CBers 7542 Posted April 5, 2015 Posted April 5, 2015 Hi Luke. Since the last update an hour ago, my library scan is stuck a ~27%. When I look in the server log, there are tons of the following errors: 2015-04-05 17:50:52.1368 Error - App: Error sending web socket message ScheduledTasksInfo *** Error Report *** Version: 3.0.5573.17762 Command line: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Value cannot be null. System.ArgumentNullException at System.Threading.Monitor.ReliableEnter(Object obj, Boolean& lockTaken) at System.Threading.SemaphoreSlim.<WaitUntilCountOrTimeoutAsync>d__3.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Net.BasePeriodicWebSocketListener`2.<SendData>d__d.MoveNext() 2015-04-05 17:50:52.1368 Info - App: ScheduledTasksWebSocketListener stop transmitting over websocket to 192.168.1.9:42250 2015-04-05 17:50:52.1368 Error - App: Error sending web socket message ScheduledTasksInfo *** Error Report *** Version: 3.0.5573.17762 Command line: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Value cannot be null. System.ArgumentNullException at System.Threading.Monitor.ReliableEnter(Object obj, Boolean& lockTaken) at System.Threading.SemaphoreSlim.<WaitUntilCountOrTimeoutAsync>d__3.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Net.BasePeriodicWebSocketListener`2.<SendData>d__d.MoveNext() 2015-04-05 17:50:52.1368 Info - App: ScheduledTasksWebSocketListener stop transmitting over websocket to 192.168.1.9:42250 2015-04-05 17:50:52.1368 Error - App: Error sending web socket message ScheduledTasksInfo *** Error Report *** Version: 3.0.5573.17762 Command line: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Value cannot be null. System.ArgumentNullException at System.Threading.Monitor.ReliableEnter(Object obj, Boolean& lockTaken) at System.Threading.SemaphoreSlim.<WaitUntilCountOrTimeoutAsync>d__3.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Net.BasePeriodicWebSocketListener`2.<SendData>d__d.MoveNext() 2015-04-05 17:50:52.1368 Info - App: ScheduledTasksWebSocketListener stop transmitting over websocket to 192.168.1.9:42250 2015-04-05 17:50:52.1368 Error - App: Error sending web socket message ScheduledTasksInfo *** Error Report *** Version: 3.0.5573.17762 Command line: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Value cannot be null. System.ArgumentNullException at System.Threading.Monitor.ReliableEnter(Object obj, Boolean& lockTaken) at System.Threading.SemaphoreSlim.<WaitUntilCountOrTimeoutAsync>d__3.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Net.BasePeriodicWebSocketListener`2.<SendData>d__d.MoveNext() 2015-04-05 17:50:52.1368 Info - App: ScheduledTasksWebSocketListener stop transmitting over websocket to 192.168.1.9:42250 2015-04-05 17:50:52.1368 Error - App: Error sending web socket message ScheduledTasksInfo *** Error Report *** Version: 3.0.5573.17762 Command line: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Value cannot be null. System.ArgumentNullException at System.Threading.Monitor.ReliableEnter(Object obj, Boolean& lockTaken) at System.Threading.SemaphoreSlim.<WaitUntilCountOrTimeoutAsync>d__3.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Net.BasePeriodicWebSocketListener`2.<SendData>d__d.MoveNext() 2015-04-05 17:50:52.1368 Info - App: ScheduledTasksWebSocketListener stop transmitting over websocket to 192.168.1.9:42250 Any ideas please, as nothing has changed my side aprt from the server update. Server log here. Thanks.
CBers 7542 Posted April 5, 2015 Author Posted April 5, 2015 I thought it might have been the Trakt plugin as it had errors as well: 2015-04-05 19:03:24.1798 Error - App: Error getting response from https://api-v2launch.trakt.tv/auth/login *** Error Report *** Version: 3.0.5573.17762 Command line: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe The remote server returned an error: (400) Bad Request. System.Net.WebException at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) 2015-04-05 19:03:24.2358 Info - App: HttpClientManager POST: https://api-v2launch.trakt.tv/auth/login 2015-04-05 19:03:24.3368 Error - App: Error getting response from https://api-v2launch.trakt.tv/auth/login *** Error Report *** Version: 3.0.5573.17762 Command line: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe The remote server returned an error: (400) Bad Request. System.Net.WebException at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) 2015-04-05 19:03:24.6438 Error - App: Error getting response from https://api-v2launch.trakt.tv/auth/login *** Error Report *** Version: 3.0.5573.17762 Command line: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe The remote server returned an error: (400) Bad Request. System.Net.WebException at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) I have now removed that plugin, but the scan media library is still stuck at ~27%. HELP !?!?!?
