, Culture=neutral,, PublicKeyToken=cbacf2b624ff6ad4,1,Application2015-05-03 10:32:40.8829,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.263.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application2015-05-03 10:32:40.8839,Info,,Plug-in reference to MediaBrowser,, Version=3.0.263.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.265.0,1,Application2015-05-03 10:32:40.8849,Debug,,=========System looking for assembly: MediaBrowser.Model,, Version=3.0.5573.17684,, Culture=neutral,, PublicKeyToken=6cde51960597a7f9,1,Application2015-05-03 10:32:40.8849,Info,,Resolving MediaBrowser.Model,, Version=3.0.5573.17684,, Culture=neutral,, PublicKeyToken=6cde51960597a7f9 to C:\ProgramData\MediaBrowser-Classic\MediaBrowser.Model.dll,1,Application2015-05-03 10:32:40.8879,Debug,,Added Plugin assembly: MBPlus.Classic,, Version=1.0.5.2,, Culture=neutral,, PublicKeyToken=307c6ce4e08b837b,1,Application2015-05-03 10:32:40.8999,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.243.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application2015-05-03 10:32:40.8999,Info,,Plug-in reference to MediaBrowser,, Version=3.0.243.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.265.0,1,Application2015-05-03 10:32:40.9059,Info,,Subdued - Creating Theme,1,Application2015-05-03 10:32:40.9169,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\The Original.mcml,1,Application2015-05-03 10:32:40.9179,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\The Original.mcml,1,Application2015-05-03 10:32:40.9179,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\White Shadow.mcml,1,Application2015-05-03 10:32:40.9179,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\White Shadow.mcml,1,Application2015-05-03 10:32:40.9179,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 1.mcml,1,Application2015-05-03 10:32:40.9189,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 1.mcml,1,Application2015-05-03 10:32:40.9189,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 2.mcml,1,Application2015-05-03 10:32:40.9189,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 2.mcml,1,Application2015-05-03 10:32:40.9189,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Blue Note.mcml,1,Application2015-05-03 10:32:40.9189,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Blue Note.mcml,1,Application2015-05-03 10:32:40.9189,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Cold as Ice.mcml,1,Application2015-05-03 10:32:40.9199,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Cold as Ice.mcml,1,Application2015-05-03 10:32:40.9199,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Neon.mcml,1,Application2015-05-03 10:32:40.9199,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Neon.mcml,1,Application2015-05-03 10:32:40.9199,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Redrum.mcml,1,Application2015-05-03 10:32:40.9199,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Redrum.mcml,1,Application2015-05-03 10:32:40.9199,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Red.mcml,1,Application2015-05-03 10:32:40.9209,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Red.mcml,1,Application2015-05-03 10:32:40.9209,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Blue.mcml,1,Application2015-05-03 10:32:40.9209,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Blue.mcml,1,Application2015-05-03 10:32:40.9209,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Green.mcml,1,Application2015-05-03 10:32:40.9209,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Green.mcml,1,Application2015-05-03 10:32:40.9219,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Orange.mcml,1,Application2015-05-03 10:32:40.9219,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Orange.mcml,1,Application2015-05-03 10:32:40.9219,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Yellow.mcml,1,Application2015-05-03 10:32:40.9219,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Yellow.mcml,1,Application2015-05-03 10:32:40.9219,Info,,Subdued - Validating installed styles,1,Application2015-05-03 10:32:40.9219,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Blue Note.mcml,1,Application2015-05-03 10:32:40.9219,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Cold as Ice.mcml,1,Application2015-05-03 10:32:40.9229,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Neon.mcml,1,Application2015-05-03 10:32:40.9229,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Redrum.mcml,1,Application2015-05-03 10:32:40.9229,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 1.mcml,1,Application2015-05-03 10:32:40.9229,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 2.mcml,1,Application2015-05-03 