JeremyFr79 228 Posted April 23, 2015 Posted April 23, 2015 So I've moved channels and now am getting 25 down 17 up will try some playback tests later to see how it does, didn't see as many drops during the test as before.
mdgentile 0 Posted April 23, 2015 Posted April 23, 2015 I'm still having Chromecast issues as well, even after updating the server tonight and unplugging the CC for a while. For about 2 weeks now, shows just randomly freeze. I can stop it and restart it again, moving the slider to where I was - this sometimes works, but often the app will just freeze on a black screen. I've noticed that when a show freezes, the android app will be flicking between play/pause, changing every second. I just tested the chromecast speed and getting 26/18, no issues with the test. Here are all the logs from trying to watch Gotham tonight. I gave up after a few freezes and watched the last 5 minuted on my phone. transcode-0b900b70-f80f-41cf-8631-5dddd1445e6b.txt transcode-c885e16e-de9f-4823-a5a7-6af242b89577.txt transcode-25050fa5-18cb-4c55-8b76-b163955dfe98.txt transcode-86b77a35-b666-4f7c-bfce-440c4b07c89e.txt transcode-ba1d0cff-9b00-4fb1-a09c-e2014bfde1c7.txt transcode-a4d1eca8-a41b-48e2-8b73-2d56c99d68a3.txt transcode-789a98da-e8e1-4db1-8a28-e0f03aca4d54.txt transcode-8be67109-f962-40f2-9968-cfdc2118a58b.txt
JeremyFr79 228 Posted April 23, 2015 Posted April 23, 2015 I'm still having Chromecast issues as well, even after updating the server tonight and unplugging the CC for a while. For about 2 weeks now, shows just randomly freeze. I can stop it and restart it again, moving the slider to where I was - this sometimes works, but often the app will just freeze on a black screen. I've noticed that when a show freezes, the android app will be flicking between play/pause, changing every second. I just tested the chromecast speed and getting 26/18, no issues with the test. Here are all the logs from trying to watch Gotham tonight. I gave up after a few freezes and watched the last 5 minuted on my phone. Thats exactly what's been going on with me as well, even the play pause switching back and forth, its like emby server just suddenly stops talking to the chromecast.
JeremyFr79 228 Posted April 24, 2015 Posted April 24, 2015 Ok, so I dropped the bitrate from 6Mbps to 4Mbps last night and watched several episodes of a show. It seemed to work much better doing this. But I don't see that as a fix as I used to be able to stream 10Mbps to chromecast just fine from Emby, and my CC does just fine with higher bitrates from other sources.
jubbynox 0 Posted April 24, 2015 Posted April 24, 2015 Hi, I have been experiencing this problem, too, when casting from the MediaBrowser iPad app. Changing the bitrate in the settings doesn't seem to have any effect on the quality, nor does it solve the problem. Interestingly, if I use a Chromecast enabled browser on the iPad, e.g. CastNow browser, and navigate to the Emby web client, then casting a stream works perfectly at high bitrates. It would appear that the issue is something to do with Emby transcoding specifically for Chromecast; whereas if you cast a stream that is intended for the iPad UIWebView then everything is OK. Is it possible to make Emby use the same transcoding for Chromecast as it does for the iPad web client? If I had the time, I would create an iOS app that is essentially a WKWebView (this will restrict the app to iOS 8+), and then register a WKUserContentController in order to bridge the gap between the JavaScript Chromecast API and the iOS native Chromecast API. Then we can have an app, that is really just the excellent web client, but with Chromecast support!
mdgentile 0 Posted April 28, 2015 Posted April 28, 2015 Wanted to bump this up, still can't play anything via Chromecast. Here are the todays logs. I rebooted the pc and CC before starting. server-63565840216.txt transcode-a7d7904e-9871-4bd2-b98d-13664ba706ff.txt transcode-b981450f-0c0e-4e22-93d7-fafcc6ca8892.txt server-63565839221.txt transcode-c4d48bbc-45eb-44cb-a07a-18018e0f04b5.txt transcode-7876a48a-f710-4c54-976f-1a91a7dbf6c2.txt
FloCdr 0 Posted May 4, 2015 Author Posted May 4, 2015 Well I'm gonna try to bump this up too, because my original problem didn't disappear since my original post... It got better with some updates, and videos only crashed a few seconds before the end, but with the latest update I'm back with even more frustrating freezes and crashes. Tried a lot of tweaking with CC, throttling and capping streaming bitrate ; the issues are never the same but they persist. Here are the logs, if it can help. I'm always here to try some stuff if need be, I'd love Emby to keep working ! server-63566371881.txt transcode-bc97074f-2177-4083-9e0c-4b8f6e43b453.txt server-63566369692.txt transcode-9b92eee7-47d1-470d-bcd3-f4d5768e0c1f.txt transcode-debdfca0-271e-4a8f-bf48-2d74ab14a478.txt transcode-a5f5520a-9b08-40c3-82cd-8d34b073ae0e.txt transcode-531b1fd7-60ef-48cc-82cb-70c75ef2fd3e.txt transcode-acf21df3-6d40-4ef2-94de-ae093404f8ed.txt
Luke 42287 Posted May 4, 2015 Posted May 4, 2015 Well I'm gonna try to bump this up too, because my original problem didn't disappear since my original post... It got better with some updates, and videos only crashed a few seconds before the end, but with the latest update I'm back with even more frustrating freezes and crashes. Tried a lot of tweaking with CC, throttling and capping streaming bitrate ; the issues are never the same but they persist. Here are the logs, if it can help. I'm always here to try some stuff if need be, I'd love Emby to keep working ! let's collect a bit more precise info, such as exact times that issues occurred, and what precisely the issue was. thanks.
