Iorifly 15 Posted April 5, 2018 Posted April 5, 2018 Luke, I'm also not. But, I already configured the user to enter password etc. But I get these msg. I changed user view: 2018-04-05 18:51:02.183 htsp: Got connection from 192.168.1.20 2018-04-05 18:51:02.203 htsp: 192.168.1.20: Identified as user 'admin' (unverified) 2018-04-05 18:51:02.204 htsp: 192.168.1.20 [ admin ]: Welcomed client software: TVHclient4Emby-3.3.1.0 (HTSPv20) 2018-04-05 18:51:02.212 htsp: 192.168.1.20 [ admin | TVHclient4Emby-3.3.1.0 ]: Identified as user 'admin' 2018-04-05 18:51:02.213 htsp: 192.168.1.20 [ admin | TVHclient4Emby-3.3.1.0 ]: Privileges updated
Gerrit507 24 Posted April 5, 2018 Posted April 5, 2018 (edited) Luke, I'm also not. But, I already configured the user to enter password etc. But I get these msg. I changed user view: 2018-04-05 18:51:02.183 htsp: Got connection from 192.168.1.20 2018-04-05 18:51:02.203 htsp: 192.168.1.20: Identified as user 'admin' (unverified) 2018-04-05 18:51:02.204 htsp: 192.168.1.20 [ admin ]: Welcomed client software: TVHclient4Emby-3.3.1.0 (HTSPv20) 2018-04-05 18:51:02.212 htsp: 192.168.1.20 [ admin | TVHclient4Emby-3.3.1.0 ]: Identified as user 'admin' 2018-04-05 18:51:02.213 htsp: 192.168.1.20 [ admin | TVHclient4Emby-3.3.1.0 ]: Privileges updated At General -> Base -> HTTP Server Settings change Authentication type to "Plain (insecure)" or "Both Plain and digest". This was necessary for something. I think it was the logos... Then navigate to Users -> Access Entries and make sure that the user has Streaming at least "HTSP" and Video Recorder at least "Basic" and "View all". I would just check everything though to be sure... then it should work in theory... Edited April 5, 2018 by Gerrit507
Iorifly 15 Posted April 5, 2018 Posted April 5, 2018 Use HTTP Digest Authentication: Unchecked in the user part : same problem 2018-04-05 20:24:49.583 htsp: Got connection from 192.168.1.20 2018-04-05 20:24:49.617 htsp: 192.168.1.20: Identified as user 'admin' (unverified) 2018-04-05 20:24:49.617 htsp: 192.168.1.20 [ admin ]: Welcomed client software: TVHclient4Emby-3.3.1.0 (HTSPv20) 2018-04-05 20:24:49.626 htsp: 192.168.1.20 [ admin | TVHclient4Emby-3.3.1.0 ]: Identified as user 'admin' 2018-04-05 20:24:49.626 htsp: 192.168.1.20 [ admin | TVHclient4Emby-3.3.1.0 ]: Privileges updated
Gerrit507 24 Posted April 6, 2018 Posted April 6, 2018 (edited) Use HTTP Digest Authentication: Unchecked in the user part : same problem 2018-04-05 20:24:49.583 htsp: Got connection from 192.168.1.20 2018-04-05 20:24:49.617 htsp: 192.168.1.20: Identified as user 'admin' (unverified) 2018-04-05 20:24:49.617 htsp: 192.168.1.20 [ admin ]: Welcomed client software: TVHclient4Emby-3.3.1.0 (HTSPv20) 2018-04-05 20:24:49.626 htsp: 192.168.1.20 [ admin | TVHclient4Emby-3.3.1.0 ]: Identified as user 'admin' 2018-04-05 20:24:49.626 htsp: 192.168.1.20 [ admin | TVHclient4Emby-3.3.1.0 ]: Privileges updated Does the user admin have HTSP at Transmissao? Can you play recordings over emby? The login seems to work: "Identified as user admin" What's in the emby log when you try to play a channel? Edited April 6, 2018 by Gerrit507
Iorifly 15 Posted April 6, 2018 Posted April 6, 2018 (edited) I could not isolate the moment of play .... log https://pastebin.com/hqhJ5Mfm even if I remove the m3u list. restart the emby, then install the plugin, restart the emby ..... osb: the plugin is already set up ..... does not work Edited April 6, 2018 by Iorifly
Iorifly 15 Posted April 6, 2018 Posted April 6, 2018 I will not use the emby at the moment ... I will follow the topic for news.
