Sammy 791 Posted November 14, 2013 Posted November 14, 2013 I am on server Version 3.0.5061.25570 and my library is not showing on any of my clients. I am using UNC path convention and didn't have any problems until the server update. Now I cannot use Media Browser..
Luke 42287 Posted November 15, 2013 Posted November 15, 2013 is it in the middle of the first-time scan after the update? if so just wait it out. we'll improve it soon so that this doesn't happen.
gthrift 66 Posted November 15, 2013 Posted November 15, 2013 Which clients are you trying? Post logs for the devs and give us some detail about your setup.
Sammy 791 Posted November 15, 2013 Author Posted November 15, 2013 MBC and Android clients. It is on the server end. Can I get the logs when I log into the server using my public IP address and port from a remote location?
ebr 16354 Posted November 15, 2013 Posted November 15, 2013 You say your library doesn't show up. What does show up on the clients? What do you see in the web client?
Sammy 791 Posted November 15, 2013 Author Posted November 15, 2013 How to log into the web client? From MBC I get nothing at all showing.
ebr 16354 Posted November 15, 2013 Posted November 15, 2013 How to log into the web client? Click the MB icon in the upper left of the dashboard, or select "Browse Library..." from the context menu on the tray icon of the server. From MBC I get nothing at all showing. What is "nothing at all"? Your screen goes black? I doubt that is the case. In order for us to help we need very specific information about what is happening. Pictures are an excellent way to provide this.
Solution ebr 16354 Posted November 15, 2013 Solution Posted November 15, 2013 Are you sure the user you are logged in as actually has access to a library? Can you please post a server log from when you brought up that web client screen.
Sammy 791 Posted November 15, 2013 Author Posted November 15, 2013 I am trying to access it now via RDP. I am at work.
Sammy 791 Posted November 15, 2013 Author Posted November 15, 2013 I got it now. For some reason, the "Use Default Library" check box was unchecked.. Whew.. IDK how that happened but thanks for the help. I was panicking!