mdgentile 0 Posted May 5, 2015 Posted May 5, 2015 Same here, crashing near the end. Happened while watching a movie last night and during Brooklyn 99 just now. With about 45 seconds left, goes to black screen. On the android app, it shows it playing from beginning but nothing but black on the TV. I can stop it and drag the slider to where it was, plays about 10 seconds farther than it did, then black screen again. It did this 3 times in the last 45 seconds of the show. transcode-15becf0c-1524-46af-a893-4b60f9fd8911.txt server-63566358096.txt transcode-145cb807-ca67-42ac-b376-470e6414d4c9.txt transcode-079fcd3f-d154-440f-b1ba-a46a538acd40.txt transcode-4c5c3a92-89df-43e9-9c5a-e38dcdee6ef0.txt transcode-be816531-65bc-4f52-9c73-54f03ee8d27f.txt transcode-6cc07557-7d6e-4b96-bf07-3b3ba54b7c25.txt transcode-b2459e8f-285c-4ec0-bf8f-2a45f9afb6f2.txt transcode-cf63750a-7cef-428f-8996-7deba4a8f591.txt server-63566294412.txt
FloCdr 0 Posted May 7, 2015 Author Posted May 7, 2015 All right, here is a session of Emby server showing the symptoms after 4:02 or so during playback. I experience major freezes, the video is jumping between frames without sound, and sometimes goes back playing for a few seconds before freezing again... Sometimes the screen just goes black and remote control on the server becomes unresponsive. This time it remained active. I've got some time now, if you want me to test anything. server-63566627933.txt transcode-1eee695c-6ad6-49ab-a86a-7e6107eb0d67.txt
Luke 42287 Posted May 7, 2015 Posted May 7, 2015 as a test, i've pushed an update to the Chromecast receiver that will make it behave more like it did a month or so ago. Please reboot your Chromecast device and then give it a shot. Let me know how it goes, and post the transcoding log from that. Thanks.
cskyrme 0 Posted May 8, 2015 Posted May 8, 2015 Fixed! I tried the same clip that always skipped and locked up at the same spots (3 to 4 times within the first minute), and now it works perfectly fine. I had been able to work around by dropping the bit rate to 2.6, but was able to play without issues at 10 and 20 Mbit today. I rebooted by Chromecast, and am currently running Version 3.0.5597.1 of the server, and 2.2.26 of the Android client on a Nexus 6 (5.1) and Nexus 9 (5.0.2). transcode-0fb7273f-7ea4-4ca1-89e9-e46d116a08e3.txt transcode-850600b0-ba95-4657-9c74-b24cb5a3ba76.txt transcode-d66117c0-df07-48c3-b367-45aff68432e8.txt transcode-1d941bd4-da99-4b41-9b4f-7a5e3f6127d7.txt server-63566626607.txt
FloCdr 0 Posted May 8, 2015 Author Posted May 8, 2015 All right, this seems to be fixed for me too ! I'll keep an eye on things to be sure (especiallly using the Android app, which I abandoned for a time because it worked even less...). Thanks anyway, great work. server-63566673484.txt transcode-082f8ff3-8c27-446c-881e-10928ef32ebd.txt
mdgentile 0 Posted May 13, 2015 Posted May 13, 2015 Thought this was fixed for me too, until it started happening 90% of the way through a movie last night. I really want this program to work, and would happily pay for it if it did, but I think I'm going to try something else at this point.
SilentException 6 Posted May 14, 2015 Posted May 14, 2015 Same here, Playback on CC always ends before 100%. Using latest Beta Emby server. From logs I would say that when transcoding job finishes, it deletes the files and the playback stalls. Not sure, logs are now too huge to post, I will do clean logs when home.
