freebs 2 Posted May 22, 2015 Posted May 22, 2015 anyone running this under Ubuntu trusty ? I get no guide no channels... Status says ok and Up to date! HTS Tvheadend 3.9.2827~g477feab~trusty HTSP protokoll version: 20 Free diskspace: 388GB / 450GB Up to date! Status: Ok
Tolotos 61 Posted May 23, 2015 Author Posted May 23, 2015 @@freebs Only channels with a number (no character or space) are displayed. Please check if you have setup channel number in the tvheadend configuration page.
freebs 2 Posted May 23, 2015 Posted May 23, 2015 (edited) you mean the name or the number.. my numbers are just that, but channel names are a combo of both. Edited May 23, 2015 by freebs
freebs 2 Posted May 23, 2015 Posted May 23, 2015 (edited) Sure .. any help appreciated. here it is. Emby_server_log Thanks alot! Edited May 23, 2015 by freebs
Tolotos 61 Posted May 24, 2015 Author Posted May 24, 2015 @@freebs I think I identified the problem. Can you please check the attached version. Please let me know if solves your problem so I can release this change to the catalog. - Tolotos TVHeadEnd.zip
freebs 2 Posted May 24, 2015 Posted May 24, 2015 (edited) new to Emby, how would I install this... I copied the dll to plugin folder.. where does the pbd file go ? Thanks! I see, it's a backup file created in Windows. I guess I have no need for it. latest version you gave me 1.0.5604.36619 gives the same result, if I'm correct about the install. I can see my recordings and that's all. here is the latest log with your version of tvHeadEnd. Log Edited May 24, 2015 by freebs
Tolotos 61 Posted May 24, 2015 Author Posted May 24, 2015 @@freebs Please copy both files of the attached version into the Plugins folder and post the log. The .pdb files contains debug informations. TVHeadEnd.zip
freebs 2 Posted May 24, 2015 Posted May 24, 2015 (edited) ok gotcha.. here is the newest log with both those files in the plugin folder. Emby_Server_log 11:25AM Thanks bud! Edited May 24, 2015 by freebs
Tolotos 61 Posted May 24, 2015 Author Posted May 24, 2015 (edited) @@freebs The log doesn't contain my new logging. But I found this line: 2015-05-24 11:22:18.3505 Info - App: New plugin installed: TVHeadEnd 1.0.5607.25877 Release This means Emby is overriding the manual copied newer version with the latest of the catalog. I uploaded the dll as a DEV build into the catalog. Please choose the DEV version from the plugin catalog and try again. - Tolotos Edited May 24, 2015 by Tolotos
freebs 2 Posted May 24, 2015 Posted May 24, 2015 (edited) Oh nice.. further along.. Guide is now populated along with the icons .. awesome !! Channels all show but they won't play anything.. SD or HD. here is my log ... Emby_log Used google drive.. pastbin/hastebin both say it's too long. Oh and my Tuner still doesn't show. I'm using a Skywalker-1 USB Tuner. perhaps that might be a reason for no channel. Also in TvHeadend.. I see no client "test" connecting at all. Here is my transcode log as well. See server error returned here. Thanks again for all this - I owe you a beer or two or three lol. Edited May 24, 2015 by freebs
Tolotos 61 Posted May 24, 2015 Author Posted May 24, 2015 (edited) @@freebs Ok, I see 39 channels which has no service information (HDTV, SDTV or Radio) these channels are skipped. The tuner list in Emby is not filled up by the plugin as different TV-cards are delivering the data in a not deterministic format. The tuner info is mixed up from tvheadend with the channel info and there is no possibility to check when the tuner info ends and the channel info starts. The error on playback is a http 503 error from your tvheadend server. Emby is calling e.g. http://localhost:9981/stream/channelid/1479537393?ticket=63DA09DAA89E1761B13509608E6586FA7523289B which results in the 503. For his error you must open a call the tvheadend forum. I'll releasing a new release version of the plugin with the same functionality but without the excessive logging in a few minutes. Please update to this version to save lots of space on your hard drive. EDIT: version 1.0.5622.32968 (RELEASE) is online now -- Tolotos Edited May 24, 2015 by Tolotos
MrGrymReaper 0 Posted May 28, 2015 Posted May 28, 2015 How would I go about setting up and installing this plugin under Debian Linux 8.0 please?
