dibsta 0 Posted April 26, 2015 Posted April 26, 2015 Hi All I'm cannot to find the cause of my problem Every 4 hours I get "Refresh Guide failed database disk image is malformed database disk image is malformed" My setup Windows 7 64bit i3 Processor 8Gb Ram Emby Server Version 3.0.5588.1 I've attached server log Hope someone can help Thanks Dave server-63565679885.txt
ebr 16307 Posted April 26, 2015 Posted April 26, 2015 Looks like your library database has become corrupted. You may need to shut down the server and delete the library.db file under the data directory and then re-start and let it re-build.
dibsta 0 Posted April 26, 2015 Author Posted April 26, 2015 Looks like your library database has become corrupted. You may need to shut down the server and delete the library.db file under the data directory and then re-start and let it re-build. Thanks ebr ill try that now and let you know how I get on
dibsta 0 Posted April 26, 2015 Author Posted April 26, 2015 Cheers ebr did what you suggested and its sorted it, but i've now lost my boxsets cheers Dave
