jose 73 Posted April 15, 2015 Author Posted April 15, 2015 Partial support for m3u playlists: Should support the following formats rtsp, rtmp, http, file but only tested with http stream from a prime. #EXTM3U#EXTINF:-1 tvg-id="1" tvg-name="ABC",Channel 1http://192.168.1.238:5004/auto/v8#EXTINF:-1 tvg-id="2" tvg-name="Channel_2",Channel 2http://192.168.1.238:5004/auto/v9 Needs to be added manually to the config xml file, example a HDHomerun Prime and a m3u playlist. <TunerHostsConfiguration><TunerUserConfiguration><ServerId>HDHR3-CC-XXXXXX</ServerId><ServerType>HdHomerun</ServerType><UserFields><UserField><Name>Url</Name><Value>192.168.1.238</Value></UserField><UserField><Name>OnlyFavorites</Name><Value>true</Value></UserField></UserFields></TunerUserConfiguration><TunerUserConfiguration><ServerId>test</ServerId><ServerType>M3UPlaylist</ServerType><UserFields><UserField><Name>PlaylistPath</Name><Value>C:\Users\Win10\Desktop\Prime.m3u</Value></UserField></UserFields></TunerUserConfiguration></TunerHostsConfiguration> 1
jose 73 Posted April 15, 2015 Author Posted April 15, 2015 Support some iptv channels. Sometimes they put the channels ips on a playlist.
jose 73 Posted April 15, 2015 Author Posted April 15, 2015 what is this for? Does the server support a UDP video/audio streams from what i can see IPTV m3u files usually contain udp addresses # EXTM3U # EXTINF: -1 tvg-id = "1" tvg-name = "Pervyy_kanal" tvg-logo = "PervyyKanal" group-title = "The federal channels," Channel udp :/ / @ 224.2.0.1:6000 # EXTINF: -1 tvg-name = "Rossiya_1" tvg-logo = "Russia1" Russia-1 udp :/ / @ 224.2.0.6:6000 I based the M3U format on the format used by the kodi simpleIptv plugin http://kodi.wiki/view/Add-on:IPTV_Simple_Client
Luke 42241 Posted April 15, 2015 Posted April 15, 2015 the server supports anything we can pass into ffmpeg on the command line
jose 73 Posted April 15, 2015 Author Posted April 15, 2015 @@Luke as ffmpeg seems to support udp streams can you add udp to the protocols for Media stream info? Or what protocol do i set if i pass a udp path
Luke 42241 Posted April 15, 2015 Posted April 15, 2015 if its' a path and a name of a protocol yes that's easy
MSattler 390 Posted April 15, 2015 Posted April 15, 2015 Under "LiveTVStatus", http://whateverIP:8096/mediabrowser/web/livetvstatus.html if you click on EmbyTV it goes to http://localhost:8096/web/ConfigurationPage?name=EmbyTV. That's fine if you are on the Emby Server host, but not if you are working on it remotely. Thanks!
rabbit1543 106 Posted April 15, 2015 Posted April 15, 2015 (edited) Im having some troubles with the latest dev build 06.0.0. Not sure if i should start over or not. I've got 2 HDRPs configured and my recordings are set to go to a second internal hard drive. 1. When trying to tune a channel im getting an error "Value Cannot be null. Parameter name: source" , scheduled recordings are not working as well, assume this is related. 2. Also how do i get my recordings to show up under the recordings tab 3. When scheduling a series should the upcoming recordings show up under the scheduled tab or only in the series tab. Comparing to wmc i am able to see the individual upcoming scheduled series recordings. This was working the other day on the initial release. If it means anything im also running the latest beta 3.0.5582.1 Edited April 15, 2015 by rabbit1543
denethor 90 Posted April 15, 2015 Posted April 15, 2015 (edited) I got excited since this is a generic add-on for Networked tuners there are lots of possibilities. First I tried DVBViewer with m3u playlist file. (By the the way I am hoping for support of RTSP, SAT/IP, Unicast,DLNA etc..DVBviewer Recording Service support almost all the possible Network stream protocols) Below is the DVBViewer Recording Service M3U format and look like it's not supported by this addon. Please take a look and feel free to add support DVBViewer users you can get your server playlist files with: http://localhost:8089/?command=get_playlist_m3u EXTM3U #EXTINF:-1,Sky - Discovery http://localhost:7522/upnp/channelstream/169.ts #EXTINF:-1,Sky - Animal Planet http://localhost:7522/upnp/channelstream/170.ts In the mean time DVBViewer Recording Service APIs(Search for "API" in the page): http://en.dvbviewer.tv/wiki/Category:DVBViewer_Recording_Service Warning: 8089 is default port for DVBviewer WEB Interface and it is possible to add password protection to that port. On the other hand 7522 is default streaming port and password protection is not possible for streams. So think twice for opening your server to internet. Edited April 15, 2015 by denethor
rabbit1543 106 Posted April 15, 2015 Posted April 15, 2015 Another thing i just experienced. I removed the option to refresh the guide at startup since its takes at least 30 mins to download everything at the moment. Prior to a server restart my epg was populated and now after a restart my guide is empty. I would have thought that the epg would survive a server restart and i wouldnt need to refresh the guide at each startup.