10:32:40.9229,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Blue.mcml,1,Application2015-05-03 10:32:40.9229,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Green.mcml,1,Application2015-05-03 10:32:40.9229,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Orange.mcml,1,Application2015-05-03 10:32:40.9229,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Red.mcml,1,Application2015-05-03 10:32:40.9229,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Yellow.mcml,1,Application2015-05-03 10:32:40.9229,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\The Original.mcml,1,Application2015-05-03 10:32:40.9229,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\White Shadow.mcml,1,Application2015-05-03 10:32:40.9299,Info,,Subdued - Theme Creation took 0.02 seconds.,1,Application2015-05-03 10:32:40.9309,Debug,,Added Plugin assembly: Subdued,, Version=3.0.1.17,, Culture=neutral,, PublicKeyToken=cbacf2b624ff6ad4,1,Application2015-05-03 10:32:40.9319,Info,,BDScreenSaver (version 2.0.0.4) Plug-in Loaded.,1,Application2015-05-03 10:32:40.9509,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Chocolate-strings-en.xml,1,Application2015-05-03 10:32:40.9709,Info,,Chocolate Theme (version 3.0.8.2) Loaded.,1,Application2015-05-03 10:32:40.9889,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Plugins/RegistrationRecords/MBPlus?Mb2Equivalent=MBPlus&format=Json,25,Worker thread for Common 2015-05-03 10:32:41.0159,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\MBPlus-strings-en.xml,1,Application2015-05-03 10:32:41.0179,Info,,MBPlus (version 1.0.5.2) Plug-in Loaded.,1,Application2015-05-03 10:32:41.0199,Info,,Subdued - Initializing Theme,1,Application2015-05-03 10:32:41.0209,Info,,Subdued - Checking active style: C:\ProgramData\MediaBrowser-Classic\Subdued_Styles.mcml,1,Application2015-05-03 10:32:41.0229,Info,,Subdued - Setting active style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\The Original.mcml,1,Application2015-05-03 10:32:41.0459,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Subdued-strings-en.xml,1,Application2015-05-03 10:32:41.0459,Info,,Subdued - Theme Initialization took 0.03 seconds.,1,Application2015-05-03 10:32:41.0459,Info,,Subdued - Version 3.0.1.17 ready,1,Application2015-05-03 10:32:41.0459,Info,,Plugin Loading and Init took 0.18 seconds.,1,Application2015-05-03 10:32:41.0689,Debug,,=========System looking for assembly: WebSocket4Net,, Version=0.12.0.0,, Culture=neutral,, PublicKeyToken=eb4e154b696bf72a,1,Application2015-05-03 10:32:41.0689,Info,,Resolving WebSocket4Net,, Version=0.12.0.0,, Culture=neutral,, PublicKeyToken=eb4e154b696bf72a to C:\ProgramData\MediaBrowser-Classic\websocket4net.dll,1,Application2015-05-03 10:32:41.0929,Info,,Connected to ws://192.168.0.10:8096/mediabrowser,1,Application2015-05-03 10:32:41.1249,Debug,,Sending Http Post to http://192.168.0.10:8096/mediabrowser/Sessions/Capabilities?format=Json,1,Application2015-05-03 10:32:41.1459,Debug,,Navigating to My Library item type MediaBrowser.Library.FolderModel,1,Application2015-05-03 10:32:41.1469,Debug,,Loading display prefs for ,1,Application2015-05-03 10:32:41.1499,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/DisplayPreferences/9b220f8d-2e0b-2dfa-e036-bc7809e9f05b?userId=3ab3d06361f5ce6186f568a7ecd9b343&client=MBC&format=Json,1,Application2015-05-03 10:32:41.2089,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d06361f5ce6186f568a7ecd9b343/Views?format=Json,1,Application2015-05-03 10:32:41.4770,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Items/9b220f8d2e0b2dfae036bc7809e9f05b/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json,1,Application2015-05-03 10:32:41.4850,Error,,Error getting response from http://192.168.0.10:8096/mediabrowser/Items/9b220f8d2e0b2dfae036bc7809e9f05b/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (400) Bad Request. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),1,Application 2015-05-03 10:32:41.4900,Debug,,GoToPage: resx://MBPlus.Classic/MBPlus.Classic.Resources/MetroEHS#PanoramicMetroEHS,1,Application2015-05-03 10:32:41.5060,Debug,,=========System looking for assembly: MBPlus.Classic,1,Application2015-05-03 10:32:41.5060,Info,,Resolving plug-in reference to: MBPlus.Classic,1,Application2015-05-03 10:32:41.7410,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/MBPlus/Users/3ab3d06361f5ce6186f568a7ecd9b343/Categories?format=Json,1,Application2015-05-03 10:32:41.9680,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/MBPlus/Users/3ab3d06361f5ce6186f568a7ecd9b343/Folder/f0cadffa9dce42e4a11625eb4338ca65/Children?fields=Overview,,IndexOptions,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&format=Json,1,Application2015-05-03 