Tranquil 95 Posted April 10, 2015 Posted April 10, 2015 Hello Forum. I'm running MBC on a Windows 7 64 Bit Environment where just these components are installed: - Nvidia Display Drivers - Shark Codec Pack - MST Tool - Daemon Tools Light (without additional Software) - MBC Addon for MCE - DVBLogic Network Client - iMON - Team Viewer Version 10 System behind a firewalled Router, no Ports to these machine are forwarded. The System is only used for TV in our living room. Today I wanted to install latest Windows Updated and also wanted to try to install Kodi. While visiting the Kodi website I noticed a bunch of commercial frames which for sure do not belong to the original kodi website. So I installed a anti virus suit and run a check and found may adWare/ Trojans where I dont know how these programs get their way on my machine. The report of avira antivir starts whit these founds: Beginne mit der Suche in 'C:\' C:\ProgramData\MediaBrowser-Classic\ImageCache\1\1128cada55beca1b9da7596452286af7 [FUND] Enthält Erkennungsmuster des Exploits EXP/MS04-028.JPEG.A C:\ProgramData\MediaBrowser-Classic\ImageCache\5\d52426cfbda1954f4e7006f469728256 [FUND] Enthält Erkennungsmuster des Exploits EXP/MS04-028.JPEG.A I know there was an exploit in GDI+ which was fixed from MS quite a while and because of this, I never installed an antivir on that machine. It seems that there is a problem still somewhere. Many other AdWare/ Trojans found their way on my machine just by running MCE and MBC: C:\Users\MCE-PC\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\LG0VP2AG\setup[1].exe [FUND] Enthält Muster der Software PUA/Somoto.Gen2 C:\Users\MCE-PC\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\SYMLB3NZ\1060-8101_BuzzSurfing[1] [0] Archivtyp: NSIS --> ProgramFilesDir/[PluginsDir]/e.dll [FUND] Enthält Erkennungsmuster der Adware ADWARE/AgentCV.A.37562 [WARNUNG] Infizierte Dateien in Archiven können nicht repariert werden C:\Users\MCE-PC\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\SYMLB3NZ\setup[1].exe [FUND] Enthält Muster der Software PUA/Somoto.hzis C:\Users\MCE-PC\AppData\Local\Temp\lyricsPaltmp.exe [0] Archivtyp: NSIS --> ProgramFilesDir/[PluginsDir]/e.dll [FUND] Enthält Erkennungsmuster der Adware ADWARE/AgentCV.A.37562 [WARNUNG] Infizierte Dateien in Archiven können nicht repariert werden C:\Users\MCE-PC\AppData\Local\Temp\LyricsPal_1060-8101_v122.exe [0] Archivtyp: NSIS --> ProgramFilesDir/Lyrics.exe [FUND] Enthält Erkennungsmuster der Adware ADWARE/Adware.Gen [WARNUNG] Infizierte Dateien in Archiven können nicht repariert werden C:\Users\MCE-PC\AppData\Local\Temp\nsc8989.tmp [FUND] Enthält Muster der Software PUA/Somoto.hzis C:\Users\MCE-PC\AppData\Local\Temp\nsh51E8.tmp [FUND] Enthält Muster der Software PUA/Somoto.hzis C:\Users\MCE-PC\AppData\Local\Temp\nsr3502.tmp [FUND] Enthält Muster der Software PUA/Somoto.Gen2 C:\Users\MCE-PC\AppData\Local\Temp\_appBuzzSurfingR17.exe [0] Archivtyp: NSIS --> ProgramFilesDir/[PluginsDir]/g.dll [FUND] Enthält Erkennungsmuster der Adware ADWARE/Adware.Gen4 [WARNUNG] Infizierte Dateien in Archiven können nicht repariert werden C:\Windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\update[1] [0] Archivtyp: Inno Setup --> {app}\guardsvc.exe [FUND] Ist das Trojanische Pferd TR/Rogue.131920 [WARNUNG] Infizierte Dateien in Archiven können nicht repariert werden --> {app}\lbnjct2.dll [FUND] Ist das Trojanische Pferd TR/Rogue.303952 [WARNUNG] Infizierte Dateien in Archiven können nicht repariert werden --> {app}\notifier.exe [FUND] Enthält Erkennungsmuster der Adware ADWARE/PassionFruit.A [WARNUNG] Infizierte Dateien in Archiven können nicht repariert werden --> {app}\lbwnhk.dll [FUND] Ist das Trojanische Pferd TR/Dldr.Agent.hexg.8 [WARNUNG] Infizierte Dateien in Archiven können nicht repariert werden --> {app}\getvmname.exe [FUND] Ist das Trojanische Pferd TR/Rogue.86352 [WARNUNG] Infizierte Dateien in Archiven können nicht repariert werden C:\Windows\Temp\INJ001\ExtensionUpdate.exe [0] Archivtyp: Inno Setup --> {app}\guardsvc.exe [FUND] Ist das Trojanische Pferd TR/Rogue.131920 [WARNUNG] Infizierte Dateien in Archiven können nicht repariert werden --> {app}\lbnjct2.dll [FUND] Ist das Trojanische Pferd TR/Rogue.303952 [WARNUNG] Infizierte Dateien in Archiven können nicht repariert werden --> {app}\notifier.exe [FUND] Enthält Erkennungsmuster der Adware ADWARE/PassionFruit.A [WARNUNG] Infizierte Dateien in Archiven können nicht repariert werden --> {app}\lbwnhk.dll [FUND] Ist das Trojanische Pferd TR/Dldr.Agent.hexg.8 [WARNUNG] Infizierte Dateien in Archiven können nicht repariert werden --> {app}\getvmname.exe [FUND] Ist das Trojanische Pferd TR/Rogue.86352 [WARNUNG] Infizierte Dateien in Archiven können nicht repariert werden Anyone else with these kind of problems?