denethor 90 Posted April 15, 2015 Posted April 15, 2015 (edited) I' ve tried to match your supported M3U list format with data in DVBviewer m3u files. Mine final test playlist file as follows: #EXTM3U #EXTINF:-1 tvg-id="1" tvg-name="SOMENAME",Channel Name http://192.168.1.10:7522/upnp/channelstream/0.ts But I got this in logs. I do not know which file is wrong. Config file or m3u file 2015-04-16 01:21:58.2073 Info - EmbyTV: Start GetChannels Async, retrieve all channels for test 2015-04-16 01:21:58.2073 Error - App: Error refreshing channels for service *** Error Report *** Version: 3.0.5583.30726 Command line: C:\Users\Name Surname\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Name Surname\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Name Surname\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe wrong file System.ApplicationException at EmbyTV.TunerHost.M3UHost.GetChannels(CancellationToken cancellationToken) at EmbyTV.LiveTvService.<GetChannelsAsync>d__1d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager.<GetChannels>d__113.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager.<RefreshChannelsInternal>d__e9.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager.<RefreshChannelsInternal>d__dd.MoveNext() Edited April 15, 2015 by denethor
jose 73 Posted April 15, 2015 Author Posted April 15, 2015 (edited) I' ve tried to match your supported M3U list format with data in DVBviewer m3u files. Mine final test playlist file as follows: #EXTM3U #EXTINF:-1 tvg-id="1" tvg-name="SOMENAME",Channel Name http://192.168.1.10:7522/upnp/channelstream/0.ts But I got this in logs. I do not know which file is wrong. Config file or m3u file 2015-04-16 01:21:58.2073 Info - EmbyTV: Start GetChannels Async, retrieve all channels for test 2015-04-16 01:21:58.2073 Error - App: Error refreshing channels for service *** Error Report *** Version: 3.0.5583.30726 Command line: C:\Users\Name Surname\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Name Surname\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Name Surname\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe wrong file System.ApplicationException at EmbyTV.TunerHost.M3UHost.GetChannels(CancellationToken cancellationToken) at EmbyTV.LiveTvService.<GetChannelsAsync>d__1d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager.<GetChannels>d__113.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager.<RefreshChannelsInternal>d__e9.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager.<RefreshChannelsInternal>d__dd.MoveNext() Fix should be coming up, i was expecting a space after #EXTM3U I' ve tried to match your supported M3U list format with data in DVBviewer m3u files. Mine final test playlist file as follows: Im having some troubles with the latest dev build 06.0.0. Not sure if i should start over or not. I've got 2 HDRPs configured and my recordings are set to go to a second internal hard drive. 1. When trying to tune a channel im getting an error "Value Cannot be null. Parameter name: source" , scheduled recordings are not working as well, assume this is related. 2. Also how do i get my recordings to show up under the recordings tab 3. When scheduling a series should the upcoming recordings show up under the scheduled tab or only in the series tab. Comparing to wmc i am able to see the individual upcoming scheduled series recordings. This was working the other day on the initial release. If it means anything im also running the latest beta 3.0.5582.1 The recordings metadata is not being populated at the moment i am working on that, but the file should be recorded and appear on schedule recordings, Series recording wont record anything ii has not been fully implemented. Epg data should service restart if it was pulled at least once correctly since version 0.6.0 Also can you post a log to see a little more detail about the source error. Edited April 15, 2015 by jose
jose 73 Posted April 15, 2015 Author Posted April 15, 2015 Still no store tile as well... I dont know what to use so i havent put one there.
