johnlo317 4 Posted April 21, 2015 Posted April 21, 2015 I installed OpenELEC for Raspberry Pi. I downloaded the xbmb3c Repo from link - http://cdn.mediabrowser.tv/downloads/addons/xbmb3c/xbmb3c-repo/repository.xbmb3c-1.0.2.zip. From RPi, when I do the Installed Zip File, It is telling me that the structure isnt correct or something like that. Am I downloading the correct file? Thanks John
kolbasz 20 Posted April 21, 2015 Posted April 21, 2015 I think your XBMC is jacked and you are not able to write to storage. I had a similar issue and noticed that none of the plugins would even update. In the end, I blew everything away and started over. I know in the last few days I say both this structure issue and also the inability to install/update other add-ons. Starting over resolved my issues.
