hey guys i know this may sound lazy, but is there a way that you can add double click on the try icon open the Emby main config page, i know you can righ click and click config and it will do the job, but i belive is more easy just double click on the try icon
thanks in advanced
yes, it's a good idea
Koleckai Silvestri
I just opened the page in Google Chrome. Then on Chrome's menu went to More Tools -> Create Application Shortcuts. Now I have it directly on my desktop and taskbar as an icon. Only drawback is that Chrome's chrome disappears and Emby's Web client doesn't have its own full navigation.
Could be a work around until the above is implemented.
thanks luke :)