denethor 90 Posted April 16, 2015 Posted April 16, 2015 (edited) First things first: 0.60.1 fixed the problem with m3u files. I can now see all my channels in Live TV. Parsing have still some issues. Group names or channels names which contains "space" cannot be displayed in EMBY->Live TV-> Channel list For example below channel listed as "A" Parsing trims all charecters after space: #EXTINF:-1 tvg-id="82" tvg-name="A SPOR HD",A SPOR HD 2nd problem is related with encrypted channels (I have subscription smart card installed in my CAM) Those cannot be streamed. It think this is a issue with timeout. DVBviewer own web clients requires 10-15 seconds time out for ffmpeg process to catch up with the stream. 3rd problem, sometimes streaming fails even for FTA channels. Looks like ffmpeg process just quits. I just posted some logs below that look relevant with problem. I think server Devs may need to look at transcoders timeouts. Server Log: 2015-04-16 11:08:52.8028 Info - App: Opening channel stream from EmbyTV, external channel Id: 79 2015-04-16 11:08:52.8028 Info - EmbyTV: Streaming Channel 2015-04-16 11:08:52.8028 Info - App: Live stream info: {"Protocol":"Http","Id":"2","Path":"http://localhost:7522/upnp/channelstream/79.ts","Type":"Default","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":true,"LiveStreamId":"42765c0aec53374f18a41b1fc056fcbc_2","MediaStreams":[{"IsInterlaced":true,"IsDefault":false,"IsForced":false,"Type":"Video","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false},{"IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false}],"PlayableStreamFileNames":[],"Formats":[],"RequiredHttpHeaders":{}} 2015-04-16 11:08:52.8028 Debug - MediaEncoder: C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150331\ffprobe.exe -i "http://localhost:7522/upnp/channelstream/79.ts" -threads 0 -v info -print_format json -show_streams -show_format 2015-04-16 11:09:04.2170 Debug - MediaSourceManager: Live stream opened: {"Protocol":"Http","Id":"2","Path":"http://localhost:7522/upnp/channelstream/79.ts","Type":"Default","Container":"mpegts","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":true,"LiveStreamId":"1a755974de5dc3461dc6ecae8ddec68b|42765c0aec53374f18a41b1fc056fcbc_2","MediaStreams":[{"Codec":"mpeg2video","IsInterlaced":false,"BitDepth":8,"IsDefault":false,"IsForced":false,"Height":576,"Width":720,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"Main","Type":"Video","AspectRatio":"4:3","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":8,"IsAnamorphic":false},{"Codec":"mp2","Language":"tur","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":256000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":4000000,"RequiredHttpHeaders":{},"DefaultAudioStreamIndex":1} 2015-04-16 11:09:04.2170 Debug - App: Profile: Unknown Profile, Path: http://localhost:7522/upnp/channelstream/79.ts, isEligibleForDirectPlay: False, isEligibleForDirectStream: False 2015-04-16 11:09:04.2170 Debug - App: Profile: Unknown Profile, Path: http://localhost:7522/upnp/channelstream/79.ts, isEligibleForDirectPlay: False, isEligibleForDirectStream: False 2015-04-16 11:09:04.2170 Debug - App: Profile: Unknown Profile, Path: http://localhost:7522/upnp/channelstream/79.ts, isEligibleForDirectPlay: False, isEligibleForDirectStream: False 2015-04-16 11:09:04.2170 Debug - HttpServer: HTTP Response 200 to 5.25.139.31. Response time: 11429.8599 ms. Url: http://192.168.1.10:8096/mediabrowser/LiveStreams/Open?UserId=3eff8a317d0ecf2ca565029f7516f357&StartTimeTicks=0&ItemId=82dada7265d90c33c01f446cd9949271&PlaySessionId=2331bc8d10c642cbb79f7a1f246e5172 2015-04-16 11:09:04.5035 Debug - HttpServer: HTTP GET http://192.168.1.10:8096/mediabrowser/videos/82dada7265d90c33c01f446cd9949271/master.m3u8?DeviceId=29cb81082ef7b350b2cbeee3ccb46c796f420da4&MediaSourceId=2&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1872000&AudioBitrate=128000&MaxWidth=1280&Level=41&ClientTime=635647685442180869&Profile=high&Cabac=True&PlaySessionId=2331bc8d10c642cbb79f7a1f246e5172&api_key=db596495bc974584991ad40892909643&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b|42765c0aec53374f18a41b1fc056fcbc_2 Ip: 192.168.1.10:61684. Headers: Cache-Control=max-age=7800,Connection=Keep-Alive,Accept=*/*,Accept-Encoding=gzip,Accept-Language=en-us,Host=192.168.1.10:8096,Max-Forwards=10,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_10_3) AppleWebKit/600.5.17 (KHTML, like Gecko) Version/8.0.5 Safari/600.5.17,X-Playback-Session-Id=4715121D-62C9-4C0E-9DE7-5B97091FB996,X-Original-URL=/mediabrowser/videos/82dada7265d90c33c01f446cd9949271/master.m3u8?DeviceId=29cb81082ef7b350b2cbeee3ccb46c796f420da4&MediaSourceId=2&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1872000&AudioBitrate=128000&MaxWidth=1280&Level=41&ClientTime=635647685442180869&Profile=high&Cabac=True&PlaySessionId=2331bc8d10c642cbb79f7a1f246e5172&api_key=db596495bc974584991ad40892909643&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b|42765c0aec53374f18a41b1fc056fcbc_2,X-Forwarded-For=5.25.139.31,X-ARR-LOG-ID=e14018b8-ba9b-4e06-beed-53f42c10f9bd 2015-04-16 11:09:04.5045 Debug - MediaSourceManager: