Luke 42239 Posted July 19, 2015 Posted July 19, 2015 Can someone tell me where the log file for emby is located? I am having an issue with my tuners showing up. it's displayed on the front page of the server dashboard.
Tolotos 61 Posted July 19, 2015 Author Posted July 19, 2015 Hi What profile settings do I need in TVH for my emby user - streaming, advanced streaming etc... thx Hi, you need to set check all but not admin. -- Tolotos
Tolotos 61 Posted July 19, 2015 Author Posted July 19, 2015 Can someone tell me where the log file for emby is located? I am having an issue with my tuners showing up. Hi, tuners are not listed as tvheadend delivers the tuner information as one streing together with the current channel name and there is now way to device the both correctly for all tuners. -- Tolotos
Luke 42239 Posted July 20, 2015 Posted July 20, 2015 Hi, As I wrote in post 92 this issue can not be solved through the plugin. Emby code must be changed to send an user agent in the HTTP header. http://logos.xmltv.se changed their service to bann requests without this meta data. -- Tolotos Assuming any user agent is OK, then I'm updating the core to provide one. If needs a specific value though then I'd rather just give you a way to specify it.
Tolotos 61 Posted July 20, 2015 Author Posted July 20, 2015 Hi @@Luke, I tried "Emby" as user agent and it worked with the logos.xmltv.se site. But using an existing user agent string would make it harder to ban emby. Making it configurable like "Existing user agent / own string" would be nice. -- Tolotos
KRA 39 Posted July 25, 2015 Posted July 25, 2015 Icons from xmltv.se confirmed working in DEV version of Emby server.
KRA 39 Posted July 25, 2015 Posted July 25, 2015 I have several recordings listed as "active recordings" that have finished days and weeks ago. I think this issue started after installing tvheadend version 4.0.4. So far I've tried reset both emby and tvheadend server, upgraded emby to dev version and upgraded tvheadend to version 4.0.5. Problem remains.
nague 5 Posted September 9, 2015 Posted September 9, 2015 (edited) I'm trying tvheadend plugin (1.0.5628) with TVheadend 4.0.5-21. Connection looks ok as I can read the following status on the “Live TV” parameter page: HTS Tvheadend 4.0.5-21~gd8bd6fb HTSP protokoll version: 20 Free diskspace: 35GB / 38GB À jour! Etat: Ok But the "Refresh Guide Data" button is not present. On TVHeadend "Connections” Page, I can see a running HTSP Connection for Emby as well. My issue is that Emby is not showing any Live TV channel... And TV guide is empty. Did I miss something ? By the way, TVHeadend and Kodi are working perfectly together... And I correctly filled channel tags (HDTV, SDTV) and numbers. Edited September 9, 2015 by nague
gstuartj 40 Posted September 9, 2015 Posted September 9, 2015 (edited) I'm trying tvheadend plugin (1.0.5628) with TVheadend 4.0.5-21. Connection looks ok as I can read the following status on the “Live TV” parameter page: Did I miss something ? It's awesome that we have the TvHeadend plugin now, but it doesn't support the unstable 4.x branch of TVH. It's also only been tested with stable versions up to 3.4.27 as far as I know. I'm currently having the same issue with 3.4.28, actually, though I'm pretty sure it was working fine on this version before. It can be made to work, but between the issues with the TVH project itself, the Emby plugin developer's time limitations, etc, if I were recommending a live TV setup to a Linux user today I might have to tell them to just buy an HDHomerun. It's the most popular and has the best support. Edited September 9, 2015 by gstuartj
im85288 1493 Posted September 9, 2015 Posted September 9, 2015 Working fine for 3.9 iterations of TV HeadEnd...but maybe good advice above although I'm not so sure how applicable that is for users in Europe/UK as there still seems to not be a device from HDHomeRun capable of running the DVB-S2 network 1
nague 5 Posted September 10, 2015 Posted September 10, 2015 (edited) @gstuartj @im85288 Thanks for your answers. I'll give a try with TVH 3.9 branch and i'll wait patiently for the 4.x support. Edited September 10, 2015 by nague
KRA 39 Posted September 11, 2015 Posted September 11, 2015 isn't 4.0 from stable branch now ? I get version 4.x from tvheadends ubuntu stable repository.
