Nikolaech 32 Posted May 7, 2015 Posted May 7, 2015 (edited) Does it work as simple as that with dvbviewer? That makes my tbs 6984 a network tuner.. If it does this is a big deal for me!!!! The best solution today MBS + Kodi + DVBViewer PVR client addon for Kodi + 1080XF MediaBrowser Edition (Helix Only) support Logo, EPG, CPU 10...30%. The image quality is good EmbyTV a livetv client for Network Tuners (HDHomerun at the moment) + Regservice (DVBViewer) - works, but, no support Logo, EPG, CPU 50..100% Videobookmarks (IP-TV) +Regservice (DVBViewer) - works, but, no support Logo, EPG, CPU 50..100% Edited May 7, 2015 by Nikolaech
Lee 212 Posted May 7, 2015 Posted May 7, 2015 The best solution today MBS + Kodi + DVBViewer PVR client addon for Kodi + 1080XF MediaBrowser Edition (Helix Only) support Logo, EPG, CPU 10...30%. The image quality is good EmbyTV a livetv client for Network Tuners (HDHomerun at the moment) + Regservice (DVBViewer) - works, buts, no support Logo, EPG, CPU 50..100% Videobookmarks (IP-TV) +Regservice (DVBViewer) - works, buts, no support Logo, EPG, CPU 50..100% I'm going to try kodi again.. It kept crashing when I tried it last. It was an early beta tho tbf
Nikolaech 32 Posted May 7, 2015 Posted May 7, 2015 pictures I do not speak English. Your computer's network settings, adjust manually. The plugin settings. the result Should run well.
mediacowboy 438 Posted May 9, 2015 Posted May 9, 2015 (edited) @@jose, I think I may have figured out my issue. I think it is related to the CPU and ffmpeg. If I try streaming with the processor maxed out it fails.I am running 2 HDHR3-CC. I think this is the error. Sorry about all the other stuff that may be in it. The kids are watching stuff in the other room's *** Error Report *** Version: 3.0.5597.1 Command line: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe The process cannot access the file 'C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm' because it is being used by another process. System.IO.IOException at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.File.InternalDelete(String path, Boolean checkHost) at System.IO.File.Delete(String path) at MediaBrowser.Common.Implementations.IO.CommonFileSystem.DeleteFile(String path) at MediaBrowser.Api.ApiEntryPoint.<DeletePartialStreamFiles>d__30.MoveNext() 2015-05-09 17:32:12.3271 Info - App: Deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm 2015-05-09 17:32:12.4352 Debug - HttpServer: HTTP POST http://XXX.XXX.XXX.50:8096/mediabrowser/Sessions/Playing/Progress?itemId=19f40037007a986f26054535b3a95187&PositionTicks=5650000000&isPaused=false&canSeek=true&PlayMethod=DirectStream&QueueableMediaTypes=Video&MediaSourceId=19f40037007a986f26054535b3a95187&AudioStreamIndex=1 Ip: XXX.XXX.XXX.100:60501. Headers: User-Agent=Roku/DVP-6.2 (046.02E03332A),Host=XXX.XXX.XXX.50:8096,Accept=*/*,Accept-Encoding=deflate, gzip,Authorization=MediaBrowser Client="Roku", Device="Roku 3", DeviceId="1GS3DY024781", Version="1.96", UserId="0218ea92a5444af50bd0a770060a215e",X-MediaBrowser-Token=5a79c5a2d4064a918ad15d886726b734,Content-Length=0,Content-Type=application/x-www-form-urlencoded 2015-05-09 17:32:12.4352 Debug - HttpServer: HTTP Response 204 to XXX.XXX.XXX.100. Response time: 1.0001 ms. Url: http://XXX.XXX.XXX.50:8096/mediabrowser/Sessions/Playing/Progress?itemId=19f40037007a986f26054535b3a95187&PositionTicks=5650000000&isPaused=false&canSeek=true&PlayMethod=DirectStream&QueueableMediaTypes=Video&MediaSourceId=19f40037007a986f26054535b3a95187&AudioStreamIndex=1 2015-05-09 17:32:12.8252 Error - App: Error deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm *** Error Report *** Version: 3.0.5597.1 Command line: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe The process cannot access the file 'C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm' because it is being used by another process. System.IO.IOException at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.File.InternalDelete(String path, Boolean checkHost) at System.IO.File.Delete(String path) at MediaBrowser.Common.Implementations.IO.CommonFileSystem.DeleteFile(String path) at MediaBrowser.Api.ApiEntryPoint.