defiance77 9 Posted April 19, 2015 Posted April 19, 2015 Hello everybody. I already reported this by PM to null_pointer and xnappo, but as per request I will now post this on the forum in case it may be helpful to someone else. As of version 0.25 of the plugin I started having problems with the plugin. On Kodi startup I was always getting "Emby: Script failed" New episodes was not getting picked up New series was not getting picked up Watched state was not gettig synced. To try to resolve this I tried a number of things. Reset of Kodi database from Emby settings, This never worked, Kodi hung everytime forcing me to make a hard reset. Reset of database and settings, same result as above + the fyll DB sync running afteer restart but me database not containing any TV series at all even though i saw rhe scan finding them. Uninstall and reinstall Emby plugin, both in GUI and by manually deleting the addon and addondata folders None of the above worked. Yesterday I found the problem. In my advancedsettings.xml i had the following setting. Once removed everything is working perfectly again. <hideemptyseries>true</hideemptyseries> A big thank you to all the developers involved in this amazing project. 1
Feanorean 0 Posted April 21, 2015 Posted April 21, 2015 Oh my god! I have spent far too long trying to figure this out - even wiped the install, and then no TV Shows were picked up at all. Of course, I had just dropped in my standard advancedsettings.xml without even thinking about it.... This solved it in seconds - thank you, thank you, thank you!
xnappo 1611 Posted April 21, 2015 Posted April 21, 2015 Sorry guys - I actually recommended playing with that setting in another thread No idea why it would cause that - but good find!
