audiounit 0 Posted April 25, 2015 Posted April 25, 2015 Hi, I've been using the web client for a while now, when I had previously added to home screen it would treat the web client like an app going to full screen "no safari menu bar" and was separate from my normal tabs. Recently I changed ip's so I had to readdress my web client and re add it to home, since then it won't go full screen and just opens up in safari with my other tabs. Has something changed? Does anyone now how I can sort this out and get it working in full screen mode again? I have other webpages saved this way and they still work as expected. I'm running iOS 8.4 Cheers.
Luke 42243 Posted April 25, 2015 Posted April 25, 2015 the web client doesn't have a back button and right now i don't plan on reworking the UI to add one. so that is the problem with taking away the address bar
audiounit 0 Posted April 26, 2015 Author Posted April 26, 2015 Ok, thanks for the response. I always just swiped from off the screen left/right to go back and forward pages, I understand this feature might not be common knowledge and removing the menu bar might create more problems for the general user.
Luke 42243 Posted April 26, 2015 Posted April 26, 2015 thanks. in any event, i am going to add the button to the top left so that the menu bar can be removed in iOS. It's not ideal having the menu bar button next to it, but I don't want to rework the whole layout and it accomplish the intended goal.
audiounit 0 Posted April 27, 2015 Author Posted April 27, 2015 That's great, appreciate the consideration. Just want to give you guys a big thumbs up been using media browser since its first iteration and it just keeps better and better. Big fan here.
audiounit 0 Posted May 1, 2015 Author Posted May 1, 2015 It's working great in full screen mode again. I just had to "add to home" again to reset the icon, Cheers.