<DeletePartialStreamFiles>d__30.MoveNext() 2015-05-09 17:32:12.8252 Info - App: Deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm 2015-05-09 17:32:13.3402 Error - App: Error deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm *** Error Report *** Version: 3.0.5597.1 Command line: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe The process cannot access the file 'C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm' because it is being used by another process. System.IO.IOException at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.File.InternalDelete(String path, Boolean checkHost) at System.IO.File.Delete(String path) at MediaBrowser.Common.Implementations.IO.CommonFileSystem.DeleteFile(String path) at MediaBrowser.Api.ApiEntryPoint.<DeletePartialStreamFiles>d__30.MoveNext() 2015-05-09 17:32:13.3402 Info - App: Deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm 2015-05-09 17:32:13.4492 Debug - HttpServer: HTTP POST http://XXX.XXX.XXX.50:8096/mediabrowser/Sessions/Playing/Progress?itemId=19f40037007a986f26054535b3a95187&PositionTicks=5660000000&isPaused=false&canSeek=true&PlayMethod=DirectStream&QueueableMediaTypes=Video&MediaSourceId=19f40037007a986f26054535b3a95187&AudioStreamIndex=1 Ip: XXX.XXX.XXX.100:60501. Headers: User-Agent=Roku/DVP-6.2 (046.02E03332A),Host=XXX.XXX.XXX.50:8096,Accept=*/*,Accept-Encoding=deflate, gzip,Authorization=MediaBrowser Client="Roku", Device="Roku 3", DeviceId="1GS3DY024781", Version="1.96", UserId="0218ea92a5444af50bd0a770060a215e",X-MediaBrowser-Token=5a79c5a2d4064a918ad15d886726b734,Content-Length=0,Content-Type=application/x-www-form-urlencoded 2015-05-09 17:32:13.4492 Debug - HttpServer: HTTP Response 204 to XXX.XXX.XXX.100. Response time: 1 ms. Url: http://XXX.XXX.XXX.50:8096/mediabrowser/Sessions/Playing/Progress?itemId=19f40037007a986f26054535b3a95187&PositionTicks=5660000000&isPaused=false&canSeek=true&PlayMethod=DirectStream&QueueableMediaTypes=Video&MediaSourceId=19f40037007a986f26054535b3a95187&AudioStreamIndex=1 2015-05-09 17:32:13.8432 Error - App: Error deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm *** Error Report *** Version: 3.0.5597.1 Command line: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe The process cannot access the file 'C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm' because it is being used by another process. System.IO.IOException at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.File.InternalDelete(String path, Boolean checkHost) at System.IO.File.Delete(String path) at MediaBrowser.Common.Implementations.IO.CommonFileSystem.DeleteFile(String path) at MediaBrowser.Api.ApiEntryPoint.<DeletePartialStreamFiles>d__30.MoveNext() 2015-05-09 17:32:13.8432 Info - App: Deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm 2015-05-09 17:32:14.3983 Error - App: Error deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm *** Error Report *** Version: 3.0.5597.1 Command line: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe The process cannot access the file 'C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm' because it is being used by another process. System.IO.IOException at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.File.InternalDelete(String path, Boolean checkHost) at System.IO.File.Delete(String path) at MediaBrowser.Common.Implementations.IO.CommonFileSystem.DeleteFile(String path) at MediaBrowser.Api.ApiEntryPoint.