CBers 7542 Posted April 5, 2015 Author Posted April 5, 2015 <rant> OK, this is Photos related AGAIN !! I have removed my Photos library and the scan completed successfully. Ever since ImageMagick was introduced, it's done nothing but cause problems working with my Photos library, which have been in MediaBrowser3 since day 1 !! On Luke's advice, I had removed problem folders that caused the library scan to stick on previous dev releases and didn't have any issues until today. Can we please go back to the previous image provider as there were never any issues with that. I now do not have any Photos in my server, which I am not best pleased about. I do not have the time to pick through all of the folders again, so something needs to be identified with the server build and put right. Sorry for the rant, but not happy !! </rant>
CBers 7542 Posted April 5, 2015 Author Posted April 5, 2015 Same issue with mine to. Glad it's not just me then.
CBers 7542 Posted April 5, 2015 Author Posted April 5, 2015 OK, I have updated my development system to the latest beta (v3.0.5572.0), and the exact same content as my production server, and the library scan completes without issue. So, something is definitely broken in v3.0.5573.17762. It was OK BEFORE the latest dev build as well.
CBers 7542 Posted April 5, 2015 Author Posted April 5, 2015 Is this a Windows 7 v Windows 8 issue? I'm on W7. @@skynet600?
sydlexius 298 Posted April 6, 2015 Posted April 6, 2015 Win 7/amd64 here. Mine sticks on photos as well.
skynet600 33 Posted April 6, 2015 Posted April 6, 2015 This is resolved with the last release for me. Scan now completes.
CBers 7542 Posted April 6, 2015 Author Posted April 6, 2015 (edited) Was just about to post that mine still gets stuck at the same point on v3.0.5573.41025. The beta is still working fine. . Edited April 6, 2015 by CBers
CBers 7542 Posted April 6, 2015 Author Posted April 6, 2015 (edited) @@Luke - do you have any idea what's wrong please? This only started happening yesterday after the dev build was released. Something is definitely wrong with the photo provider as up to that release, everything that I had validated as working since it all went wrong a couple of weeks ago, was working fine. This is the last photo provider info in the log, at which point the scan sticks without progressing further: 2015-04-06 09:59:14.0661 Debug - App: Running PhotoAlbumImageProvider for \\MEDIASERVER-3\Photos\2005\05. May - 2005\Chatham Dockyard 2015-04-06 09:59:14.0731 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2005\05. May - 2005\Chatham Dockyard\28052010179.jpgAs I have repeatedly stated, ALL of my photos were in MB and working OK before you implemented ImageMagick. Please give this some of your time as this is very frustrating. Thanks. . Edited April 6, 2015 by CBers
CBers 7542 Posted April 6, 2015 Author Posted April 6, 2015 (edited) So is this a time out in the HTTPCONNECTION routine ?? 2015-04-06 10:32:30.5503 Debug - App: Running FolderXmlProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003 2015-04-06 10:32:30.5573 Debug - App: FolderXmlProvider returned no metadata for \\MEDIASERVER-3\Photos\2003\08. August - 2003 2015-04-06 10:32:30.5573 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003 to database. 2015-04-06 10:32:30.5573 Debug - App: Running PhotoAlbumImageProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th 2015-04-06 10:32:30.5573 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th to database. 2015-04-06 10:32:30.5913 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01387.JPG 2015-04-06 10:32:31.1133 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01387.JPG to database. 2015-04-06 10:32:31.1253 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01361.JPG 2015-04-06 10:32:31.2133 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01361.JPG to database. 2015-04-06 10:32:31.2133 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01366.JPG 2015-04-06 10:32:31.2773 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01366.JPG to database. 2015-04-06 10:32:31.2773 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01363.JPG 2015-04-06 10:32:31.3133 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01363.JPG to database. 2015-04-06 10:32:31.3283 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01368.JPG 2015-04-06 10:32:31.3643 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01368.JPG to database. 2015-04-06 10:32:31.3663 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01365.JPG 2015-04-06 10:32:31.4003 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01365.JPG to database. 