computerprep 149 Posted June 20, 2016 Posted June 20, 2016 I wonder if auto organize could store the intended folder, the way you can save series name mismatches? That way you could delete the whole folder and the auto organize would remember where those episodes are intended to be saved next season.
ebr 16337 Posted June 20, 2016 Posted June 20, 2016 I think you are going off on a tangent here. This request isn't to delete anything. It is purely a display option. Automatic deletion of things is a whole other can of worms and I think we'd need to be very careful with any such functionality but you are welcome to create a new feature request.
Koleckai Silvestri 1154 Posted June 20, 2016 Posted June 20, 2016 I think it would be much easier to look at a folder, determine if there are any videos in it. If not, don't display in the interface. No need to remember anything in Auto Organize or delete anything from the server. 2
fraenhawk 61 Posted June 20, 2016 Posted June 20, 2016 I think it would be much easier to look at a folder, determine if there are any videos in it. If not, don't display in the interface. No need to remember anything in Auto Organize or delete anything from the server. That's actually how it used to work
mrees 6 Posted June 21, 2016 Posted June 21, 2016 That's actually how it used to work Out of curiosity, why was the feature removed? It seems funny to add seasons and shows based on directory structures and not actual files (just my 2c)
Deihmos 170 Posted June 21, 2016 Posted June 21, 2016 Out of curiosity, why was the feature removed? It seems funny to add seasons and shows based on directory structures and not actual files (just my 2c) Video files get removed but the folders remain. Luckily Kodi does not show empty folders
ebr 16337 Posted June 21, 2016 Posted June 21, 2016 Out of curiosity, why was the feature removed? Performance. The feature only ever existed in the WMC client and determining whether or not a folder is empty from the client side was a potentially very expensive operation. That function rightfully belongs in the server. Thus this feature request. 2
mrees 6 Posted June 21, 2016 Posted June 21, 2016 Performance. The feature only ever existed in the WMC client and determining whether or not a folder is empty from the client side was a potentially very expensive operation. That function rightfully belongs in the server. Thus this feature request. Thanks ebr. Appreciate the info
JoshuaAJones 69 Posted June 23, 2016 Posted June 23, 2016 The feature used to work flawlessly in the Android app (which is why I continued to suggest porting its filters into the ET or the Server). Now, it doesn't even work. I'm not sure how much extra effort it would take (performance-wise) as the green circles already show up. If it doesn't have a green ball, it's empty. If the green ball has a check, you're caught up. If the green ball has a number, you've still got some shows to watch. I want options to Hide the green balls without Numbers so that I only see the folders I need to see.
Luke 42245 Posted June 23, 2016 Posted June 23, 2016 The feature used to work flawlessly in the Android app (which is why I continued to suggest porting its filters into the ET or the Server). Now, it doesn't even work. I'm not sure how much extra effort it would take (performance-wise) as the green circles already show up. If it doesn't have a green ball, it's empty. If the green ball has a check, you're caught up. If the green ball has a number, you've still got some shows to watch. I want options to Hide the green balls without Numbers so that I only see the folders I need to see. No, the android app never had support for hide empty folders.
JoshuaAJones 69 Posted June 27, 2016 Posted June 27, 2016 Although it did not have a "Hide Empty" option, it did have the "Show Unwatched" option. This essentially did the same thing. I'm still having to scan through 150+ shows to find new shows to watch.
computerprep 149 Posted June 27, 2016 Posted June 27, 2016 Although it did not have a "Hide Empty" option, it did have the "Show Unwatched" option. This essentially did the same thing. I'm still having to scan through 150+ shows to find new shows to watch. I'm pretty sure they know that these filter settings (see screenshot below) aren't working... but once they're fixed, they should help out your situation immensely.
Luke 42245 Posted June 27, 2016 Posted June 27, 2016 they are working for media items but just not folders at the moment.
JoshuaAJones 69 Posted June 30, 2016 Posted June 30, 2016 Either way, I am anxiously waiting there porting into the ET app as this is my main viewer. I only use the Android app while casting when on vacations.
pajo2000 1 Posted August 21, 2017 Posted August 21, 2017 (edited) What happened to this? (out of topic) I've noticed that when you use the "merge series that are spread across multiple folders" feature, it still leaves an extra copy of a 'single episode'-folder. Meaning that it merges the season all nice, but leaves the left over folder out along with folders that doesn't contain any media at all (marking them as viewed) Edited August 21, 2017 by pajo2000
Luke 42245 Posted August 21, 2017 Posted August 21, 2017 It's something we'd like to look at for a future update, thanks.
Inodder 0 Posted August 21, 2017 Posted August 21, 2017 If I understand correct even after 2 and a half years the "hide empty folder" option still isn't fixed nor is there a working alternative. I thought it would be implemented server side. Why not release a version with the original option that worked perfectly for everyone here. Let people who have problems choose the other version. Don't think I'll ever come back to emby as I don't believe it will ever be fixed after all this time. Big disappointment.
wizbowes 4 Posted October 11, 2017 Posted October 11, 2017 PLEASE can you look at this. I have 166 folders, of which about 20 have episodes in them. The interface is an absolute mess of folders with no content.
rigo8582 16 Posted November 18, 2017 Posted November 18, 2017 (edited) I would be very appreciative if this feature was in emby theater. Edited February 4, 2018 by rigo8582
Dibbes 515 Posted December 6, 2017 Posted December 6, 2017 Just out of curiousity, what's the reason for keeping empty folders anyway?
fraenhawk 61 Posted December 7, 2017 Posted December 7, 2017 If you don't keep all episodes of a show on your server and you're between seasons you delete the season folder but not the main show folder.
Dibbes 515 Posted December 8, 2017 Posted December 8, 2017 If you don't keep all episodes of a show on your server and you're between seasons you delete the season folder but not the main show folder. I would just move this folder to another "Series" folder that would not be part the library. Since Emby is not automatically downloading, you have a few manual actions once the next season starts anyway.
JeffWScott 2 Posted March 6, 2018 Posted March 6, 2018 (edited) Ugh... Just came over from Plex, loving emby so far.. Except this issue. Shoot i guess nothing is perfect. Edited March 6, 2018 by ebr Edited for language