<DeletePartialStreamFiles>d__30.MoveNext() 2015-05-09 17:32:14.3983 Info - App: Deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm 2015-05-09 17:32:14.4463 Debug - HttpServer: HTTP POST http://XXX.XXX.XXX.50:8096/mediabrowser/Sessions/Playing/Progress?itemId=19f40037007a986f26054535b3a95187&PositionTicks=5670000000&isPaused=false&canSeek=true&PlayMethod=DirectStream&QueueableMediaTypes=Video&MediaSourceId=19f40037007a986f26054535b3a95187&AudioStreamIndex=1 Ip: XXX.XXX.XXX.100:60501. Headers: User-Agent=Roku/DVP-6.2 (046.02E03332A),Host=XXX.XXX.XXX.50:8096,Accept=*/*,Accept-Encoding=deflate, gzip,Authorization=MediaBrowser Client="Roku", Device="Roku 3", DeviceId="1GS3DY024781", Version="1.96", UserId="0218ea92a5444af50bd0a770060a215e",X-MediaBrowser-Token=5a79c5a2d4064a918ad15d886726b734,Content-Length=0,Content-Type=application/x-www-form-urlencoded 2015-05-09 17:32:14.4483 Debug - HttpServer: HTTP Response 204 to XXX.XXX.XXX.100. Response time: 2.0001 ms. Url: http://XXX.XXX.XXX.50:8096/mediabrowser/Sessions/Playing/Progress?itemId=19f40037007a986f26054535b3a95187&PositionTicks=5670000000&isPaused=false&canSeek=true&PlayMethod=DirectStream&QueueableMediaTypes=Video&MediaSourceId=19f40037007a986f26054535b3a95187&AudioStreamIndex=1 2015-05-09 17:32:14.7973 Debug - HttpServer: HTTP POST http://XXX.XXX.XXX.50:8096/mediabrowser/Sessions/Playing/Progress Ip: XXX.XXX.XXX.146:50029. Headers: X-MediaBrowser-Token=ceb3015d7006411fa5058a68b2d3a898,Authorization=MediaBrowser Client="AndroidTv", DeviceId="532bc3993b7c7ae4", Device="Amazon AFTM", Version="1.0.33a", UserId="0218ea92a5444af50bd0a770060a215e",Content-Type=application/json,User-Agent=Dalvik/1.6.0 (Linux; U; Android 4.2.2; AFTM Build/JDQ39),Host=XXX.XXX.XXX.50:8096,Connection=Keep-Alive,Accept-Encoding=gzip,Content-Length=149 2015-05-09 17:32:14.7973 Debug - HttpServer: HTTP Response 204 to XXX.XXX.XXX.146. Response time: 2.0001 ms. Url: http://XXX.XXX.XXX.50:8096/mediabrowser/Sessions/Playing/Progress 2015-05-09 17:32:14.9033 Error - App: Error deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm *** Error Report *** Version: 3.0.5597.1 Command line: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe The process cannot access the file 'C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm' because it is being used by another process. System.IO.IOException at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.File.InternalDelete(String path, Boolean checkHost) at System.IO.File.Delete(String path) at MediaBrowser.Common.Implementations.IO.CommonFileSystem.DeleteFile(String path) at MediaBrowser.Api.ApiEntryPoint.<DeletePartialStreamFiles>d__30.MoveNext() 2015-05-09 17:32:14.9033 Info - App: Deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm 2015-05-09 17:32:15.4103 Error - App: Error deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm *** Error Report *** Version: 3.0.5597.1 Command line: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe The process cannot access the file 'C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm' because it is being used by another process. System.IO.IOException at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.File.InternalDelete(String path, Boolean checkHost) at System.IO.File.Delete(String path) at MediaBrowser.Common.Implementations.IO.CommonFileSystem.DeleteFile(String path) at MediaBrowser.Api.ApiEntryPoint.<DeletePartialStreamFiles>d__30.MoveNext() 2015-05-09 17:32:15.4103 Info - App: Deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm 2015-05-09 17:32:15.4443 Debug - HttpServer: HTTP POST http://XXX.XXX.XXX.50:8096/mediabrowser/Sessions/Playing/Progress?itemId=19f40037007a986f26054535b3a95187&PositionTicks=5680000000&isPaused=false&canSeek=true&PlayMethod=DirectStream&QueueableMediaTypes=Video&MediaSourceId=19f40037007a986f26054535b3a95187&AudioStreamIndex=1 Ip: XXX.XXX.XXX.100:60501. Headers: User-Agent=Roku/DVP-6.2 (046.02E03332A),Host=XXX.XXX.XXX.50:8096,Accept=*/*,Accept-Encoding=deflate, gzip,Authorization=MediaBrowser Client="Roku", Device="Roku 3", DeviceId="1GS3DY024781", Version="1.96", UserId="0218ea92a5444af50bd0a770060a215e",X-MediaBrowser-Token=5a79c5a2d4064a918ad15d886726b734,Content-Length=0,Content-Type=application/x-www-form-urlencoded 2015-05-09 17:32:15.4463 Debug - HttpServer: HTTP Response 204 to XXX.XXX.XXX.100. Response time: 2.0001 ms. Url: http://XXX.XXX.XXX.50:8096/mediabrowser/Sessions/Playing/Progress?itemId=19f40037007a986f26054535b3a95187&PositionTicks=5680000000&isPaused=false&canSeek=true&PlayMethod=DirectStream&QueueableMediaTypes=Video&MediaSourceId=19f40037007a986f26054535b3a95187&AudioStreamIndex=1 2015-05-09 17:32:15.9174 Error - App: Error deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm *** Error Report *** Version: 3.0.5597.1 Command line: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe The process cannot access the file 'C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm' because it is being used by another process. System.IO.IOException at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.File.InternalDelete(String path, Boolean checkHost) at System.IO.File.Delete(String path) at MediaBrowser.Common.Implementations.IO.CommonFileSystem.DeleteFile(String path) at MediaBrowser.Api.ApiEntryPoint.