Getting live stream 1a755974de5dc3461dc6ecae8ddec68b|42765c0aec53374f18a41b1fc056fcbc_2 2015-04-16 11:09:04.5045 Debug - HttpServer: HTTP Response 200 to 5.25.139.31. Response time: 1.9988 ms. Url: http://192.168.1.10:8096/mediabrowser/videos/82dada7265d90c33c01f446cd9949271/master.m3u8?DeviceId=29cb81082ef7b350b2cbeee3ccb46c796f420da4&MediaSourceId=2&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1872000&AudioBitrate=128000&MaxWidth=1280&Level=41&ClientTime=635647685442180869&Profile=high&Cabac=True&PlaySessionId=2331bc8d10c642cbb79f7a1f246e5172&api_key=db596495bc974584991ad40892909643&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b|42765c0aec53374f18a41b1fc056fcbc_2 2015-04-16 11:09:04.5669 Debug - HttpServer: HTTP GET http://192.168.1.10:8096/mediabrowser/videos/82dada7265d90c33c01f446cd9949271/live.m3u8?DeviceId=29cb81082ef7b350b2cbeee3ccb46c796f420da4&MediaSourceId=2&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1872000&AudioBitrate=128000&MaxWidth=1280&Level=41&ClientTime=635647685442180869&Profile=high&Cabac=True&PlaySessionId=2331bc8d10c642cbb79f7a1f246e5172&api_key=db596495bc974584991ad40892909643&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b|42765c0aec53374f18a41b1fc056fcbc_2 Ip: 192.168.1.10:61684. Headers: Cache-Control=max-age=7800,Connection=Keep-Alive,Accept=*/*,Accept-Encoding=gzip,Accept-Language=en-us,Host=192.168.1.10:8096,Max-Forwards=10,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_10_3) AppleWebKit/600.5.17 (KHTML, like Gecko) Version/8.0.5 Safari/600.5.17,X-Playback-Session-Id=4715121D-62C9-4C0E-9DE7-5B97091FB996,X-Original-URL=/mediabrowser/videos/82dada7265d90c33c01f446cd9949271/live.m3u8?DeviceId=29cb81082ef7b350b2cbeee3ccb46c796f420da4&MediaSourceId=2&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1872000&AudioBitrate=128000&MaxWidth=1280&Level=41&ClientTime=635647685442180869&Profile=high&Cabac=True&PlaySessionId=2331bc8d10c642cbb79f7a1f246e5172&api_key=db596495bc974584991ad40892909643&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b|42765c0aec53374f18a41b1fc056fcbc_2,X-Forwarded-For=5.25.139.31,X-ARR-LOG-ID=c781dc09-8754-44cd-b341-f9e2101a4486 2015-04-16 11:09:04.5669 Debug - MediaSourceManager: Getting live stream 1a755974de5dc3461dc6ecae8ddec68b|42765c0aec53374f18a41b1fc056fcbc_2 2015-04-16 11:09:04.5669 Info - App: C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150331\ffmpeg.exe -fflags +genpts -i "http://localhost:7522/upnp/channelstream/79.ts" -map_metadata -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 1872000 -bufsize 3744000 -vsync vfr -profile:v high -level 41 -force_key_frames expr:gte(t,n_forced*3) -vf "scale=min(iw\,1280):trunc(ow/dar/2)*2" -sc_threshold 0 -codec:a:0 aac -strict experimental -ab 128000 -af "adelay=1,aresample=async=1" -hls_time 3 -start_number 0 -hls_list_size 0 -hls_base_url "hls/4aac97cb8cbd8b830949e5f1caeaf956/" -y "C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf956.m3u8" 2015-04-16 11:09:14.8553 Debug - HttpServer: HTTP GET http://localhost:8096/web/index.html Ip: 127.0.0.1:61731. Headers: User-Agent=Pulseway/4.7 (http://www.pulseway.com),Host=localhost:8096,Connection=Close 2015-04-16 11:09:14.8553 Debug - HttpServer: HTTP GET http://localhost:8096/web/dashboard.html Ip: 127.0.0.1:61732. Headers: User-Agent=Pulseway/4.7 (http://www.pulseway.com),Host=localhost:8096,Connection=Close 2015-04-16 11:09:14.8723 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 17.0175 ms. Url: http://localhost:8096/web/index.html 2015-04-16 11:09:14.8943 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 39.0383 ms. Url: http://localhost:8096/web/dashboard.html 2015-04-16 11:09:16.2497 Debug - App: Waiting for 3 segments in C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf956.m3u8 2015-04-16 11:09:20.4495 Debug - App: Finished waiting for 3 segments in C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf956.m3u8 2015-04-16 11:09:20.4495 Debug - App: OnTranscodeEndRequest job.ActiveRequestCount=0 2015-04-16 11:09:20.4495 Debug - App: Starting kill timer at 20000ms. JobId 072e9231f258470c83c82dfeb3ab596c PlaySessionId 2331bc8d10c642cbb79f7a1f246e5172 2015-04-16 11:09:20.4495 Debug - HttpServer: HTTP Response 200 to 5.25.139.31. Response time: 15883.6386 ms. Url: http://192.168.1.10:8096/mediabrowser/videos/82dada7265d90c33c01f446cd9949271/live.m3u8?DeviceId=29cb81082ef7b350b2cbeee3ccb46c796f420da4&MediaSourceId=2&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1872000&AudioBitrate=128000&MaxWidth=1280&Level=41&ClientTime=635647685442180869&Profile=high&Cabac=True&PlaySessionId=2331bc8d10c642cbb79f7a1f246e5172&api_key=db596495bc974584991ad40892909643&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b|42765c0aec53374f18a41b1fc056fcbc_2 