thefirstofthe300 292 Posted April 20, 2015 Posted April 20, 2015 One thing that I have noticed is that the Android app doesn't handle audio streams intelligently. I have a number of videos encoded h264 with an AC3 stream and an AAC stream. [daniel@Iron-Man ~]$ ffprobe /data/TV-Shows/MASH/Season\ 01/M-A-S-H\ -\ S01E01\ -\ M-A-S-H\ the\ Pilot.mkv ffprobe version 2.6.1 Copyright (c) 2007-2015 the FFmpeg developers built with gcc 4.9.2 (GCC) 20150304 (prerelease) configuration: --prefix=/usr --disable-debug --disable-static --disable-stripping --enable-avisynth --enable-avresample --enable-fontconfig --enable-gnutls --enable-gpl --enable-libass --enable-libbluray --enable-libfreetype --enable-libfribidi --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-libschroedinger --enable-libspeex --enable-libssh --enable-libtheora --enable-libv4l2 --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libxvid --enable-runtime-cpudetect --enable-shared --enable-swresample --enable-vdpau --enable-version3 --enable-x11grab libavutil 54. 20.100 / 54. 20.100 libavcodec 56. 26.100 / 56. 26.100 libavformat 56. 25.101 / 56. 25.101 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 11.102 / 5. 11.102 libavresample 2. 1. 0 / 2. 1. 0 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100 Input #0, matroska,webm, from '/data/TV-Shows/MASH/Season 01/M-A-S-H - S01E01 - M-A-S-H the Pilot.mkv': Metadata: title : M*A*S*H - S01E01 ENCODER : Lavf55.33.100 Duration: 00:25:34.95, start: 0.055000, bitrate: 3496 kb/s Chapter #0:0: start 0.000000, end 156.289833 Metadata: title : Chapter 01 Chapter #0:1: start 156.289833, end 369.836500 Metadata: title : Chapter 02 Chapter #0:2: start 369.836500, end 530.830667 Metadata: title : Chapter 03 Chapter #0:3: start 530.830667, end 681.648000 Metadata: title : Chapter 04 Chapter #0:4: start 681.648000, end 942.708800 Metadata: title : Chapter 05 Chapter #0:5: start 942.708800, end 1124.223467 Metadata: title : Chapter 06 Chapter #0:6: start 1124.223467, end 1229.461933 Metadata: title : Chapter 07 Chapter #0:7: start 1229.461933, end 1360.292633 Metadata: title : Chapter 08 Chapter #0:8: start 1360.292633, end 1463.061967 Metadata: title : Chapter 09 Chapter #0:9: start 1463.061967, end 1534.846322 Metadata: title : Chapter 10 Stream #0:0(eng): Video: h264 (High), yuv420p, 720x480 [SAR 8:9 DAR 4:3], 29.97 fps, 29.97 tbr, 1k tbn, 59.94 tbc Stream #0:1(eng): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s (default) Metadata: title : Stereo LANGUAGE : eng Stream #0:2(eng): Audio: aac (LC), 48000 Hz, stereo, fltp (default) Metadata: title : Stereo LANGUAGE : eng For the above file, the AC3 stream is the one chosen by the app and not the aac stream (if I remember right, it was encoded at 192 kbps so it should play without a problem). Logs: Transcode log: http://hastebin.com/igitokamim Server log: http://hastebin.com/parucudeyo Android log: On its way...
Solution Luke 42242 Posted April 20, 2015 Solution Posted April 20, 2015 we don't do that. we have no way of knowing if it's actually an alternate encoding or some kind of commentary. Instead we go by what is marked as default and the order of the streams. 1
