venkavis 1 Posted April 28, 2015 Posted April 28, 2015 I installed a few Plugins from MB site and re-started the FREENAS MB3 Plugin. The plugin goes to start and then immediately goes to OFF mode. I am able to start the webclient and within a second it errors out. I Cant see any logs on the /var/log on the MB3 Jail in FREENAS. Kindly suggest how to troubleshoot~ ~Venkat V
woodsb02 17 Posted April 28, 2015 Posted April 28, 2015 The logs can be found in /var/db/mediabrowser/logs or /var/db/emby-server/logs within the jail, depending on the version.
venkavis 1 Posted April 28, 2015 Author Posted April 28, 2015 I installed a bunch, Here is what I could remember. The WMC Plugin Cover Art Some theme I guess. I think Installed 4 and dont remember the other two. What files are the server logs? Sorry I am new to Emby. There is not much in the messages. ~Venkat V
venkavis 1 Posted April 28, 2015 Author Posted April 28, 2015 Here are the last log files. unhandled_df966f59-8d90-437e-8179-c8908b12bc9b.txt server-63565784862.txt
Luke 42237 Posted April 28, 2015 Posted April 28, 2015 Ok, it looks like MBPlus is encountering an error. This is actually resolved in the latest version of the server which might not yet be published for freenas. In the meantime I would just remove the MBPlus plugin.
venkavis 1 Posted April 28, 2015 Author Posted April 28, 2015 How do I remove the MbPlus Plugin? I am not able to get the server up. I cant go to the server admin page.
Luke 42237 Posted April 28, 2015 Posted April 28, 2015 go to /var/db/emby/plugins delete the MBPlus dll file
venkavis 1 Posted April 28, 2015 Author Posted April 28, 2015 Thank you. My Emby is up and running now. Appreciate the Ultra fast feedback and support. ~Venkat V 1