<DeletePartialStreamFiles>d__30.MoveNext() 2015-05-09 17:32:15.9174 Info - App: Deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm 2015-05-09 17:32:16.4224 Error - App: Error deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm *** Error Report *** Version: 3.0.5597.1 Command line: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe The process cannot access the file 'C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm' because it is being used by another process. System.IO.IOException at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.File.InternalDelete(String path, Boolean checkHost) at System.IO.File.Delete(String path) at MediaBrowser.Common.Implementations.IO.CommonFileSystem.DeleteFile(String path) at MediaBrowser.Api.ApiEntryPoint.<DeletePartialStreamFiles>d__30.MoveNext() 2015-05-09 17:32:16.4224 Info - App: Deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm 2015-05-09 17:32:16.4624 Debug - HttpServer: HTTP POST http://XXX.XXX.XXX.50:8096/mediabrowser/Sessions/Playing/Progress?itemId=19f40037007a986f26054535b3a95187&PositionTicks=5690000000&isPaused=false&canSeek=true&PlayMethod=DirectStream&QueueableMediaTypes=Video&MediaSourceId=19f40037007a986f26054535b3a95187&AudioStreamIndex=1 Ip: XXX.XXX.XXX.100:60501. Headers: User-Agent=Roku/DVP-6.2 (046.02E03332A),Host=XXX.XXX.XXX.50:8096,Accept=*/*,Accept-Encoding=deflate, gzip,Authorization=MediaBrowser Client="Roku", Device="Roku 3", DeviceId="1GS3DY024781", Version="1.96", UserId="0218ea92a5444af50bd0a770060a215e",X-MediaBrowser-Token=5a79c5a2d4064a918ad15d886726b734,Content-Length=0,Content-Type=application/x-www-form-urlencoded 2015-05-09 17:32:16.4624 Debug - HttpServer: HTTP Response 204 to XXX.XXX.XXX.100. Response time: 1.0001 ms. Url: http://XXX.XXX.XXX.50:8096/mediabrowser/Sessions/Playing/Progress?itemId=19f40037007a986f26054535b3a95187&PositionTicks=5690000000&isPaused=false&canSeek=true&PlayMethod=DirectStream&QueueableMediaTypes=Video&MediaSourceId=19f40037007a986f26054535b3a95187&AudioStreamIndex=1 2015-05-09 17:32:16.9374 Error - App: Error deleting partial stream file(s) C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm *** Error Report *** Version: 3.0.5597.1 Command line: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe The process cannot access the file 'C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\41bee9f4fba5bb718b2bb5d1800f1e90.webm' because it is being used by another process. System.IO.IOException at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.File.InternalDelete(String path, Boolean checkHost) at System.IO.File.Delete(String path) at MediaBrowser.Common.Implementations.IO.CommonFileSystem.DeleteFile(String path) at MediaBrowser.Api.ApiEntryPoint.<DeletePartialStreamFiles>d__30.MoveNext() EmbyTV.xml Edited May 9, 2015 by mediacowboy
denethor 90 Posted May 11, 2015 Posted May 11, 2015 @@denethor was this effective with dvbviewer? I'm crossing my fingers!! Yes and No. If you set your RTSP channel list xml file properly this add-on can list and stream your channels. But there are some basic staff missing; guide, channel names with spaces etc. Also transcoded streaming is not reliable -actually not working- with CAM/CI. Only FTA channels supported. Like @@Nikolaech said best setup is using Kodi add-on for DVBviewer backends. Which means no support for mobile/remote clients. 1
Lee 212 Posted May 11, 2015 Posted May 11, 2015 Cheers for that, I've got a seperate mobile app anyway for dvbviewer. Might give it a try.
