saitoh183 137 Posted April 13, 2015 Posted April 13, 2015 My friend is trying to watch a movie(jap language) from his house via Connect on my server and is unable get the english subs to work. Its a mkv with embedded subs. Could this be because of the transcoding since external srt work? and if so, is this a limitation or bug that needs fixing? server 3.0.5572.0
Luke 42184 Posted April 13, 2015 Posted April 13, 2015 Please see http://emby.media/community/index.php?/topic/790-how-to-report-a-problem/
saitoh183 137 Posted April 13, 2015 Author Posted April 13, 2015 Please see http://emby.media/community/index.php?/topic/790-how-to-report-a-problem/ I know how to report a problem but im asking a question before i go through the process of reproducing the problem since i will have to contact the person and have him play stuff so i can log it
Blob 7 Posted April 13, 2015 Posted April 13, 2015 http://emby.media/community/index.php?/topic/15506-subtitles-in-webclient/ Could it be the same.... Still present in current version for my setup. I will encourage you to do the required work and spend some time from your own side so the helpers can see if its the same Then it would probrally get fixed some day I wish you the best. Regards.
saitoh183 137 Posted April 13, 2015 Author Posted April 13, 2015 http://emby.media/community/index.php?/topic/15506-subtitles-in-webclient/ Could it be the same.... Still present in current version for my setup. I will encourage you to do the required work and spend some time from your own side so the helpers can see if its the same Then it would probrally get fixed some day I wish you the best. Regards. Thanks, That is what i wanted to know before i proceed in doing the work.
Luke 42184 Posted April 13, 2015 Posted April 13, 2015 If you want your issue resolved then always do the work as they are quite possibly unrelated.
