Dan64 31 Posted April 25, 2015 Posted April 25, 2015 (edited) Hello., I'm using Emby Server 3.0.5588.1. I'm using the parental settings in Emby. The settings available in Emby are for US country and at the moment I'm using the parent filter to rating "PG\TV-PG". Now, since I have setup as preferred language Italian, some time are downloaded from the metadata info-providers rating used in Italy, for example "IT-T". I'd like to know if Emby is using a mapping table in this case or is unable to use rating specified for non US countries. Could be possible specify in metadata download settings to use a rating system specific for a give country as in Kodi ? Edited April 25, 2015 by Dan64
ebr 16307 Posted April 25, 2015 Posted April 25, 2015 The "Country" setting in the metadata settings page determines this. However, we may or may not have Italian ratings defined. If not, if you can provide them, they can be added.
Dan64 31 Posted April 25, 2015 Author Posted April 25, 2015 (edited) In Italy there are only 3 ratings (*): IT-T (all): All ages admitted. IT-VM14: Not suitable for children under 14 IT-VM18: Not suitable for children under 18 More info can be found at: http://en.wikipedia.org/wiki/Motion_picture_rating_system (*) I don't like this, I prefer the US rating system that is more granular. Edited April 25, 2015 by Dan64