mediacowboy 438 Posted May 12, 2015 Posted May 12, 2015 I think I noticed something tonight and why I might be having a lot of errors on recording and stuff failing to close properly. One of my shows finished recording and when it did I had 3 other shows recording at the same time. When that show finished and closed out it looks like maybe it killed the FFMPEG process(s) and stopped all streams. I will try to reproduce with debug logs turned on. I am also running the latest version, which at this time is, 0.10.2.0. I will keep testing but would love some feed back so I'm not losing my mind or so that I know I'm not testing for nothing.
jasonmcroy 320 Posted May 12, 2015 Posted May 12, 2015 I just tried to use the Live TV feed via the Emby app on Roku today. When I select the channel and hit play the app crashes and closes. I am not sure if you have tried this yet or not but I wanted to let you know. -Jason
mediacowboy 438 Posted May 13, 2015 Posted May 13, 2015 It also looks like firing up mutliple tuner's at once kills the ffmpeg process. Again sorry no logs but the system is actively used.
mediacowboy 438 Posted May 13, 2015 Posted May 13, 2015 (edited) What Follows is how and what I did to test: Enabled Debug mode Disabled start up task Opened three Incognito windows in Google Chrome Had one Normal windows open in Google Chrome Restart server Refreshed TV guide (14 day refresh for 255) Channels Scan was still runningOpened a stream in 1st incognito mode Did not even make it a minute before streamed died. Stopped server. Captured log's. http://paste2.org/70ewWkGZ - Transcoding Log Server log is attached in a zip as it is to be to use paste2 or attach it directly I will wait to hear back on what you find on this before I test more. Thanks @@jose and team for the work you do. Server Log.zip Edited May 13, 2015 by mediacowboy
mediacowboy 438 Posted May 13, 2015 Posted May 13, 2015 (edited) Ok I Lied. With the server started back up and still in debug mode I waited for my 9:00 PM recording to come on. At the time it did not kick off. turned off debug mode and shutdown the server. Edit: I have re enabled my normal scheduled task. server-63567060382.txt Edited May 13, 2015 by mediacowboy
johnodon 18 Posted May 13, 2015 Posted May 13, 2015 (edited) HOLD FOR NOW...I updated the firmware on my tuners and looks like I made it further. It is populating guide data now. I'll report back. Trying to get this up and running. I am able to add my tuners... However, I am seeing no Tuners and that 404 error on the main LiveTV page: Looking at the syslog (attached) I see the below (among other errors)... 2015-05-13 09:22:38.0127 Info - App: HttpClientManager POST: http://www.mb3admin.com/admin/service/package/retrieveall2015-05-13 09:22:41.3616 Info - App: ScheduledTasksWebSocketListener Begin transmitting over websocket to 192.168.1.35:647842015-05-13 09:22:41.3629 Info - App: HttpClientManager GET: http://192.168.1.7/2015-05-13 09:22:41.3698 Info - App: HttpClientManager GET: http://192.168.1.8/2015-05-13 09:22:41.4288 Info - App: HttpClientManager GET: http://192.168.1.7/tuners.html2015-05-13 09:22:41.4319 Error - App: Error getting response from http://192.168.1.7/tuners.html 2015-05-13 09:22:44.9549 Info - App: Executing Refresh Guide2015-05-13 09:22:44.9573 Info - App: HttpClientManager GET: http://192.168.1.7/2015-05-13 09:22:44.9608 Info - App: HttpClientManager GET: http://192.168.1.8/2015-05-13 09:22:45.0308 Info - EmbyTV: Start GetChannels Async, retrieve all channels for HDHR3-USDevice ID: 103DF36CFirmware: 20150319beta1-2015-05-13 09:22:45.0308 Info - App: HttpClientManager GET: http://192.168.1.7/lineup.json2015-05-13 09:22:45.0337 Error - App: Error getting response from http://192.168.1.7/lineup.json John Log.txt Edited May 13, 2015 by johnodon
mediacowboy 438 Posted May 14, 2015 Posted May 14, 2015 I may have noticed another issue with this. I had two shows set to record back to back on the same channel and it looks like it failed to start recording the second show. After I hear back on some of the other issue's I will do more testing but wanted to post this and see if anyone else has had this issue.