2015-04-16 11:09:20.6048 Debug - HttpServer: HTTP GET http://192.168.1.10:8096/mediabrowser/videos/82dada7265d90c33c01f446cd9949271/live.m3u8?DeviceId=29cb81082ef7b350b2cbeee3ccb46c796f420da4&MediaSourceId=2&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1872000&AudioBitrate=128000&MaxWidth=1280&Level=41&ClientTime=635647685442180869&Profile=high&Cabac=True&PlaySessionId=2331bc8d10c642cbb79f7a1f246e5172&api_key=db596495bc974584991ad40892909643&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b|42765c0aec53374f18a41b1fc056fcbc_2 Ip: 192.168.1.10:61684. Headers: Cache-Control=max-age=7800,Connection=Keep-Alive,Accept=*/*,Accept-Encoding=gzip,Accept-Language=en-us,Host=192.168.1.10:8096,Max-Forwards=10,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_10_3) AppleWebKit/600.5.17 (KHTML, like Gecko) Version/8.0.5 Safari/600.5.17,X-Playback-Session-Id=4715121D-62C9-4C0E-9DE7-5B97091FB996,X-Original-URL=/mediabrowser/videos/82dada7265d90c33c01f446cd9949271/live.m3u8?DeviceId=29cb81082ef7b350b2cbeee3ccb46c796f420da4&MediaSourceId=2&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1872000&AudioBitrate=128000&MaxWidth=1280&Level=41&ClientTime=635647685442180869&Profile=high&Cabac=True&PlaySessionId=2331bc8d10c642cbb79f7a1f246e5172&api_key=db596495bc974584991ad40892909643&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b|42765c0aec53374f18a41b1fc056fcbc_2,X-Forwarded-For=5.25.139.31,X-ARR-LOG-ID=af5c38c4-a8aa-448e-9afe-9662098d32ae 2015-04-16 11:09:20.6048 Debug - MediaSourceManager: Getting live stream 1a755974de5dc3461dc6ecae8ddec68b|42765c0aec53374f18a41b1fc056fcbc_2 2015-04-16 11:09:20.6048 Debug - App: OnTranscodeEndRequest job.ActiveRequestCount=0 2015-04-16 11:09:20.6048 Debug - App: Changing kill timer to 20000ms. JobId 072e9231f258470c83c82dfeb3ab596c PlaySessionId 2331bc8d10c642cbb79f7a1f246e5172 2015-04-16 11:09:20.6048 Debug - HttpServer: HTTP Response 200 to 5.25.139.31. Response time: 3.0039 ms. Url: http://192.168.1.10:8096/mediabrowser/videos/82dada7265d90c33c01f446cd9949271/live.m3u8?DeviceId=29cb81082ef7b350b2cbeee3ccb46c796f420da4&MediaSourceId=2&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1872000&AudioBitrate=128000&MaxWidth=1280&Level=41&ClientTime=635647685442180869&Profile=high&Cabac=True&PlaySessionId=2331bc8d10c642cbb79f7a1f246e5172&api_key=db596495bc974584991ad40892909643&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b|42765c0aec53374f18a41b1fc056fcbc_2 2015-04-16 11:09:20.6410 Debug - HttpServer: HTTP GET http://192.168.1.10:8096/mediabrowser/videos/82dada7265d90c33c01f446cd9949271/hls/4aac97cb8cbd8b830949e5f1caeaf956/4aac97cb8cbd8b830949e5f1caeaf9560.ts Ip: 192.168.1.10:61684. Headers: Cache-Control=max-age=7800,Connection=Keep-Alive,Accept=*/*,Accept-Encoding=identity,Accept-Language=en-us,Host=192.168.1.10:8096,Max-Forwards=10,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_10_3) AppleWebKit/600.5.17 (KHTML, like Gecko) Version/8.0.5 Safari/600.5.17,X-Playback-Session-Id=4715121D-62C9-4C0E-9DE7-5B97091FB996,X-Original-URL=/mediabrowser/videos/82dada7265d90c33c01f446cd9949271/hls/4aac97cb8cbd8b830949e5f1caeaf956/4aac97cb8cbd8b830949e5f1caeaf9560.ts,X-Forwarded-For=5.25.139.31,X-ARR-LOG-ID=da828eec-e396-4c76-8b6c-81532047f6d6 2015-04-16 11:09:20.6470 Debug - App: OnTranscodeEndRequest job.ActiveRequestCount=0 2015-04-16 11:09:20.6470 Debug - App: Changing kill timer to 20000ms. JobId 072e9231f258470c83c82dfeb3ab596c PlaySessionId 2331bc8d10c642cbb79f7a1f246e5172 2015-04-16 11:09:20.6470 Debug - HttpServer: HTTP Response 200 to 5.25.139.31. Response time: 7.0039 ms. Url: http://192.168.1.10:8096/mediabrowser/videos/82dada7265d90c33c01f446cd9949271/hls/4aac97cb8cbd8b830949e5f1caeaf956/4aac97cb8cbd8b830949e5f1caeaf9560.ts 22015-04-16 11:09:40.6476 Debug - App: Transcoding kill timer stopped for JobId 072e9231f258470c83c82dfeb3ab596c PlaySessionId 2331bc8d10c642cbb79f7a1f246e5172. Killing transcoding 2015-04-16 11:09:40.6476 Debug - App: KillTranscodingJob - JobId 072e9231f258470c83c82dfeb3ab596c PlaySessionId 2331bc8d10c642cbb79f7a1f246e5172. Killing transcoding 2015-04-16 11:09:40.6476 Info - App: Killing ffmpeg process for C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf956.m3u8 2015-04-16 11:09:40.7106 Debug - App: Disposing stream resources 2015-04-16 11:09:40.7106 Info - App: FFMpeg exited with code 0 2015-04-16 11:09:40.7106 Info - App: Deleting partial stream