Kodi acting erratic
Long story short, my kodi has been rebooting on my a good bit lately.  Stop a video reboot, check updates, reboot.  Things it doesnt do without emby.
Another thing it does, it will quit talking to the server.  Watched 2 shows tonight, neither appear in the recent activity.  As though suddenly emby/kodi are not reporting to the server.
And then another, watching a show tonight when the episod. just quit/stopped with a few minutes left.  There was no option to recover so I rebooted.  Even after reboot, I couldnt resume playback.  The video just hung.
I thought it would be easiest to group all issues in one as everything does appear to relate
kodi.log
kodi.old.log
Angelblue05
Does it work ok if you disable ssl? Just curious.
I never turned see on... Is it suddenly on?
Angelblue05
@@kolbasz
Make sure in your Emby for Kodi settings that you haven't enabled https if you are not using it. Let me know.
22:58:41 T:1837986880   ERROR: /storage/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/util/ssl_.py:79: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. For more information, see https://urllib3.readthedocs.org/en/latest/security.html#insecureplatformwarning.
As for your actual problem I'm thinking maybe we need to just set a check for runtimeticks.
Edited by Angelblue05
as a heads up, item 3 was a bad file.  I went and tried playing it on my computer with MPC-HT, which plays everything and it had the same behavior.
I will check the https tonight.
  • Like 1
checked for SSL, opened emby add-on setting, under emby tab, SSL/https is not enabled.
  • Like 1
Angelblue05
Thanks for checking. I think I will have to add an extra verification for it. Just incase :)
Guest
