blade005 185 Posted May 1, 2015 Posted May 1, 2015 Emby Server Version 3.0.5597.1 Emby Theater Version 3.0.5591.19855 Playback of Recorded TV (WTV) files with Theater is showing a 3 to 4 second length in the Progress Bar and does not allow any FFWD of the file. The file will continue to play past this length, but any attempt to FFWD will stop play. No resume status as well. Version 3.0.5531 of Theater was the previous version and did not have this issue. Doesn't appear to be an issue with MP4 or MKV files, just WTV files.
hoxtonia 46 Posted May 10, 2015 Posted May 10, 2015 Server 3.0.5608.30475 Emby Theater 3.0.5591.19855 I too experience this with WTV files - having to add a conversion process to recorded tv is a pain and causing me pain from the family. Hoping for a fix on this
hoxtonia 46 Posted May 11, 2015 Posted May 11, 2015 Recording from last night Loads fine in recordings - click play - shows 2 seconds on progress bar - video plays back but no fast forward sample in my google drive https://drive.google.com/folderview?id=0B5woaBa5i7_7fjZFMXRTMmVGdGJmLUtoV2pXRy0xY055WlhfOEZremhZNUFidU4wX3d3YlE&usp=sharing
Luke 42239 Posted May 11, 2015 Posted May 11, 2015 Ok, the server handles this fine, but video player in MBT does not. It's probably going to come down to an issue in lav filters.
hoxtonia 46 Posted May 11, 2015 Posted May 11, 2015 ok thanks for checking Luke... I will have to live with the conversion step for now.... as Blade005 said this used to work fine....
babgvant 143 Posted May 12, 2015 Posted May 12, 2015 IIRC, LAV does not enable WTV support by default and MBT doesn't expose container toggles through its settings UI (or set it for that matter to implictly trust Nevcairiel's decisions) so I don't think LAV should be used for WTV (it will work most of the time, but ffmpeg's support isn't as good as the SBE). Can you check the log to see if it is?