file(s) C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf956.m3u8 2015-04-16 11:09:42.2255 Info - App: Deleting HLS file C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf956.m3u8 2015-04-16 11:09:42.2255 Info - App: Deleting HLS file C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf9560.ts 2015-04-16 11:09:42.2255 Info - App: Deleting HLS file C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf9561.ts 2015-04-16 11:09:42.2255 Info - App: Deleting HLS file C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf95610.ts 2015-04-16 11:09:42.2255 Info - App: Deleting HLS file C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf9562.ts 2015-04-16 11:09:42.2255 Info - App: Deleting HLS file C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf9563.ts 2015-04-16 11:09:42.2255 Info - App: Deleting HLS file C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf9564.ts 2015-04-16 11:09:42.2255 Info - App: Deleting HLS file C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf9565.ts 2015-04-16 11:09:42.2255 Info - App: Deleting HLS file C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf9566.ts 2015-04-16 11:09:42.2255 Info - App: Deleting HLS file C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf9567.ts 2015-04-16 11:09:42.2255 Info - App: Deleting HLS file C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf9568.ts 2015-04-16 11:09:42.2255 Info - App: Deleting HLS file C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\4aac97cb8cbd8b830949e5f1caeaf9569.ts 2015-04-16 11:09:46.4356 Debug - HttpServer: HTTP GET http://192.168.1.10:8096/mediabrowser/web/files/dummy.mp4 Transcoder Logs http://192.168.1.10:8096/mediabrowser/videos/368df7f819017a7e34e2f88e228c34b6/live.m3u8?DeviceId=29cb81082ef7b350b2cbeee3ccb46c796f420da4&MediaSourceId=5&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1872000&AudioBitrate=128000&MaxWidth=720&Level=41&ClientTime=635647689576501434&Profile=high&Cabac=True&PlaySessionId=24ee16f3a7924a1ba6d6c8ae2fea2898&api_key=db596495bc974584991ad40892909643&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b%7C42765c0aec53374f18a41b1fc056fcbc_5 C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150331\ffmpeg.exe -fflags +genpts -i "http://localhost:7522/upnp/channelstream/84.ts" -map_metadata -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 1872000 -bufsize 3744000 -vsync vfr -profile:v high -level 41 -force_key_frames expr:gte(t,n_forced*3) -vf "scale=min(iw\,720):trunc(ow/dar/2)*2" -sc_threshold 0 -codec:a:0 aac -strict experimental -ab 128000 -af "adelay=1,aresample=async=1" -hls_time 3 -start_number 0 -hls_list_size 0 -hls_base_url "hls/f5fb105d1de6030f1303f0c0238461b9/" -y "C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\f5fb105d1de6030f1303f0c0238461b9.m3u8" ffmpeg version N-71182-g5cba529 Copyright (c) 2000-2015 the FFmpeg developers built with gcc 4.9.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib libavutil 54. 21.100 / 54. 21.100 libavcodec 56. 32.100 / 56. 32.100 libavformat 56. 27.100 / 56. 27.100 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 13.101 / 5. 13.101 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100 [mpeg2video @ 000000000455c760] Invalid frame dimensions 0x0. Last message repeated 4 times Input #0, mpegts, from 'http://localhost:7522/upnp/channelstream/84.ts': Duration: N/A, start: 20947.326867, bitrate: N/A Program 10800 Stream #0:0[0x708]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv), 720x576 [SAR 16:15 DAR 4:3], max. 15000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1[0x76c](tur): Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16p, 256 kb/s [libx264 @ 0000000004586480] using SAR=1/1 [libx264 @ 0000000004586480] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [libx264 @ 0000000004586480] profile High, level 4.1 Output #0, hls, to 'C:\Users\denethor\AppData\Roaming\MediaBrowser-Server\transcoding-temp\f5fb105d1de6030f1303f0c0238461b9.m3u8': Metadata: encoder : Lavf56.27.100 Stream #0:0: Video: h264 (libx264), yuv420p, 720x540 [SAR 1:1 DAR 4:3], q=-1--1, max. 1872 kb/s, 25 fps, 90k tbn, 25 tbc Metadata: encoder : Lavc56.32.100 libx264 Stream #0:1: Audio: aac, 48000 Hz, stereo, fltp, 128 kb/s Metadata: encoder : Lavc56.32.100 aac Stream mapping: Stream #0:0 -> #0:0 (mpeg2video (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (mp2 (native) -> aac (native)) Press [q] to stop, [?] for help frame= 136 fps=0.0 q=24.0 size=N/A time=00:00:05.58 bitrate=N/A frame= 149 fps=141 q=24.0 size=N/A time=00:00:06.12 bitrate=N/A frame= 152 fps= 52 q=27.0 size=N/A time=00:00:06.22 bitrate=N/A [mpegts @ 