10:32:41.9880,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/MBPlus/Users/3ab3d06361f5ce6186f568a7ecd9b343/Folder/8e02c149f6abd8dc8ef8806623b5f558/Children?fields=Overview,,IndexOptions,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&format=Json,1,Application2015-05-03 10:32:41.9970,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/DisplayPreferences/be80f845-0631-1457-34a6-841fbf32597b?userId=3ab3d06361f5ce6186f568a7ecd9b343&client=MBC&format=Json,1,Application2015-05-03 10:32:41.9990,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Items/8e02c149f6abd8dc8ef8806623b5f558/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json,1,Application2015-05-03 10:32:42.0030,Error,,Error getting response from http://192.168.0.10:8096/mediabrowser/Items/8e02c149f6abd8dc8ef8806623b5f558/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (400) Bad Request. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),1,Application 2015-05-03 10:32:42.0040,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/MBPlus/Users/3ab3d06361f5ce6186f568a7ecd9b343/Folder/434c09b4f30eef000b94da7bd285ae80/Children?fields=Overview,,IndexOptions,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&format=Json,1,Application2015-05-03 10:32:42.0810,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/DisplayPreferences/a7fe19bb-1044-22f7-c0ca-0f2bf81213bb?userId=3ab3d06361f5ce6186f568a7ecd9b343&client=MBC&format=Json,1,Application2015-05-03 10:32:42.0830,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Items/434c09b4f30eef000b94da7bd285ae80/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json,1,Application2015-05-03 10:32:42.0890,Error,,Error getting response from http://192.168.0.10:8096/mediabrowser/Items/434c09b4f30eef000b94da7bd285ae80/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (400) Bad Request. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),1,Application 2015-05-03 10:32:42.0920,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/MBPlus/Users/3ab3d06361f5ce6186f568a7ecd9b343/ChannelGroup/2dd05c928acf57427627ce9c7d5f97f1/Children?fields=Overview,,IndexOptions,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&format=Json,1,Application2015-05-03 10:32:42.1050,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/b090b2e2-c5da-2302-7533-eaed79c5deed?format=Json,1,Application2015-05-03 10:32:42.1370,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/09bc914b-1425-8220-5d5e-b623d21a49a9?format=Json,1,Application2015-05-03 10:32:42.1480,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/b7a39630-b7b0-30ab-ef52-cb229e54ced1?format=Json,1,Application2015-05-03 10:32:42.1550,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/2af506a1-1868-d67f-2dc2-57a028451297?format=Json,1,Application2015-05-03 10:32:42.1630,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/639bd35a-63ea-3db2-91db-77e24115078b?format=Json,1,Application2015-05-03 10:32:42.1740,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/c173b9ce-0587-62bb-a12c-ccfa4b7baf99?format=Json,1,Application2015-05-03 10:32:42.1990,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/c10284ea-9a74-e0cf-4673-7974922877f1?format=Json,1,Application2015-05-03 10:32:42.2100,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/c76b8f93-fe02-093b-7a62-1d57ff23289c?format=Json,1,Application2015-05-03 10:32:42.2190,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/8ba6e697-76e1-c836-2074-1b2567a40a39?format=Json,1,Application2015-05-03 10:32:42.2280,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/83fc97da-ab45-0b45-c488-ee9669f0d69f?format=Json,1,Application2015-05-03 10:32:42.2360,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/fcdd3635-603d-a6f2-1e66-9ac2fa51f860?format=Json,1,Application2015-05-03 10:32:42.2480,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/24f314c1-b3fe-e6fe-5920-60f8b538fcc4?format=Json,1,Application2015-05-03 10:32:42.2560,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/DisplayPreferences/e1319237fa3f5777c7d769eb500e56d5?userId=3ab3d06361f5ce6186f568a7ecd9b343&client=MBC&format=Json,1,Application2015-05-03 10:32:42.2590,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Items/2dd05c928acf57427627ce9c7d5f97f1/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json,1,Application2015-05-03 10:32:42.2630,Error,,Error getting response from http://192.168.0.10:8096/mediabrowser/Items/2dd05c928acf57427627ce9c7d5f97f1/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (400) Bad Request. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),1,Application 2015-05-03 10:32:42.2630,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/MBPlus/Users/3ab3d06361f5ce6186f568a7ecd9b343/Folder/7c6bb85f1129d6c74e53b14a9cffe4e3/Children?fields=Overview,,IndexOptions,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&format=Json,1,Application2015-05-03 10:32:42.2890,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/DisplayPreferences/4bec02a0-d530-abb4-12ab-22b5f725295c?userId=3ab3d06361f5ce6186f568a7ecd9b343&client=MBC&format=Json,1,Application2015-05-03 10:32:42.2920,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Items/7c6bb85f1129d6c74e53b14a9cffe4e3/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json,1,Application2015-05-03 10:32:42.2960,Error,,Error getting response from http://192.168.0.10:8096/mediabrowser/Items/7c6bb85f1129d6c74e53b14a9cffe4e3/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (400) Bad Request. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),1,Application 2015-05-03 10:32:42.2960,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/MBPlus/Users/3ab3d06361f5ce6186f568a7ecd9b343/Folder/147d78ab702186470d744bf7310fd42b/Children?fields=Overview,,IndexOptions,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&format=Json,1,Application2015-05-03 10:32:42.3100,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/DisplayPreferences/e6c39d25-c87b-9c5c-a911-0f1fc17e34ee?userId=3ab3d06361f5ce6186f568a7ecd9b343&client=MBC&format=Json,1,Application2015-05-03 10:32:42.3120,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Items/147d78ab702186470d744bf7310fd42b/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json,1,Application2015-05-03 10:32:42.3160,Error,,Error getting response from http://192.168.0.10:8096/mediabrowser/Items/147d78ab702186470d744bf7310fd42b/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (400) Bad Request. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),1,Application 2015-05-03 10:32:42.3160,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/MBPlus/Users/3ab3d06361f5ce6186f568a7ecd9b343/ChannelGroup/49ed7669d7942027f55dd9227ac73c20/Children?fields=Overview,,IndexOptions,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&format=Json,1,Application2015-05-03 10:32:42.5210,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/MBPlus/Users/3ab3d06361f5ce6186f568a7ecd9b343/Channel/e3db7d2d704f4842511ef477a3233f6f/Children?fields=Overview,,IndexOptions,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&format=Json,1,Application2015-05-03 10:32:42.6760,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/DisplayPreferences/aee05aca086ee34aa48c0691fdcb852c?userId=3ab3d06361f5ce6186f568a7ecd9b343&client=MBC&format=Json,1,Application2015-05-03 10:32:42.6790,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Items/49ed7669d7942027f55dd9227ac73c20/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json,1,Application2015-05-03 10:32:42.6860,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/MBPlus/Users/3ab3d06361f5ce6186f568a7ecd9b343/Folder/d85ce1757b98e5f3155241e31716252e/Children?fields=Overview,,IndexOptions,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&format=Json,1,Application2015-05-03 10:32:42.6970,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Items/d85ce1757b98e5f3155241e31716252e/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json,1,Application2015-05-03 10:32:42.7010,Error,,Error getting response from http://192.168.0.10:8096/mediabrowser/Items/d85ce1757b98e5f3155241e31716252e/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (400) Bad Request. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),1,Application 2015-05-03 10:32:42.7050,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Items/Counts/?userId=3ab3d063-61f5-ce61-86f5-68a7ecd9b343&format=Json,1,Application2015-05-03 10:32:42.7480,Debug,,=========System looking for assembly: BDScreenSaver,1,Application2015-05-03 10:32:42.7500,Info,,Resolving plug-in reference to: BDScreenSaver,1,Application2015-05-03 10:32:43.1841,Debug,,************** Api item count is null for Genres,29,Worker thread for Common2015-05-03 10:32:43.1871,Debug,,MBPlus Loading resx image: mbplusresx://MBPlus.Classic/MBPlus.Classic.Resources/genrestile / genrestile,21,Image loader-Worker2015-05-03 10:32:43.1981,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/83917704-2fdd-6bd9-e49e-3eefb1ea61c0?format=Json,1,Application2015-05-03 10:32:43.1991,Debug,,MBPlus Loading resx image: mbplusresx://MBPlus.Classic/MBPlus.Classic.Resources/yearstile / yearstile,21,Image loader-Worker2015-05-03 10:32:43.2021,Debug,,MBPlus Loading resx image: mbplusresx://MBPlus.Classic/MBPlus.Classic.Resources/actorstile / actorstile,20,Image loader-Worker2015-05-03 