bluemonkey07 590 Posted April 22, 2015 Posted April 22, 2015 It would be great to be able to set which devices will use cinema mode in addition to the current option of content type, the reason being it would be more likely to want this function when watching a movie in your home theatre than when watching a movie on your smartphone etc
ebr 16337 Posted April 22, 2015 Posted April 22, 2015 The better approach (IMO) is to have app-level control of the feature. Either a way to disable it at the app level or a way to playback with or without intros. For instance, MBC only plays the intros if you initiate playback from the detail screen. That's not the best approach because it is basically hidden but I still think this type of option should be controllable from the app at playback time.
bluemonkey07 590 Posted April 22, 2015 Author Posted April 22, 2015 Well yea that's another way just seems that the trend with emby is to have less settings for the client and everything set via the server, that's why I suggested this approach
ebr 16337 Posted April 22, 2015 Posted April 22, 2015 Yes - but only for items that should be the same in all apps. This is an instance (like, say, sort order) where the choice should be more distributed and maybe even left up to each user at the time of playback.
