heula 192 Posted November 14, 2013 Posted November 14, 2013 When I change things in Coverart I noticed it will not always be updated even after multiple library refreshes. For testing I changed my thumb and episode overlay but it will not be changed. For episodes that is the case in ROC and NEO and for thumbs only Roc doesn't update like it seems. https://dl.dropboxusercontent.com/u/901529/Media%20Browser/MB3/Coverart%20not%20updating%201.log https://dl.dropboxusercontent.com/u/901529/Media%20Browser/MB3/Coverart%20not%20updating%202.log
ebr 16342 Posted November 14, 2013 Posted November 14, 2013 The first one looks like it is a collection item which has its own treatment style. On the second, are you sure it is within the proper profile?
heula 192 Posted November 14, 2013 Author Posted November 14, 2013 The first one looks like it is a collection item which has its own treatment style. On the second, are you sure it is within the proper profile? The first is my own created thumb.jpg and the red bars must show that it has been treated as film once. That was the case till I changed it to border today. The film treatment is still there and is not updated. Yes Im sure. Beauty and the beast is in Series Alex folder.
ebr 16342 Posted November 14, 2013 Posted November 14, 2013 I can't reproduce any of this so I will need to see a server log in debug mode when you make a change to a treatment and then bring that item up in a client for viewing (the web client will work).
heula 192 Posted November 14, 2013 Author Posted November 14, 2013 I can't reproduce any of this so I will need to see a server log in debug mode when you make a change to a treatment and then bring that item up in a client for viewing (the web client will work). https://dl.dropboxusercontent.com/u/901529/Media%20Browser/MB3/server-Coverart%20not%20updating%201.log https://dl.dropboxusercontent.com/u/901529/Media%20Browser/MB3/server-Coverart%20not%20updating%202.log
ebr 16342 Posted November 15, 2013 Posted November 15, 2013 There is a massive library scan and a lot of changes happening to your file system during that log but CoverArt was never called to process anything other than the configuration. Is it possible for you to create this situation without all of that other stuff going on? Plus, be sure you actually make a change to the configuration. Don't just change it to one thing and then change it right back because that will cause the images to still be pulled from the cache. You need to do something that is truly different for CA to re-process.
Luke 42252 Posted November 15, 2013 Posted November 15, 2013 There is a bug in the current server that will be fixed in the next release. If an image is requested using entirely default settings - no width or height values specified, then the original file is served as an optimization to avoid gdi processing. But it also needs to check if there are any image enhancers and that's what the current release is not doing. It's fixed and will be in the next one.
ebr 16342 Posted November 15, 2013 Posted November 15, 2013 There is a bug in the current server that will be fixed in the next release. If an image is requested using entirely default settings - no width or height values specified, then the original file is served as an optimization to avoid gdi processing. But it also needs to check if there are any image enhancers and that's what the current release is not doing. It's fixed and will be in the next one. That sounds like a doozy but all MBC image requests do contain the MaxWidth parameter...
Luke 42252 Posted November 15, 2013 Posted November 15, 2013 There are also new optimizations if the size falls within the max values requested. I'll review that. Could be a bug there.
heula 192 Posted November 15, 2013 Author Posted November 15, 2013 Does this mean I have to do nothing cause there is bug that is causing this?
ebr 16342 Posted November 15, 2013 Posted November 15, 2013 Does this mean I have to do nothing cause there is bug that is causing this? It sounds that way.
smounche 0 Posted November 15, 2013 Posted November 15, 2013 Having the same issue here.. i'm just adding movies to my movies folder.. and it won't update coverart..