jose 73 Posted May 14, 2015 Author Posted May 14, 2015 It also looks like firing up mutliple tuner's at once kills the ffmpeg process. Again sorry no logs but the system is actively used. I dont know what i can do about this. I dont use ffmpeg at all , the server is the one that decides if it need to use it when you ask a stream for it, for recordings it is not used and saved in the original format.
jasonmcroy 320 Posted May 14, 2015 Posted May 14, 2015 As an update to my last post, the latest Roku app update seems to have solved the issue with Live TV crashing the app. -Jason
Jackrats 4 Posted May 18, 2015 Posted May 18, 2015 OMG, how did I just noticed this plugin? Awesome work, Jose! This is epic!Unfortunately, I'm having problems getting my Schedules Direct to download. I keep getting an Error 400 Bad Request from SD when EmbyTV tries to update. Looks like it gets a token, but there's something about the request that SD doesn't like.Unfortunately debug logging doesn't add any clarity to the request and I can't Wireshark it because it's HTTPS. 2015-05-17 23:06:33.1506 Info - EmbyTV: Start GetChannels Async, retrieve all channels for HDTC-2US-1050B951 2015-05-17 23:06:33.1506 Info - App: HttpClientManager GET: http://hdhomerun.mydomain.com/lineup.json 2015-05-17 23:06:33.2107 Info - EmbyTV: Found 33channels on host: hdhomerun.mydomain.com 2015-05-17 23:06:33.2107 Info - EmbyTV: Only Favorites?True 2015-05-17 23:06:33.2113 Info - App: HttpClientManager POST: https://json.schedulesdirect.org/20141201/token 2015-05-17 23:06:33.6590 Info - EmbyTV: Authenticated with Schedules Direct token: *redacted token* 2015-05-17 23:06:33.6591 Info - App: HttpClientManager GET: https://json.schedulesdirect.org/20141201/lineups/USA-OTA-*redacted zipcode* 2015-05-17 23:06:33.9559 Error - App: Error getting response from https://json.schedulesdirect.org/20141201/lineups/USA-OTA-*redacted zipcode* *** Error Report *** Version: 3.0.5607.2 Command line: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe -programdata /var/opt/Emby/server Operating system: Unix 3.10.0.229 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/opt/Emby/server Mono: 3.10.0 (tarball Sat Nov 15 03:35:34 UTC 2014) Application Path: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe The remote server returned an error: (400) Bad Request. System.Net.WebException at System.Net.HttpWebRequest.CheckFinalStatus (System.Net.WebAsyncResult result) [0x00000] in <filename unknown>:0 at System.Net.HttpWebRequest.SetResponseData (System.Net.WebConnectionData data) [0x00000] in <filename unknown>:0 2015-05-17 23:06:33.9561 Error - App: Error refreshing channels for service *** Error Report *** Version: 3.0.5607.2 Command line: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe -programdata /var/opt/Emby/server Operating system: Unix 3.10.0.229 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/opt/Emby/server Mono: 3.10.0 (tarball Sat Nov 15 03:35:34 UTC 2014) Application Path: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe The remote server returned an error: (400) Bad Request. MediaBrowser.Model.Net.HttpException at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[MediaBrowser.Common.Net.HttpResponseInfo].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsync>c__async1.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[MediaBrowser.Common.Net.HttpResponseInfo].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<Get>c__async0.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter`1[System.IO.Stream].GetResult () [0x00000] in <filename unknown>:0 at EmbyTV.EPGProvider.SchedulesDirect+<getChannelInfo>d__12.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter`1[System.Collections.Generic.IEnumerable`1[MediaBrowser.Controller.LiveTv.ChannelInfo]].GetResult () [0x00000] in <filename unknown>:0 at EmbyTV.LiveTvService+<GetChannelsAsync>d__2a.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[System.Collections.Generic.IEnumerable`1[MediaBrowser.Controller.LiveTv.ChannelInfo]].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager+<GetChannels>c__async14.