000000000457cb80] PES packet size mismatch [mpeg2video @ 0000000005507b60] invalid cbp -1 at 0 24 [mpeg2video @ 0000000005507b60] invalid cbp -1 at 0 25 [mpeg2video @ 0000000005507b60] invalid cbp -1 at 0 20 [mpeg2video @ 0000000005507b60] invalid cbp -1 at 0 28 [mpeg2video @ 0000000005507b60] invalid cbp -1 at 0 32 [mpeg2video @ 0000000005507b60] invalid cbp 0 at 1 33 [mpeg2video @ 0000000005507b60] 00 motion_type at 4 34 [mpeg2video @ 0000000005507b60] ac-tex damaged at 30 35 [mpeg2video @ 0000000005507b60] 00 motion_type at 1 16 [mpeg2video @ 0000000005507b60] 00 motion_type at 6 13 [mpeg2video @ 0000000005507b60] slice mismatch [mpeg2video @ 0000000005507b60] 00 motion_type at 2 21 [mpeg2video @ 0000000005507b60] 00 motion_type at 2 29 [mpeg2video @ 0000000005507b60] ac-tex damaged at 0 17 [mpeg2video @ 0000000005507b60] invalid cbp -1 at 0 6 [mpeg2video @ 0000000005507b60] 00 motion_type at 4 27 [mpeg2video @ 0000000005507b60] invalid mb type in P Frame at 5 22 [mpeg2video @ 0000000005507b60] invalid cbp -1 at 0 30 [mpeg2video @ 0000000005507b60] 00 motion_type at 15 18 [mpeg2video @ 0000000005507b60] invalid cbp -1 at 0 7 [mpeg2video @ 0000000005507b60] slice mismatch [mpeg2video @ 0000000005507b60] invalid cbp -1 at 0 31 [mpeg2video @ 0000000005507b60] invalid cbp -1 at 0 19 [mpeg2video @ 0000000005507b60] invalid mb type in P Frame at 1 8 [mpeg2video @ 0000000005507b60] 00 motion_type at 19 9 [mpeg2video @ 0000000005507b60] 00 motion_type at 12 10 [mpeg2video @ 0000000005507b60] 00 motion_type at 23 11 [mpeg2video @ 0000000005507b60] 00 motion_type at 17 12 [mpeg2video @ 0000000005507b60] 00 motion_type at 2 13 [mpeg2video @ 0000000005507b60] 00 motion_type at 3 14 [mpeg2video @ 0000000005507b60] 00 motion_type at 2 15 [mpeg2video @ 0000000005507b60] Warning MVs not available [mpeg2video @ 0000000005507b60] concealing 1350 DC, 1350 AC, 1350 MV errors in P frame [mp2 @ 00000000052ce760] Header missing Error while decoding stream #0:1: Invalid data found when processing input frame= 164 fps= 47 q=25.0 size=N/A time=00:00:08.00 bitrate=N/A frame= 178 fps= 44 q=21.0 size=N/A time=00:00:09.04 bitrate=N/A frame= 191 fps= 42 q=22.0 size=N/A time=00:00:09.57 bitrate=N/A frame= 205 fps= 40 q=24.0 size=N/A time=00:00:10.13 bitrate=N/A frame= 221 fps= 39 q=24.0 size=N/A time=00:00:10.64 bitrate=N/A frame= 232 fps= 38 q=22.0 size=N/A time=00:00:11.20 bitrate=N/A frame= 245 fps= 37 q=25.0 size=N/A time=00:00:11.73 bitrate=N/A frame= 261 fps= 36 q=25.0 size=N/A time=00:00:12.28 bitrate=N/A frame= 273 fps= 35 q=24.0 size=N/A time=00:00:12.77 bitrate=N/A frame= 286 fps= 34 q=22.0 size=N/A time=00:00:13.35 bitrate=N/A frame= 296 fps= 33 q=24.0 size=N/A time=00:00:13.88 bitrate=N/A frame= 310 fps= 33 q=24.0 size=N/A time=00:00:14.44 bitrate=N/A frame= 326 fps= 33 q=25.0 size=N/A time=00:00:14.93 bitrate=N/A frame= 339 fps= 33 q=25.0 size=N/A time=00:00:15.44 bitrate=N/A frame= 353 fps= 32 q=21.0 size=N/A time=00:00:16.04 bitrate=N/A frame= 367 fps= 32 q=23.0 size=N/A time=00:00:16.59 bitrate=N/A frame= 380 fps= 32 q=24.0 size=N/A time=00:00:17.08 bitrate=N/A frame= 392 fps= 31 q=24.0 size=N/A time=00:00:17.62 bitrate=N/A frame= 407 fps= 31 q=25.0 size=N/A time=00:00:18.15 bitrate=N/A frame= 421 fps= 31 q=22.0 size=N/A time=00:00:18.64 bitrate=N/A frame= 434 fps= 30 q=25.0 size=N/A time=00:00:19.28 bitrate=N/A frame= 454 fps= 31 q=23.0 size=N/A time=00:00:19.84 bitrate=N/A frame= 469 fps= 31 q=21.0 size=N/A time=00:00:20.33 bitrate=N/A frame= 473 fps= 30 q=22.0 size=N/A time=00:00:20.82 bitrate=N/A frame= 485 fps= 30 q=26.0 size=N/A time=00:00:21.33 bitrate=N/A frame= 498 fps= 29 q=23.0 size=N/A time=00:00:21.90 bitrate=N/A frame= 512 fps= 29 q=22.0 size=N/A time=00:00:22.48 bitrate=N/A frame= 526 fps= 29 q=23.0 size=N/A time=00:00:22.95 bitrate=N/A frame= 539 fps= 29 q=21.0 size=N/A time=00:00:23.44 bitrate=N/A frame= 551 fps= 29 q=21.0 size=N/A time=00:00:23.97 bitrate=N/A frame= 565 fps= 29 q=26.0 size=N/A time=00:00:24.53 bitrate=N/A frame= 578 fps= 29 q=24.0 size=N/A time=00:00:25.02 bitrate=N/A frame= 590 fps= 29 q=25.0 size=N/A time=00:00:25.53 bitrate=N/A frame= 604 fps= 29 q=23.0 size=N/A time=00:00:26.09 bitrate=N/A frame= 617 fps= 29 q=24.0 size=N/A time=00:00:26.58 bitrate=N/A frame= 628 fps= 29 q=20.0 size=N/A time=00:00:27.05 bitrate=N/A frame= 640 fps= 28 q=27.0 size=N/A time=00:00:27.52 bitrate=N/A frame= 652 fps= 28 q=24.0 size=N/A time=00:00:28.11 bitrate=N/A frame= 668 fps= 28 q=22.0 size=N/A time=00:00:28.60 bitrate=N/A frame= 681 fps= 28 q=25.0 size=N/A time=00:00:29.09 bitrate=N/A frame= 697 fps= 28 