Njcki 1 Posted April 16, 2015 Posted April 16, 2015 Hi, today I had this error with auto-organize. Maybe it's because of "[" and "]"? Log: 2015-04-16 18:22:16.1494 Error - FileOrganizationService: Failed to move file from /home/<myusername>/<mydownloaddir>/TV temp/The.Mentalist.S07E05.WEB-DLMux.H264.Ita Eng Aac.Sub Ita Eng[BlackBit]mutu_1980/The.Mentalist.S07E05.WEB-DLMux.H264.Ita Eng Aac.Sub Ita Eng[BlackBit]mutu_1980.mp4 to /home/<myusername>/<mydownloaddir>/TV/The Mentalist/S07/The Mentalist - 7x05 - La valigetta d'argento.mp4 *** Error Report *** Version: 3.0.5582.0 Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -programdata /var/lib/mediabrowser Operating system: Unix 3.13.0.46 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/mediabrowser Mono: 3.12.1 (tarball Fri Mar 6 19:12:47 UTC 2015) Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe Access to the path is denied. System.UnauthorizedAccessException at System.IO.File.Move (System.String sourceFileName, System.String destFileName) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.FileOrganization.EpisodeFileOrganizer.PerformFileSorting (MediaBrowser.Model.FileOrganization.TvFileOrganizationOptions options, MediaBrowser.Model.FileOrganization.FileOrganizationResult result) [0x00000] in <filename unknown>:0 Thanks
Luke 42242 Posted April 16, 2015 Posted April 16, 2015 no i don't see any problems there. it appears to be out of our control. we try to save, your system says no.
thefirstofthe300 292 Posted April 16, 2015 Posted April 16, 2015 (edited) It's a permissions issue. Have you made sure that emby or the group emby running as has permission to access read and write to either the auto-organize directory or the output directory Edited April 16, 2015 by DaBungalow
Njcki 1 Posted April 16, 2015 Author Posted April 16, 2015 You're right! Problem solved. I had to add write permission to others. Thanks 1
