Ballistic 8 Posted April 8, 2015 Posted April 8, 2015 Hi All, I recently updated to Mediabrowser 3.0.5518.7. This is the latest version available in the ports/pkg repository. (ports/pkgs up to date but no emby port/package is known) Since the upgrade, MB has become very slow in browsing. Loading pages takes 5 to 10 seconds each. Images take a long time to retrieve. Also updating the libary only works when MB is started. Manual/automatic refresh no longer works. It stays on 0%. Logs: 2015-04-08 21:32:17.0722 Info - App: Executing Scan media library Thats it really. Nothing more happends. Does anyone have any idea?
josh4trunks 70 Posted April 8, 2015 Posted April 8, 2015 the emby-server port/package should be available soon. what version of mono are you on? I think it doesn't work well on 3.12+
kjp4756 41 Posted April 8, 2015 Posted April 8, 2015 Yeah don't use anything other than mono 3.10. I had big problems with 3.12 on my system. It took me a while to figure out how to downgrade to a specific version of a port. If you need a package for the last mono 3.10 I can upload it some where.
Ballistic 8 Posted April 9, 2015 Author Posted April 9, 2015 I am running mono-3.12.1_1 now so that might explain things. Even with a clean database, mediabrowser is very sluggish and scanning takes hours. kjp4756: It would be great if you could upload the mono 3.10 package somewhere.
kjp4756 41 Posted April 9, 2015 Posted April 9, 2015 https://drive.google.com/file/d/0B3TzI9suqxcwZmpWaVJ4SXFHdjA/view?usp=sharing Delete your current mono with 'pkg delete -f mono' Install package with 'pkg add mono-3.10.0_2.txz' Then do a 'pkg lock mono' to prevent mono from being updated Hopefully it works for you. 1
Ballistic 8 Posted April 10, 2015 Author Posted April 10, 2015 Thanks alot mate. I reinstalled Mediabrowser with a clean library and re-imported my library and weird enough it is running alot better now. Running Mono 3.12. If i still encounter issues i will let you know and then i will also try your Mono 3.10 package.