2015-04-06 10:32:31.4003 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01372.JPG 2015-04-06 10:32:31.4523 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01372.JPG to database. 2015-04-06 10:32:31.4793 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01364.JPG 2015-04-06 10:32:31.5133 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01364.JPG to database. 2015-04-06 10:32:31.5253 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01375.JPG 2015-04-06 10:32:31.5603 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01375.JPG to database. 2015-04-06 10:32:31.5603 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01362.JPG 2015-04-06 10:32:31.5883 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01362.JPG to database. 2015-04-06 10:32:31.5883 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01373.JPG 2015-04-06 10:32:31.6323 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01373.JPG to database. 2015-04-06 10:32:31.6323 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01383.JPG 2015-04-06 10:32:31.6783 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01383.JPG to database. 2015-04-06 10:32:31.6783 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01379.JPG 2015-04-06 10:32:31.7133 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01379.JPG to database. 2015-04-06 10:32:31.7133 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01369.JPG 2015-04-06 10:32:31.7503 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01369.JPG to database. 2015-04-06 10:32:31.7763 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01380.JPG 2015-04-06 10:32:31.8173 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01380.JPG to database. 2015-04-06 10:32:31.8193 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01378.JPG 2015-04-06 10:32:31.8543 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01378.JPG to database. 2015-04-06 10:32:31.8543 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01391.JPG 2015-04-06 10:32:31.9023 Debug - App: Saving \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01391.JPG to database. 2015-04-06 10:32:31.9214 Debug - App: Running PhotoProvider for \\MEDIASERVER-3\Photos\2003\08. August - 2003\Peggy's 70th\DCP01388.JPG 2015-04-06 10:34:26.9339 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: f52881c737b049dbb2ad424917a53507 2015-04-06 10:34:26.9339 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 33489c8aa4304b5a8eea99533e56eaac 2015-04-06 10:34:36.9345 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 5296227307ea4526a8e870f992fd4d10 2015-04-06 10:34:36.9345 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 376a5632f5854afe8d836f658f17578a 2015-04-06 10:35:46.9345 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: bd35739fdff7407e9052c27a7476d3a4 2015-04-06 10:35:46.9345 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 326fb9dd0585491c83d2ecca57717c8d 2015-04-06 10:37:31.6735 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: a8c6e659ada946518d9dc844e0ec0543 2015-04-06 10:37:34.1606 Debug - HttpServer: HTTP DELETE http://192.168.1.140:8096/mediabrowser/Library/VirtualFolders/Paths?refreshLibrary=true&path=%5C%5CMEDIASERVER-3%5CPhotos%5C2003&name=Photos Ip: 192.168.1.102:51363. Headers: Host=192.168.1.140:8096,Connection=keep-alive,Accept=*/*,X-MediaBrowser-Token=131716b7e15240adb323d73b469f0f04,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/40.0.2214.115 Safari/537.36,Authorization=MediaBrowser Client="Dashboard", Device="Chrome 40.0.2214.115", DeviceId="36f13a0f5ac6d9b2c499c0648270afd6552071d2", Version="3.0.5572.0", UserId="fe8e98c1df54d9b502474bab46ee8982",Origin=http://192.168.1.140:8096,DNT=1,Accept-Encoding=gzip, deflate, sdch,Accept-Language=en-GB,en;q=0.8 2015-04-06 10:37:34.1686 Debug - HttpServer: HTTP Response 204 to 192.168.1.102. Response time: 8.0005 ms. Url: http://192.168.1.140:8096/mediabrowser/Library/VirtualFolders/Paths?refreshLibrary=true&path=%5C%5CMEDIASERVER-3%5CPhotos%5C2003&name=Photos These messages always seem to appear as the scan hangs. . Edited April 6, 2015 by CBers
CBers 7542 Posted April 7, 2015 Author Posted April 7, 2015 Following the recent update, I checked the logs and the only references to the SCAN MEDIA LIBRARY were as follows: 2015-04-07 02:02:57.6497 Info - App: Attempting to cancel Scheduled Task Scan media library 2015-04-07 06:20:34.4598 Debug - App: Scan media library: Cancelling 2015-04-07 06:20:34.4598 Debug - App: Scan media library: Waiting on Task 2015-04-07 06:20:36.4599 Debug - App: Scan media library: Timed out waiting for task to stop 2015-04-07 06:20:36.4599 Debug - App: Scan media library: Disposing CancellationToken As you can see, the library scan never finishes.