gstuartj 40 Posted May 29, 2015 Posted May 29, 2015 (edited) Hi @@Tolotos, thanks for the work you've put into the TVHeadend plugin. I've been anticipating the release of a Linux PVR plugin and it's much appreciated. I, too, am running into an issue where I get nothing but a blank guide and channel list. I was hoping you could help me troubleshoot. On startup the plugin is loaded successfully and starts importing the channels, but fails and leaves an error like the following in the log for each channel. 2015-05-29 10:33:19.7211 Error - App: [TVHclient] ChannelDataHelper: unkown service type 'Other'. 2015-05-29 10:33:19.7211 Error - App: [TVHclient] ChannelDataHelper: unable to detect service-type from service list: HTSMessage: <dump> channelId : 11 channelNumber : 110 channelName : ABC - WCPO eventId : 10120 nextEventId : 10122 services : HTSMessage: <dump> name : Kworld USB/521,028 kHz type : Other </dump> , tags : method : channelAdd </dump> In TVHeadend all services were automatically added with the default type of "Other (0x0000)," I have not changed this from the defaults, and it seems to work fine with Kodi. Is this a problem I need to correct in my TVHeadend configuration, or is it a bug in the plugin? Thanks Edited May 29, 2015 by gstuartj
gstuartj 40 Posted May 29, 2015 Posted May 29, 2015 Looks like the switch block starting on line 151 in DataHelper/ChannelDataHelper.cs is missing a case for "Other." I'd patch it and do a pull request, but I don't know enough about TVHeadend to say with certainty whether "Other" should always be assumed to be a TV channel. (Nor do I have a .NET build environment set up.)
Tolotos 61 Posted May 30, 2015 Author Posted May 30, 2015 (edited) @@gstuartj Please test the new dev version 1.0.5628.29938 in the catalog. There is a new setting for the channel type to use for 'Other'. But the best way is to set the correct channel type in tvheadend. -- Tolotos Edited May 30, 2015 by Tolotos 1
gstuartj 40 Posted May 30, 2015 Posted May 30, 2015 @@Tolotos Dev release 1.0.5628.29938 is working great with the new setting, thanks! But the best way is to set the correct channel type in tvheadend. Agreed, though I'm still unsure of how to go about doing so. I didn't find a way to set the service type in TVHeadend after detection. I also suspect this could be a rare edge case relating to my cheap USB tuner or something. Thanks again for updating it.
gstuartj 40 Posted May 30, 2015 Posted May 30, 2015 (edited) @@Tolotos I spoke a little too soon. The guide and channel lists are all being populated correctly now, but all services are being imported as SD channels rather than HD. This results in HD channels being cropped to 4:3 during transcoding. I do have a mix of SD and HD services, all of which are tagged "Other." If they were all imported as HD would Emby handle an SD stream gracefully? If not then that could complicate this. In the meantime I'll ask around about changing service types within TVHeadend. Update: My mistake Edited May 30, 2015 by gstuartj
gstuartj 40 Posted May 30, 2015 Posted May 30, 2015 (edited) According to the TvHeadend docs: TypeType of service [as given in the DVB stream]. Can not be changed Seems changing that field would require patching TvHeadend to work in an unintended way. Edited May 30, 2015 by gstuartj
Tolotos 61 Posted May 30, 2015 Author Posted May 30, 2015 (edited) Thank for the response. I made it now a official release. You should be able to create "Channel Tags" in the TVHeadend configuration page. My plugin works with "SDTV", "HDTV" and "Radio". These tags can be assigned to the channels. EDIT: SD and HD TV are not divided by Emby. The transcoding service will recognize the correct type. -- Tolotos Edited May 30, 2015 by Tolotos
gstuartj 40 Posted May 30, 2015 Posted May 30, 2015 (edited) EDIT: SD and HD TV are not divided by Emby. The transcoding service will recognize the correct type. -- Tolotos You're right. I thought that was true from my glance at the code, but I was still getting SD content. Turns out I was just being dumb. There was paid programming on two of my HD test channels that was being broadcast in 4:3. Sorry! Thanks again for the help. Edited May 30, 2015 by gstuartj 1
freebs 2 Posted June 3, 2015 Posted June 3, 2015 I am still getting 503 errors trying to connect - I upgraded to 4.0.4-5 hoping it was tvheadened error. I've noted below the username when using dvr, which works perfectly fine. Can you tell me what that means? Jun 2 20:06:28 HTPC tvheadend[1191]: http: 127.0.0.1: using ticket 22C345D8FB9D90861BEEB71CA883498C5A79526A for /dvrfile/1711558383 Jun 2 20:06:28 HTPC tvheadend[1191]: subscription: 0039: "HTTP" unsubscribing, hostname="127.0.0.1", username="Lavf/56.25.101" Jun 2 20:06:28 HTPC tvheadend[1191]: http: 127.0.0.1: using ticket 22C345D8FB9D90861BEEB71CA883498C5A79526A for /dvrfile/1711558383 Jun 2 20:06:38 HTPC tvheadend[1191]: subscription: 003A: "HTTP" unsubscribing, hostname="127.0.0.1", username="Lavf/56.25.101" P.S I've posted on tvheadend forums and have never gotten a reply.
