Help with transcoding files
Go to solution Solved by Luke,
farside847
Hi guys, I started to notice that a few of my kids shows are transcoding when I play them back on the roku - could it be the framerate? I dont remember it being this picky, but technically the roku only supports 24 and 30fps. this file is 60.
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709), 1280x720 [sAR 1:1 DAR 16:9], 3204 kb/s, 51.61 fps, 59.94 tbr, 90k tbn, 180k tbc (default)
    Metadata:
      handler_name    : VideoHandler
    Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 384 kb/s (default)
    Metadata:
      handler_name    : Stereo
    Stream #0:2: Video: mjpeg, yuvj444p(pc, bt470bg/unknown/unknown), 680x1000 [sAR 72:72 DAR 17:25], 90k tbr, 90k tbn, 90k tbc
I will post the transcode log, but the server log is huge so I wont bother unless its needed. :)
transcode-cfa8c1b1-fb73-4552-945b-b22fa35ce668.txt
  • Solution
yes it's limited to 30
  • Like 1
farside847
cool, thanks!
