drashna 47 Posted April 9, 2015 Posted April 9, 2015 Using a reverse proxy to access MediaBrowser. Using MediaBrowser Server 3.0.5572.0 on Windows Server 2012R2 Essentials, using IIS (and Application Request Routing and URL Rewrite) as the reverse proxying. Any time I access the server remotely (and only remotely), it gives the the above error. access occurred at 10PM PDT (GMT -7), and a few times later. server-63564081195.zip
drashna 47 Posted April 10, 2015 Author Posted April 10, 2015 This actually appears to be fixed in the dev builds, as it works fine on them.
pir8radio 1313 Posted April 11, 2015 Posted April 11, 2015 Check your setting under ARR/Proxy settings "Include TCP port from client IP" checkbox
drashna 47 Posted April 11, 2015 Author Posted April 11, 2015 Check your setting under ARR/Proxy settings "Include TCP port from client IP" checkbox That's included, and has been the entire time. Nothing changed with the IIS server settings. The only thing that had changed was that I update the Emby Server. And as I said above, the dev builds seems to have fixed the issue.
pir8radio 1313 Posted April 12, 2015 Posted April 12, 2015 (edited) That's included, and has been the entire time. Nothing changed with the IIS server settings. The only thing that had changed was that I update the Emby Server. And as I said above, the dev builds seems to have fixed the issue. Try to uncheck it... see if the problem is still there... I had to on my setup as well... even though nothing changed on our end something did on the emby end this fixed it for me. Just sayin' Edited April 12, 2015 by pir8radio