10:32:43.2051,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Genres/?sortBy=SortName&fields=SortName&Filters=&UserId=3ab3d06361f5ce6186f568a7ecd9b343&recursive=True&ExcludeItemTypes=&IncludeItemTypes=Movie&format=Json,29,Worker thread for Common 2015-05-03 10:32:43.2591,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/DisplayPreferences/454e0561-21c6-b286-0cc7-a2e41faa4848?userId=3ab3d06361f5ce6186f568a7ecd9b343&client=MBC&format=Json,29,Worker thread for Common 2015-05-03 10:32:43.2691,Debug,,************** Api item count is null for Genres,24,Worker thread for Common2015-05-03 10:32:49.2324,Debug,,Navigating to Welcome to the Punch item type MediaBrowser.Library.Item,1,Application2015-05-03 10:32:49.2414,Debug,,Loading full details for Welcome to the Punch,1,Application2015-05-03 10:32:49.2414,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/d7cc61ea-f256-7aba-712f-ebf1652225ff?format=Json,1,Application2015-05-03 10:32:49.2524,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Items/d7cc61eaf2567aba712febf1652225ff/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json,1,Application2015-05-03 10:32:49.2644,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/MovieDetailsPage,1,Application2015-05-03 10:32:49.3724,Debug,,=========System looking for assembly: Subdued,1,Application2015-05-03 10:32:49.3724,Info,,Resolving plug-in reference to: Subdued,1,Application2015-05-03 10:32:49.6304,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Persons/James+McAvoy?format=Json,1,Application2015-05-03 10:32:49.6994,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Localization/ParentalRatings?format=Json,1,Application2015-05-03 10:32:49.7584,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Images/MediaInfo?format=Json,1,Application2015-05-03 10:32:49.8254,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2frated_gb_15,1,Application2015-05-03 10:32:49.8644,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2frated_gb_15 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:49.8715,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2frated_gb_15,1,Application2015-05-03 10:32:49.8715,Info,,Subdued - Checking active MediaInfo icons set,10,2015-05-03 10:32:49.8725,Info,,Subdued - Checking active MediaInfo icons set,16,2015-05-03 10:32:49.8745,Info,,Subdued - Setting active MediaInfo icons set: MediaInfo\Subdued\mediainfo_mono.zip took 0.00 seconds.,16,2015-05-03 10:32:49.8755,Error,,Subdued - Error setting active MediaInfo icons set: The process cannot access the file 'C:\ProgramData\MediaBrowser-Classic\MediaInfo\Subdued\mediainfo_mono.zip' because it is being used by another process.,16,2015-05-03 10:32:49.8945,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2frated_gb_15 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:49.9715,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fmedia_mkv,1,Application2015-05-03 10:32:49.9995,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fmedia_mkv being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.0055,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fcodec_h262,1,Application2015-05-03 10:32:50.0255,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fcodec_h262 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.0315,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2faspect_133,1,Application2015-05-03 10:32:50.0635,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2faspect_133 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.0695,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fcodec_ac3,1,Application2015-05-03 10:32:50.0795,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fcodec_ac3 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.0825,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fchannels_6,1,Application2015-05-03 10:32:50.1035,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fchannels_6 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.1065,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fmedia_mkv,1,Application2015-05-03 10:32:50.1185,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fmedia_mkv being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.1205,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fcodec_h262,1,Application2015-05-03 10:32:50.1305,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fcodec_h262 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.1345,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2faspect_133,1,Application2015-05-03 10:32:50.1455,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2faspect_133 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.1485,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fcodec_ac3,1,Application2015-05-03 