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager+<RefreshChannelsInternal>c__async11.MoveNext () [0x00000] in <filename unknown>:0 InnerException: System.Net.WebException The remote server returned an error: (400) Bad Request. at System.Net.HttpWebRequest.CheckFinalStatus (System.Net.WebAsyncResult result) [0x00000] in <filename unknown>:0 at System.Net.HttpWebRequest.SetResponseData (System.Net.WebConnectionData data) [0x00000] in <filename unknown>:0 2015-05-17 23:06:33.9765 Info - App: Refresh Guide Completed after 0 minute(s) and 0 seconds <?xml version="1.0"?> <PluginConfiguration xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <TunerHostsConfiguration> <TunerUserConfiguration> <ServerId>HDTC-2US-1050B951</ServerId> <ServerType>HdHomeRun</ServerType> <UserFields> <UserField> <Name>Url</Name> <Value>hdhomerun.mydomain.com</Value> </UserField> <UserField> <Name>OnlyFavorites</Name> <Value>true</Value> </UserField> </UserFields> </TunerUserConfiguration> </TunerHostsConfiguration> <RecordingPath>/mnt/media/Emby/cache/temp/embytv/recordings</RecordingPath> <hashPassword>*redacted_hash*</hashPassword> <username>*redacted_username</username> <lineup> <Name>Antenna</Name> <Id>USA-OTA-*redacted_zipcode*</Id> </lineup> <zipCode>*redacted_zipcode*</zipCode> </PluginConfiguration> This is on server .5607 on Redhat 7 and 0.10.2.0 EmbyTV.
rkulagow 19 Posted May 18, 2015 Posted May 18, 2015 [i work for Schedules Direct] If you can send me your username via PM then I can pull the server-side logs and send them to Jose so that we can figure out what's happening. I'm at rkulagow@gmail.com 2
Luke 42241 Posted May 18, 2015 Posted May 18, 2015 [i work for Schedules Direct] If you can send me your username via PM then I can pull the server-side logs and send them to Jose so that we can figure out what's happening. I'm at rkulagow@gmail.com Thank you!
Jackrats 4 Posted May 18, 2015 Posted May 18, 2015 [i work for Schedules Direct] If you can send me your username via PM then I can pull the server-side logs and send them to Jose so that we can figure out what's happening. I'm at rkulagow@gmail.com Wow, incredibly awesome of you to offer to look into this! I've sent over an email. Thanks again!
rkulagow 19 Posted May 18, 2015 Posted May 18, 2015 Are you still having an issue? There was a hung process server-side which I reset this morning. Can you check if you're still having the issue, and if not, please let me know. Thanks.
Jackrats 4 Posted May 18, 2015 Posted May 18, 2015 Thanks to rkulagow and SD for awesome, proactive support! He found that there was a hung process on SD's side and my lineup was not being added. I think I'd only have 1 suggestion on the EmbyTV side however -- after the hung process was corrected, EmbyTV still wouldn't pull down data until I manually added the lineup via SD's 20141201 API. It looks like EmbyTV detected the "No lineups on account" but continued to try to pull the lineup. I think when this condition is detected via the 2101 error (to the request for the specific lineup) or the 4102 response (to the lineups list request), it should go ahead and do the PUT operation again to add it. Here you can see it trying to fetch the specific lineup even though it identified there are no lineups on the previous request: 2015-05-18 10:51:36.9138 Info - EmbyTV: Lineups on account 2015-05-18 10:51:36.9138 Info - App: HttpClientManager GET: https://json.schedulesdirect.org/20141201/lineups 2015-05-18 10:51:37.2317 Error - App: Error getting response from https://json.schedulesdirect.org/20141201/lineups *** Error Report *** Version: 3.0.5607.2 Command line: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe -programdata /var/opt/Emby/server Operating system: Unix 3.10.0.229 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/opt/Emby/server Mono: 3.10.0 (tarball Sat Nov 15 03:35:34 UTC 2014) Application Path: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe The remote server returned an error: (400) Bad Request. System.Net.WebException at System.Net.HttpWebRequest.CheckFinalStatus (System.Net.WebAsyncResult result) [0x00000] in <filename unknown>:0 at System.Net.HttpWebRequest.SetResponseData (System.Net.WebConnectionData data) [0x00000] in <filename unknown>:0 2015-05-18 10:51:37.2317 Info - EmbyTV: No lineups on account 2015-05-18 10:52:21.1575 Error - HttpServer: Error in SharpWebSocket: An exception has occurred while receiving a message.. Exception.Message: Internal error (no progr ess possible) ReadInternal 2015-05-18 10:52:21.1821 Info - App: HttpClientManager GET: http://hdhomerun.mydomain.com/ 2015-05-18 10:52:21.2593 Info - App: HttpClientManager GET: http://hdhomerun.mydomain.com/tuners.html 2015-05-18 10:52:22.8995 Info - App: Executing Refresh Guide 2015-05-18 10:52:22.8995 Info - App: HttpClientManager GET: http://hdhomerun.mydomain.com/ 2015-05-18 10:52:22.9514 Info - EmbyTV: Start GetChannels Async, retrieve all channels for HDTC-2US-1050B951 2015-05-18 10:52:22.9514 Info - App: HttpClientManager GET: http://hdhomerun.mydomain.com/lineup.json 2015-05-18 10:52:23.0115 Info - EmbyTV: Found 31channels on host: hdhomerun.mydomain.com 2015-05-18 10:52:23.0115 Info - EmbyTV: Only Favorites?True 2015-05-18 10:52:23.0115 Info - App: HttpClientManager POST: https://json.schedulesdirect.org/20141201/token 2015-05-18 10:52:23.5888 Info - EmbyTV: Authenticated with Schedules Direct token: *token* 2015-05-18 10:52:23.5888 Info - App: HttpClientManager GET: https://json.schedulesdirect.org/20141201/lineups/USA-OTA-37909
EZEd 60 Posted May 19, 2015 Posted May 19, 2015 i am willing to work with it but 1 i dont have one so i cant test it and two i dont have any documentation on how to obtain the device stream. If anyone could provide some documentatiom then development on it could start, the same for other network services and iptv providers if documentation is provided some support could be added You mentioned being willing to work this if provided the documentation to begin the development. Ceton support can likely give you the documentation about how they issue the stream. They have a similar network based tuner to Silicondust and I'm sure the stream delivery method is likely similar and based on some IEEE standard somewhere. Silicondust is doing their own DVR software that will be form fitted for their particular brand of tuners. It would be most helpful to the community at large if you guys (Emby) could do the same for the broader base of all hardware tuners similar to how Windows Media Center was already in the business of doing. Most of us cablecard tuner owners are concerned about this because Microsoft has said they are no longer delivering or supporting WMC in future releases starting with Windows 10. We cable card users are now looking for the next software platform that cable card tuners can be supported in, whether that be Emby, JRiver, Kodi, Plex or whoever is willing to step up to the plate.
kingy444 117 Posted May 27, 2015 Posted May 27, 2015 is there a proposed alternative to schedules direct? it appears they only provide information for the US. Us here in Australia are left out of the service
PhilWhite 64 Posted May 27, 2015 Posted May 27, 2015 Incredible plugin, thank you Jose for all your hard work. I was wondering if anyone has advice for the best transcoder settings. I only set this up today and noticed that turning off throttling (I had it on when I was trying to figure out why I had transmission problems the first time I set up the Emby plugin for FreeNAS, but those issues were all self-inflicted and had nothing to do with Emby) helped the picture. I have both HDHR Extend and Connect models but have Emby set to access only the Extend. Right now I have the transcode settings on the HDHR Extend set on Heavy since switching to mobile didn't seem to help picture quality (but this was before I turned off throttling). Is there any sense in turning off transcoding on the Extend and allowing Emby to do all the transcoding on my FreeNAS box? I kind of doubt that would help at all; right now there is only a very slight lag when there is movement on screen. The picture quality is actually pretty good, just wondering if there are any tweaks that might optimize things. Will try recording tonight.
PhilWhite 64 Posted May 29, 2015 Posted May 29, 2015 Another question -- I recorded two shows to see how it would work and like the way the recordings are displayed; quality was excellent. But the files were labelled in an odd way and they did not make it to the folder I assigned -- I think that was my issue not setting permissions correctly in my plugin jail, though. What is the naming convention? Will we be able to use MCEBuddy (or similar) to rename shows? -- I would then move them to Recorded TV and consume from there. It's not a big deal since the way the shows are listed after recording is fine, but I would like to strip out the commercials.
