bradwcampbell 0 Posted April 19, 2015 Posted April 19, 2015 (edited) Continue of my own problem on the PIN Request Problem http://emby.media/community/index.php?/topic/20432-pin-request/ I have disabled Windows Firewall and etc on Server and Client. Remote Machine still can not connect to Server , yet can browse server via Web and is calling for it in the log files Restart Several times ... Reinstall of Client Several Times as well 2015-04-19 10:32:56.8288,Debug,,Attempting to wake server at address F4-6D-04-03-C5-F2,1,Application2015-04-19 10:32:56.8358,Debug,,Wake command sent,1,Application2015-04-19 10:32:56.8488,Debug,,=========System looking for assembly: System.Data.SQLite,, Version=1.0.61.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1,Application2015-04-19 10:32:56.8493,Info,,System.Data.SQLite,, Version=1.0.61.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139 is being resolved to System.Data.SQLite,, Version=1.0.88.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1,Application2015-04-19 10:32:56.8543,Info,,==========Using new SQL Repo========,1,Application2015-04-19 10:32:57.0373,Info,,Playstate initialization took 0.00 seconds.,1,Application2015-04-19 10:32:57.0698,Info,,Successfully loaded fastload data for : C:\ProgramData\MediaBrowser-Classic\Cache\playstate MediaBrowser.Library.Entities.PlaybackStatus,13,Worker thread for FastLoadLoader2015-04-19 10:32:57.0893,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\strings-en.xml,1,Application2015-04-19 10:32:57.0983,Info,,Total Kernel Init took 0.28 seconds.,1,Application2015-04-19 10:32:57.1313,Info,,Information DisplayText: Welcome to Media Browser,1,Application2015-04-19 10:32:57.1368,Info,,Finished validating : C:\ProgramData\MediaBrowser-Classic\Cache\playstate MediaBrowser.Library.Entities.PlaybackStatus,13,Worker thread for FastLoadLoader2015-04-19 10:32:57.1368,Info,,Dictionary loading and validation took 0.10 seconds.,13,Worker thread for FastLoadLoader2015-04-19 10:32:57.1483,Info,,Media Browser (version 3.0.264.0 ) Starting up.,1,Application2015-04-19 10:32:57.1483,Info,,Startup parameters: ,1,Application2015-04-19 10:32:57.1643,Debug,,Having to get media experience by reflection due to bug in Windows 7,1,Application2015-04-19 10:32:57.1653,Debug,,GetMediaExperienceUsingReflection was unsuccessful,1,Application server-63565036824.log MBClassic-19420152fda64b9851b47a49647caa872bcdebb.txt Edited April 19, 2015 by bradwcampbell
ebr 16334 Posted April 19, 2015 Posted April 19, 2015 Maybe UDP is not working in your environment for some reason. Try editing that config file you posted and putting False for find server automatically and entering the IP address for the server in ServerAddress. Make sure to remove any whitespace or line feeds so it looks like: <ServerAddress>192.168.1.10</ServerAddress>