10:32:50.1585,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fcodec_ac3 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.1625,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fchannels_6,1,Application2015-05-03 10:32:50.1735,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fchannels_6 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.3905,Info,,Subdued - Setting active MediaInfo icons set: MediaInfo\Subdued\mediainfo_mono.zip took 0.52 seconds.,10,2015-05-03 10:32:50.3915,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fmedia_mkv,1,Application2015-05-03 10:32:50.4015,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fmedia_mkv being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.4055,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fcodec_h262,1,Application2015-05-03 10:32:50.4145,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fcodec_h262 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.4165,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2faspect_133,1,Application2015-05-03 10:32:50.4255,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2faspect_133 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.4285,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fcodec_ac3,1,Application2015-05-03 10:32:50.4365,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fcodec_ac3 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.4395,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fchannels_6,1,Application2015-05-03 10:32:50.4545,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fchannels_6 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.4575,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fmedia_mkv,1,Application2015-05-03 10:32:50.4795,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fmedia_mkv being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.4835,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fcodec_h262,1,Application2015-05-03 10:32:50.4925,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fcodec_h262 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.4955,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2faspect_133,1,Application2015-05-03 10:32:50.5055,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2faspect_133 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.5085,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fcodec_ac3,1,Application2015-05-03 10:32:50.5185,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fcodec_ac3 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.5215,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fchannels_6,1,Application2015-05-03 10:32:50.5315,Debug,,===CustomImage http://192.168.0.10:8096/mediabrowser/Images/MediaInfo/Subdued%2fchannels_6 being cached on first access. Shouldn't have to do this again...,1,Application 2015-05-03 10:32:50.8545,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Plugins/RegistrationRecords/mbsupporter?Mb2Equivalent=mbsupporter&format=Json,25,Worker thread for Common 2015-05-03 10:32:51.1645,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Packages/MBClassic?format=Json,29,Worker thread for Common 2015-05-03 10:32:51.6416,Debug,,New version 3.0.266 found.,29,Worker thread for Common2015-05-03 10:32:53.3957,Debug,,Not updating. User refused or not requested.,29,Worker thread for Common2015-05-03 10:32:55.6378,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/d7cc61eaf2567aba712febf1652225ff/Intros?format=Json,1,Application2015-05-03 10:32:56.0548,Info,,Playing 3 Intros before Welcome to the Punch,1,Application2015-05-03 10:32:56.1168,Info,,Internal Player about to play (\\whs2\movies\DVD\Machine Gun Preacher\Trailers\machinegunpreacher.mov) ,1,Application2015-05-03 10:32:56.1318,Info,,Internal Player playing ,1,Application2015-05-03 10:32:56.1468,Debug,,Calling MediaCenterEnvironment.PlayMedia: Microsoft.MediaCenter.MediaCollection,1,Application2015-05-03 10:32:56.1538,Debug,,Error playing item: PlayMedia returned false,1,Application2015-05-03 10:33:08.2545,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Items/Counts/?userId=3ab3d063-61f5-ce61-86f5-68a7ecd9b343&format=Json,1,Application2015-05-03 10:33:08.8706,Debug,,Nav To Last. Index: 0 Subtile: 0,1,Application2015-05-03 10:33:09.5786,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/MBPlus/Users/3ab3d06361f5ce6186f568a7ecd9b343/Folder/56edef1dfb42a306aa9bab0aca26dbea/Children?fields=Overview,,IndexOptions,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&format=Json,1,Application2015-05-03 10:33:09.7806,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/DisplayPreferences/61d217d1-5f95-2b09-5e6b-c0fc42fdd37d?userId=3ab3d06361f5ce6186f568a7ecd9b343&client=MBC&format=Json,1,Application2015-05-03 10:33:09.7836,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Items/56edef1dfb42a306aa9bab0aca26dbea/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json,1,Application2015-05-03 10:33:09.7876,Error,,Error getting response from http://192.168.0.10:8096/mediabrowser/Items/56edef1dfb42a306aa9bab0aca26dbea/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (400) Bad Request. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),1,Application 2015-05-03 10:33:09.7876,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/MBPlus/Users/3ab3d06361f5ce6186f568a7ecd9b343/Folder/c0453a6f441549fcb9094f1dadee290a/Children?fields=Overview,,IndexOptions,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&format=Json,1,Application2015-05-03 10:33:09.7916,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Items/c0453a6f441549fcb9094f1dadee290a/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json,1,Application2015-05-03 10:33:09.7986,Error,,Error getting response from http://192.168.0.10:8096/mediabrowser/Items/c0453a6f441549fcb9094f1dadee290a/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (400) Bad Request. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),1,Application 2015-05-03 10:33:09.8046,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Users/3ab3d063-61f5-ce61-86f5-68a7ecd9b343/Items/48f47c5b-493b-d3d2-3adc-b4cdc838b2a6?format=Json,1,Application2015-05-03 10:33:26.5616,Debug,,Keep alive call,, IsCurretntlyVisible=True,1,Application2015-05-03 10:34:26.5660,Debug,,Keep alive call,, IsCurretntlyVisible=True,1,Application2015-05-03 10:35:26.5645,Debug,,Keep alive call,, IsCurretntlyVisible=True,1,Application2015-05-03 10:35:50.8059,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/MBPlus/Users/3ab3d06361f5ce6186f568a7ecd9b343/Folder/038877a2ac003706b6bcf4664c019f8c/Children?fields=Overview,,IndexOptions,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&format=Json,1,Application2015-05-03 10:35:51.0159,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/DisplayPreferences/1111301c-1cfa-84fb-cc4a-c9b6ddc0b94a?userId=3ab3d06361f5ce6186f568a7ecd9b343&client=MBC&format=Json,1,Application2015-05-03 10:35:51.0189,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Items/038877a2ac003706b6bcf4664c019f8c/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json,1,Application2015-05-03 10:35:51.0219,Error,,Error getting response from http://192.168.0.10:8096/mediabrowser/Items/038877a2ac003706b6bcf4664c019f8c/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (400) Bad Request. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),1,Application 2015-05-03 10:35:51.0229,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/MBPlus/Users/3ab3d06361f5ce6186f568a7ecd9b343/Folder/f492f66fada89d6cdfe8cae43f1b85d7/Children?fields=Overview,,IndexOptions,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&format=Json,1,Application2015-05-03 10:35:51.0359,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/DisplayPreferences/a0ffa375-e533-fef8-54c2-280420fab2dd?userId=3ab3d06361f5ce6186f568a7ecd9b343&client=MBC&format=Json,1,Application2015-05-03 10:35:51.0389,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Items/f492f66fada89d6cdfe8cae43f1b85d7/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json,1,Application2015-05-03 10:35:51.0419,Error,,Error getting response from http://192.168.0.10:8096/mediabrowser/Items/f492f66fada89d6cdfe8cae43f1b85d7/ThemeMedia?InheritFromParent=False&UserId=3ab3d06361f5ce6186f568a7ecd9b343&format=Json ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (400) Bad Request. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),1,Application 2015-05-03 10:35:51.0479,Info,,Sending Http Get to http://192.168.0.10:8096/mediabrowser/Channels?userid=3ab3d06361f5ce6186f568a7ecd9b343&format=Json,1,Application2015-05-03 10:35:51.0619,Debug,,Fetching image: http://192.168.0.10:8096/mediabrowser/Items/f53b80e0e3e0188ac011f1ff12aeae99/Images/Primary?maxWidth=350&Quality=90&tag=2640964ecf1687b4ece0a8c8d32c71be,23,Net Image loader-Worker
tman 47 Posted May 3, 2015 Author Posted May 3, 2015 (edited) Ok, I can see beta 266 has just been pushed out. Upgrading to this version seems to fix it. Is that the behavior expected from this release? Edited May 3, 2015 by tman
Solution ebr 16334 Posted May 3, 2015 Solution Posted May 3, 2015 Ok, I can see beta 266 has just been pushed out. Upgrading to this version seems to fix it. Is that the behavior expected from this release? Well, it isn't expected but it was obviously the same bug that was causing "Play All" to fail since that is what 266 fixed.