Luke 42241 Posted April 6, 2018 Posted April 6, 2018 I will not use the emby at the moment ... I will follow the topic for news. I would suggest trying this: https://emby.media/community/index.php?/topic/20107-tvheadend-plugin-for-emby-beta-1/?p=564300 1
Gerrit507 24 Posted April 6, 2018 Posted April 6, 2018 I could not isolate the moment of play .... log https://pastebin.com/hqhJ5Mfm This shows me you are not using the tvheadend plugin, instead you are trying to access some m3u file. 2018-04-05 22:10:34.889 Info App: Opening channel stream from Emby, external channel Id: m3u_7127376751fdc301c8ceb2cb4a6744edbdc64e03063d97df7b9d27d9b79df5e2 2018-04-05 22:10:34.897 Info App: Streaming Channel m3u_7127376751fdc301c8ceb2cb4a6744edbdc64e03063d97df7b9d27d9b79df5e2 2018-04-05 22:10:34.923 Error HttpServer: Error processing request *** Error Report *** Version: 3.3.1.0 Command line: C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: False 64-Bit Process: False User Interactive: True Processor count: 4 Program data path: C:\Users\angel\AppData\Roaming\Emby-Server Application directory: C:\Users\angel\AppData\Roaming\Emby-Server\system MediaBrowser.Controller.LiveTv.LiveTvConflictException: Exception of type 'MediaBrowser.Controller.LiveTv.LiveTvConflictException' was thrown. at Emby.Server.Implementations.LiveTv.TunerHosts.BaseTunerHost.<GetChannelStream>d__18.MoveNext() If you would have configured everything correctly it would open a http stream like this: 2018-04-06 02:38:43.679 Info LiveTvMediaSourceProvider: Live tv media info probe took 0.0023347 seconds 2018-04-06 02:38:43.679 Info LiveTvMediaSourceProvider: Live stream info: {"Protocol":"Http","Id":"1","Path":"http://192.168.179.11:9981/stream/channelid/1220117866?ticket=76096418c099ad5cd03d51e5db50c4d26f826ed8","Type":"Default","Container":"mpegts","IsRemote":false,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":true,"LiveStreamId":"41c95b6de5174f82acbc56fe82d0a2f8_1","RequiresLooping":false,"SupportsProbing":true,"MediaStreams":[{"Codec":"h264","TimeBase":"1/90000","CodecTimeBase":"1/50","DisplayTitle":"1080I H264","NalLengthSize":"0","IsInterlaced":true,"BitRate":20000000,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":25,"RealFrameRate":50,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":40,"IsAnamorphic":false},{"Codec":"ac3","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Dolby Digital stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"Formats":[],"Bitrate":20192000,"RequiredHttpHeaders":{},"AnalyzeDurationMs":3000} 2018-04-06 02:38:43.679 Debug MediaSourceManager: Live stream opened: {"Protocol":"Http","Id":"1","Path":"http://192.168.179.11:9981/stream/channelid/1220117866?ticket=76096418c099ad5cd03d51e5db50c4d26f826ed8","Type":"Default","Container":"mpegts","IsRemote":false,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":true,"LiveStreamId":"a17c75760a04e99b68cf766e11316e1c_41c95b6de5174f82acbc56fe82d0a2f8_1","RequiresLooping":false,"SupportsProbing":true,"MediaStreams":[{"Codec":"h264","TimeBase":"1/90000","CodecTimeBase":"1/50","DisplayTitle":"1080I H264","NalLengthSize":"0","IsInterlaced":true,"BitRate":20000000,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":25,"RealFrameRate":50,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":40,"IsAnamorphic":false},{"Codec":"ac3","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Dolby Digital stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"Formats":[],"Bitrate":20192000,"RequiredHttpHeaders":{},"AnalyzeDurationMs":3000} I don't know what you were doing there but you're not acessing tvheadend over the plugin, you just try to access some m3u file that doesn't exist. 1
Gerrit507 24 Posted April 6, 2018 Posted April 6, 2018 I would suggest trying this: https://emby.media/community/index.php?/topic/20107-tvheadend-plugin-for-emby-beta-1/?p=564300 It looks like he is doing it via m3u but the path is just incorrect or whatever. This issue has actually nothing to do with the plugin...
Iorifly 15 Posted April 6, 2018 Posted April 6, 2018 Maybe the log was confusing. Come on, I'll try to explain .... First, I configured the plugin .... I did not have a video stream. Searching had found the option suggested by @@Luke, and I removed the plugin and set up a m3u list. Then you asked me to log. I removed the m3u list, installed the plugin and tried to play. I think it's "trash" garbage from m3u.