Beardyname 199 Posted April 7, 2015 Posted April 7, 2015 (edited) To add to this, This started to happen to me as well (see image for last log line mentioning the scan) And it also always stalls at the same % with this line Included in the picture is the content of said folder, Should i add anything else? (I noticed last night there was an update to imagemagic, I'm simply wondering if EMBY is trying to get the info from the folder and not from an image) The path added to the library for pictures is 192.168.1.16\blandat\Pictures And this path is a folder in a folder, Will try moving them up a level and see if that fixes it! ' *edit* Lifted up said folders and it got through that part on the next scan, stuck on some other folders - rinse and repeat (My images is a mess) But doing this a couple of times It ran through without a hitch, could it be that we have folders in our folders and it's trying to get image information from a folder and not the image itself? @@CBers could it be that you have folders in folders as well?(mixed with images on certain levels) @@Luke with this added information are you able to duplicate the behavior? Edited April 7, 2015 by Beardyname
CBers 7542 Posted April 7, 2015 Author Posted April 7, 2015 How many folders/Photos do you have @@Beardyname. I'm wondering if it's timing out traversing the folder structure, although if I go into my Photos library in EMBY, I believe they're all there, just not sure in what state.
CBers 7542 Posted April 7, 2015 Author Posted April 7, 2015 I have my Photos arranged thus. Photos/Year/Month/Event At all levels there could be videos and/or photos.
Beardyname 199 Posted April 7, 2015 Posted April 7, 2015 (edited) How many folders/Photos do you have @@Beardyname. I'm wondering if it's timing out traversing the folder structure, although if I go into my Photos library in EMBY, I believe they're all there, just not sure in what state. Around 4k in no particular order But mine ran through just fine after lifting it up to only photos_location/Foldername/ <- bunch of images goes here Lets see if luke can make out something with this new information! Edited April 7, 2015 by Beardyname
CBers 7542 Posted April 7, 2015 Author Posted April 7, 2015 I have over 22,000 photos, in order error 250 sub and sub/sub folders etc. Too many to reorganise. I tried cutting them down by only had a few at a time, but it was still failing.
Beardyname 199 Posted April 7, 2015 Posted April 7, 2015 (edited) Yep I do think multiple folder levels should be supported, but until we can make sure this is actually what's causing the problem i would recommend against moving your structure! *edit* I'm wondering it it has to do with that awesome new dynamic image thing for folders/groups in combination with folders in a folder depth. Edited April 7, 2015 by Beardyname 1
CBers 7542 Posted April 7, 2015 Author Posted April 7, 2015 @@Beardyname - it all started going wrong when ImageMagick was introduced. Up until then, I'd never had an issue.
jabbera 23 Posted April 7, 2015 Posted April 7, 2015 I'm looking into the memory management of the imagemagick stuff. Found some leaks already but nothing that I would expect to corrupt memory like you are seeing. What plugins do you use? Can you try removing them all if you use any and report back.
CBers 7542 Posted April 8, 2015 Author Posted April 8, 2015 I have several. Auto BoxSets Rotten Tomatoes Cover Art Email Notifications Server Backup Trailers I'll try tonight when I'm home.
CBers 7542 Posted April 8, 2015 Author Posted April 8, 2015 @@jabbera - I've removed all plugins, but the library scan still hangs.
CBers 7542 Posted April 8, 2015 Author Posted April 8, 2015 @@jabbera - I've now updated to the Beta release of the server, but it still hangs around the same point.
