ronsws6 4 Posted April 24, 2015 Posted April 24, 2015 Lately instead of displaying a single image for a box set in Theatre it takes the individual covers, chops them up and puts them together like this: Any Ideas? TIA
ebr 16342 Posted April 24, 2015 Posted April 24, 2015 That's a new feature but it should only be happening if there isn't a specific cover for that collection. Also, we might need a way to disable the feature just for collections since those automatic images will never look good with any CA treatment.
ronsws6 4 Posted April 25, 2015 Author Posted April 25, 2015 (edited) Well That's the other thing. These are all legit collections that do have specific covers. If I go back into Server and edit and browse images I can redownload the correct one, but I have 50-70 collections and I don't know if the next update will reverse it back to the split images that look horrible. Edited April 25, 2015 by ronsws6
Allan Cameron 40 Posted April 25, 2015 Posted April 25, 2015 I would remove the word "collection" in your naming, makes the collection titles too long and they don't fit. At least that's what I did as its not needed and it looks much better.
ronsws6 4 Posted April 25, 2015 Author Posted April 25, 2015 (edited) I didn't name any of them "collections". The software did. Now the software seems to change all the collection names to "collection". Like the Blade triology is now "Blade Collection" Edited April 25, 2015 by ronsws6
Happy2Play 9814 Posted April 25, 2015 Posted April 25, 2015 I didn't name any of them "collections". The software did. Now the software seems to change all the collection names to "collection". Like the Blade triology is now "Blade Collection" That would be the name pulled from TMDBID.
ebr 16342 Posted April 25, 2015 Posted April 25, 2015 Well That's the other thing. These are all legit collections that do have specific covers. If I go back into Server and edit and browse images I can redownload the correct one, but I have 50-70 collections and I don't know if the next update will reverse it back to the split images that look horrible. Well, then that sounds like a bug in the new feature. A specific image should take precedence I would think. Were you running dev releases at any point? If so, it might have been a bug that was fixed.
ronsws6 4 Posted April 25, 2015 Author Posted April 25, 2015 Well, then that sounds like a bug in the new feature. A specific image should take precedence I would think. Were you running dev releases at any point? If so, it might have been a bug that was fixed. No. All I allow are final releases.
Allan Cameron 40 Posted April 25, 2015 Posted April 25, 2015 I didn't name any of them "collections". The software did. Now the software seems to change all the collection names to "collection". Like the Blade triology is now "Blade Collection" Hmm, well mine did to at first.. but i just renamed everything. Not sure why you can't.. should be able to like i have.
