Dan64 32 Posted April 25, 2015 Posted April 25, 2015 Hello, I'm using Emby Server 3.0.5588.1 on Debian 8.0 I have configured the following settings (for max Kodi and Emby compatibility) I have set these settings for all the services where was allowed. Now the problem: Before to add Nfo as saver, when a new season was added Emby created the following files: Season N\metadata\sXeYY - filename.xml Season N\metadata\sXeYY - filename.jpg After adding Nfo as saver, Emby creates the following files: Season N\sXeYY - filename.nfo Season N\sXeYY - filename-thumb.jpg Season N\metadata\sXeYY - filename.xml It is not more created the file: Season N\metadata\sXeYY - filename.jpg This is an intended behavior to avoid image duplication or is a bug ? What happen if I decide to remove the Nfo saver/reader from services to the episodes with missing metadata images ?