Tolotos 61 Posted September 13, 2015 Author Posted September 13, 2015 (edited) isn't 4.0 from stable branch now ? I get version 4.x from tvheadends ubuntu stable repository. @@KRA I'm planning to update my TV-server to the stable 4.0.x tvheadend release in the next weeks. After this I'll start to implement the HTSP version 20 which is the base of the 4.x releases. The current plugin uses HTSP version 10. At opening the connection the client (my plugin) sends his HTSP version to the server and he should (tvheadend documentation) response with the highest possible HTSP version both can use to communicate. Therefore the result from the 4.x servers should be 10 and not 20 as in the above posts is written. This looks like another issue the tvheadend guys don't implement what they wrote in the documentation. -- Tolotos Edited September 13, 2015 by Tolotos 1
KRA 39 Posted September 19, 2015 Posted September 19, 2015 thanks for update Tolotos, I was afraid you had abandoned the project.
Dan64 32 Posted October 2, 2015 Posted October 2, 2015 (edited) @@KRA I'm planning to update my TV-server to the stable 4.0.x tvheadend release in the next weeks. After this I'll start to implement the HTSP version 20 which is the base of the 4.x releases. The current plugin uses HTSP version 10. At opening the connection the client (my plugin) sends his HTSP version to the server and he should (tvheadend documentation) response with the highest possible HTSP version both can use to communicate. Therefore the result from the 4.x servers should be 10 and not 20 as in the above posts is written. This looks like another issue the tvheadend guys don't implement what they wrote in the documentation. -- Tolotos Dear Tolotos Thanks for your plugin it is very useful. At the beginning I started with the version 4.1 of TVH, but I had a lot of problems to having the tv-turner working and also your plugin was not working. Reading your post I have discovered that actually your plugin works ony for the version 3.4.x of TVH. Unfortunately your comment on the first release of plugin states that it is working for the version 4.3.x of TVH, I guess that you inverted the first 2 digit (see attached screenshot). Beside that I'm very happy now with the version 3.4.27 of TVH. It is very stable I was able to quickly configure the TV-turner, now TVH is able to scan the channelds and discover all the services while doing that with the version 4.1 was a problem. My impression is that the version 4.x is still unstable and that all the features of the version 3.4 has not been fully ported yet or has not been well tested. My suggestion to the users that want install THV is to stay with the version 3.4 till the version 4.x becomes more stable, if the new features implemented in the 4.x are not really necessary. If you are planning to upgrade the plugin to work with the version 4.x please pay attention to not broke the compatibility with the version 3.4.27 since I think to use it for a lot of time... Thanks Edited October 2, 2015 by Dan64
KRA 39 Posted October 3, 2015 Posted October 3, 2015 @@Dan64 One should keep in mind that 4.1 is "unstable" branch, and 4.0.5 is considered stable. You went tried the development branch, you will most likely run into problems, although I've ran development for a long time before 4.0 was released and had minimal issues. Also the DVB backend is completely rewritten from 3.4 to 4.0, as such installing 3.4 is not an option for me since it don't even support all my tuners. And I believe this is the case for several new tuners, maybe also issue for network tuners ?
rubenverhoef 11 Posted October 6, 2015 Posted October 6, 2015 no channels, nothing... connection is okay: Externe diensten TVHclient HTS Tvheadend 3.9.20140806-6d19440 HTSP protokoll version: 12 Free diskspace: 53046GB / 55094GB Up to date! Status: Ok i see nothing special in the logs (see attached) Screen of tvheadend: Screen emby: Log.txt
rubenverhoef 11 Posted October 7, 2015 Posted October 7, 2015 no channels, nothing... connection is okay:Externe diensten TVHclient HTS Tvheadend 3.9.20140806-6d19440 HTSP protokoll version: 12 Free diskspace: 53046GB / 55094GB Up to date! Status: Ok i see nothing special in the logs (see attached) Screen of tvheadend: Screen emby: Woow! after one day it works... strange..
rubenverhoef 11 Posted October 9, 2015 Posted October 9, 2015 now i updated tvheadend with some logos but emby isn't updating it i wait 2 days
im85288 1493 Posted October 9, 2015 Posted October 9, 2015 Emby caches the logos locally so does not pick up the changes @@Luke is aware of this. The only way I managed to get it to refresh my logos was with a fresh install of Emby.
Antropy 3 Posted October 23, 2015 Posted October 23, 2015 Hi, I am testing to replace my old Mediaportal backend with TVHeadend and this very nice Plugin actually. It is working great so far aside from I have no thumbnails for the recordings within emby? Is there something i can change to get this thumbnails generated?
nague 5 Posted October 23, 2015 Posted October 23, 2015 @Antropy No thumbnails for me neither. I've just added new channels in tvheadend but I can't manage to refresh channel list in emby... Any idea? I've waited 2 days already ;-)
Tolotos 61 Posted October 23, 2015 Author Posted October 23, 2015 I've just added new channels in tvheadend but I can't manage to refresh channel list in emby... Any idea? I've waited 2 days already ;-) Are the new channels tagged with the correct values (SDTV,HDTV,Radio) ?
