kaylin4u 0 Posted April 21, 2015 Posted April 21, 2015 Never mind, I didn't set up my favorites (flags). Gonna try and restart it now.
ebr 16334 Posted April 21, 2015 Posted April 21, 2015 Jose - I suggest you make the only show favorite channels option default to off to avoid this type of confusion. Better to include everything for the first time user and then let them filter from there.
jasonmcroy 320 Posted April 21, 2015 Posted April 21, 2015 I just wanted to report that I am also not getting the guide data to show up since latest Beta server release 3.0.5588.0 and plugin version 0.7.3.0. It runs the scan but nothing shows up in the live tv section. I restarted the server a couple of times to see if that would fix it but it did not. Here are my server logs: server-63565233060.txt -Jason
jose 73 Posted April 21, 2015 Author Posted April 21, 2015 New release should fix schedule direct images and set to false the default of only Favorites.
jose 73 Posted April 21, 2015 Author Posted April 21, 2015 @@Luke Why do you know why images only appear after doing a guide refresh after being downloaded?
Luke 42241 Posted April 21, 2015 Posted April 21, 2015 it's not related to doing a guide refresh, it's just that they're downloaded in the background which means they might not initially be available when you go and view that program.
jose 73 Posted April 21, 2015 Author Posted April 21, 2015 (edited) I just wanted to report that I am also not getting the guide data to show up since latest Beta server release 3.0.5588.0 and plugin version 0.7.3.0. It runs the scan but nothing shows up in the live tv section. I restarted the server a couple of times to see if that would fix it but it did not. Here are my server logs: server-63565233060.txt -Jason That should be fixed now , it was caused due to a change in the cache directory, i forgot to add the code to create the directory if it didn't exist. Also i tried to pick a logo from the images that i get, (backdrop, characters etc..) @@Luke will it be possible to supply the server with multiple image options? Edited April 22, 2015 by jose
jose 73 Posted April 22, 2015 Author Posted April 22, 2015 For a programs if i have multiple images .
Luke 42241 Posted April 22, 2015 Posted April 22, 2015 OK. Not at the moment but something to consider for later
Kent 92 Posted April 22, 2015 Posted April 22, 2015 I'm still on .7.0.0 not sure why Emby isn't picking up the new plugin version or do i need to uninstall / reinstal to grasb the latest? Automatic updates is set at beta...?
jose 73 Posted April 22, 2015 Author Posted April 22, 2015 (edited) You can go to the plugin catalog page and installed it there without needing to uninstall Edited April 22, 2015 by jose
jasonmcroy 320 Posted April 22, 2015 Posted April 22, 2015 Hi Jose, I just updated to version 0.7.4.0 and still no guide. Is this the correct version. -Jason
jose 73 Posted April 22, 2015 Author Posted April 22, 2015 Hi Jose, I just updated to version 0.7.4.0 and still no guide. Is this the correct version. -Jason There should be a .5 out
nickr124 4 Posted April 22, 2015 Posted April 22, 2015 I updated to 0.7.5 and a lot of the channels in the guide do not have any data. I tried refreshing the guide after updating and I'm getting the same result. Server logs: server-63565240304.txt
jose 73 Posted April 22, 2015 Author Posted April 22, 2015 I updated to 0.7.5 and a lot of the channels in the guide do not have any data. I tried refreshing the guide after updating and I'm getting the same result. Server logs: server-63565240304.txt check 0.7.6
Kent 92 Posted April 22, 2015 Posted April 22, 2015 Everything is back with guide data using .8.0 plugin version. Thanks!
MSattler 390 Posted April 22, 2015 Posted April 22, 2015 Everything is back with guide data using .8.0 plugin version. Thanks! Trying to play with .8, and I get Value cannot be null. Parameter name: source
kaebelhar 0 Posted April 22, 2015 Posted April 22, 2015 I'm on .8 and can not get any channels or guide to load. While messing around trying to get the data I've gotten a couple of "unhandled exceptions" on the server and it crashes and I have to restart it. Any logs I can submit that would be helpful?
jasonmcroy 320 Posted April 22, 2015 Posted April 22, 2015 Hi Jose, Version 0.8.0 is giving me timeout errors when trying to install fresh. I am also getting some remote internal errors. Here is my log: server-63565316859.txt
