mattyg8 18 Posted April 30, 2015 Posted April 30, 2015 (edited) My server is linked to Emby Connect but when I try to access via web client and log in it comes up with select server. So I click on MATT-PC But it pops up with Connection Failure: Were unable to connect to the selected server right now. Please ensure it is running and try again. On my router I have the correct ports forwarded as I used to access the server by entering in my public Ip address:8096/mediabrowser/web/dashboard.html But it seems over last few days my ISP has changed my public ip address twice so thought I would try web client. I also have a vpn setup but can still access web server using my public ip address Heres the log 2015-05-01 08:58:49.5226 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: ceb794be86404769b17e8d4f4787e24f 2015-05-01 08:58:59.5231 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 33e03782f117432a8e50eba8af22eabf 2015-05-01 08:58:59.5231 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 42f5bb15d1c942149e0a49ad6c9222b6 2015-05-01 08:58:59.5231 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 78a3aa45f385419693fbc7578a063363 2015-05-01 08:58:59.5231 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 051f9bb8e7ec486081114a5bc3cf84bd 2015-05-01 08:58:59.5231 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: b87698d0be024efb942583ae4643cf5e Edited April 30, 2015 by mattyg8
Sparrowlogins 18 Posted May 7, 2015 Posted May 7, 2015 I am having the same issue at app.emby.media - log in ok, internal network on web app works but connecting on a machine external to the network results in the same above error when clicking my server name once logged in.
Luke 42301 Posted May 7, 2015 Posted May 7, 2015 I am having the same issue at app.emby.media - log in ok, internal network on web app works but connecting on a machine external to the network results in the same above error when clicking my server name once logged in. This isn't a case of the web client not working, it's a case of not being able to get through to your server. So you may want to look at your router and port forwarding.
akash.chaudhary 0 Posted May 27, 2015 Posted May 27, 2015 Hello Admin, I have received invitation from one of my friends to connect to his MB server, however when I click on that server it's giving me error message " We're unable to connect to the selected server right now. Please ensure it is running and try again" Kindly suggest what I am doing wrong.
ebr 16357 Posted May 27, 2015 Posted May 27, 2015 You probably aren't doing anything wrong. His server may not be up or it may not be configured for outside access properly.