q=23.0 size=N/A time=00:00:29.67 bitrate=N/A frame= 701 fps= 28 q=-1.0 Lsize=N/A time=00:00:30.20 bitrate=N/A video:2776kB audio:445kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown [libx264 @ 0000000004586480] frame I:11 Avg QP:19.04 size: 38122 [libx264 @ 0000000004586480] frame P:192 Avg QP:20.62 size: 8428 [libx264 @ 0000000004586480] frame B:498 Avg QP:21.49 size: 1618 [libx264 @ 0000000004586480] consecutive B-frames: 4.1% 1.7% 5.1% 89.0% [libx264 @ 0000000004586480] mb I I16..4: 5.4% 33.5% 61.1% [libx264 @ 0000000004586480] mb P I16..4: 3.1% 5.2% 1.6% P16..4: 71.4% 0.0% 0.0% 0.0% 0.0% skip:18.7% [libx264 @ 0000000004586480] mb B I16..4: 0.6% 0.3% 0.0% B16..8: 17.9% 0.0% 0.0% direct:14.3% skip:66.9% L0:34.6% L1:51.6% BI:13.8% [libx264 @ 0000000004586480] 8x8 transform intra:43.4% inter:46.5% [libx264 @ 0000000004586480] coded y,uvDC,uvAC intra: 58.3% 65.7% 31.4% inter: 11.0% 16.9% 0.3% [libx264 @ 0000000004586480] i16 v,h,dc,p: 55% 15% 21% 10% [libx264 @ 0000000004586480] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 30% 10% 23% 6% 6% 9% 4% 7% 5% [libx264 @ 0000000004586480] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 29% 10% 10% 9% 8% 12% 5% 11% 7% [libx264 @ 0000000004586480] i8c dc,h,v,p: 39% 16% 36% 10% [libx264 @ 0000000004586480] Weighted P-Frames: Y:0.0% UV:0.0% [libx264 @ 0000000004586480] kb/s:762.22 Edited April 16, 2015 by denethor
rabbit1543 106 Posted April 16, 2015 Posted April 16, 2015 I updated to 0.6.0.1 and after a server restart and guide refresh my epg came back and I was able to view live tv again. This morning I restarted the emby Windows service and once again lost the epg and ability to watch live tv. Will try another refresh and see what happens. Will also try to get some logs when I am at a computer
rabbit1543 106 Posted April 16, 2015 Posted April 16, 2015 I have added a few recordings which all show up in the scheduled recordings tab even ones that were already recorded earlier in the day. The odd thing is that when i click on any of them it only brings up the details of the first item in the list. I then deleted the first item and the results are the same. The new item on top of the list shows no matter what entry i click on. Side note: im liking the way the recordings are being named now. Would it be possible to make this user configurable. Im thinking it would be great to have it match the naming scheme emby uses to get metadata for TV/movie collections.
jose 73 Posted April 17, 2015 Author Posted April 17, 2015 Recordings should now appear as scheduled , inprogress and complete, timers should clean delete themselves when they are over (before they only did this on a restart), Also if you click play on a recording it will play the actual local file being saved using only one tuner and not two (plan to do something like this for all streams so that even if two person watch the same channel it doesn't waste a tuner). Also deleting a recording should delete the file if it exists.
Vitale4 15 Posted April 17, 2015 Posted April 17, 2015 I know this talks about the HDHomerun, which I am willing to purchase and try. However, can it also support CETON devices? Just checking as my son is running his home with Windows Media Server and a CETON card and we wanted to try and keep everything self contained so we simply use EMBY for movies and live TV. I am also hoping we can retire the Windows Media Center eventually.
rabbit1543 106 Posted April 17, 2015 Posted April 17, 2015 Scheduled a few recordings and im seeing that an upcoming scheduled recording is showing up in the "Latest recordings" section as well as the "All Recordings". Once the recording started it moved into "Active Recordings"
kaylin4u 0 Posted April 17, 2015 Posted April 17, 2015 I'm new to MB and just ordered my new HD Homerun. Plan to set up my live tv (local broadcasting only). But is "schedules direct" the only guide this supports? I tried reading over all this first, but might have missed something.
Luke 42241 Posted April 17, 2015 Posted April 17, 2015 I'm new to MB and just ordered my new HD Homerun. Plan to set up my live tv (local broadcasting only). But is "schedules direct" the only guide this supports? I tried reading over all this first, but might have missed something. what would you prefer?
kaylin4u 0 Posted April 17, 2015 Posted April 17, 2015 after looking around, there isn't much else is there.
Luke 42241 Posted April 17, 2015 Posted April 17, 2015 If there is then we will certainly consider it, because we all want the best. But I think schedules direct is the most popular right now. 1