Iorifly 15 Posted April 6, 2018 Posted April 6, 2018 The flow per m3u works perfectly .... but it has latches when over the web. when I leave only the plugin. Does not work.
Gerrit507 24 Posted April 6, 2018 Posted April 6, 2018 Ok try this: 1) Delete every tuner and the tvheadend plugin. 2) Restart Emby 3) Install tvheadend plugin 4) Restart Emby 5) Configure tvheadend plugin 6) Restart Emby 7) Start a Sync Guide Task in the Settings, this takes about 15 min on my server for about 500 channels or so. You will see the progress on Settings page. After that it should show all channels. 1
Iorifly 15 Posted April 6, 2018 Posted April 6, 2018 Ok try this: 1) Delete every tuner and the tvheadend plugin. 2) Restart Emby 3) Install tvheadend plugin 4) Restart Emby 5) Configure tvheadend plugin 6) Restart Emby 7) Start a Sync Guide Task in the Settings, this takes about 15 min on my server for about 500 channels or so. You will see the progress on Settings page. After that it should show all channels. there is a problem. in item 5. When I remove, and installed the plugin again it has already been configured with the previous configuration ....
Gerrit507 24 Posted April 6, 2018 Posted April 6, 2018 there is a problem. in item 5. When I remove, and installed the plugin again it has already been configured with the previous configuration .... Ok, then delete the configuration in the plugins of folder of emby.
Iorifly 15 Posted April 6, 2018 Posted April 6, 2018 done, but same error: Loglevel debug: enabled 2018-04-06 18: 57: 47.806 htsp: Got connection from 192.168.1.20 2018-04-06 18: 57: 47,825 htsp: 192.168.1.20: Identified as user 'admin' (unverified) 2018-04-06 18: 57: 47.825 htsp: 192.168.1.20 [admin]: Welcomed client software: TVHclient4Emby-3.3.1.0 (HTSPv20) 2018-04-06 18: 57: 47,833 htsp: 192.168.1.20 [admin | TVHclient4Emby-3.3.1.0]: Identified as user 'admin' 2018-04-06 18: 57: 47,833 htsp: 192.168.1.20 [admin | TVHclient4Emby-3.3.1.0]: Updated Privileges see the log https://pastebin.com/7JUJ9Bzr
Iorifly 15 Posted April 6, 2018 Posted April 6, 2018 I think the error is in the channel call, through the web interface ... see the error at the time of the player ... 2018-04-06 19:05:24.515 Error HttpServer: Error processing request *** Error Report *** Version: 3.3.1.0 Command line: C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\angel\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: False 64-Bit Process: False User Interactive: True Processor count: 4 Program data path: C:\Users\angel\AppData\Roaming\Emby-Server Application directory: C:\Users\angel\AppData\Roaming\Emby-Server\system MediaBrowser.Controller.LiveTv.LiveTvConflictException: Exception of type 'MediaBrowser.Controller.LiveTv.LiveTvConflictException' was thrown. at Emby.Server.Implementations.LiveTv.TunerHosts.BaseTunerHost.<GetChannelStream>d__18.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<GetChannelStreamInternal>d__85.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<GetChannelStreamWithDirectStreamProvider>d__81.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.LiveTvManager.<GetLiveStream>d__59.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.LiveTvMediaSourceProvider.<OpenMediaSource>d__12.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Library.MediaSourceManager.<OpenLiveStream>d__29.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.MediaInfoService.<OpenMediaSource>d__14.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.MediaInfoService.<GetPlaybackInfo>d__17.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.MediaInfoService.<Post>d__19.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceExecGeneral.<Execute>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__74.MoveNext() MediaBrowser.Controller.LiveTv.LiveTvConflictException at Emby.Server.Implementations.LiveTv.TunerHosts.BaseTunerHost.<GetChannelStream>d__18.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<GetChannelStreamInternal>d__85.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<GetChannelStreamWithDirectStreamProvider>d__81.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.LiveTvManager.<GetLiveStream>d__59.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.LiveTvMediaSourceProvider.<OpenMediaSource>d__12.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Library.MediaSourceManager.<OpenLiveStream>d__29.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.MediaInfoService.<OpenMediaSource>d__14.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.MediaInfoService.<GetPlaybackInfo>d__17.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.MediaInfoService.<Post>d__19.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceExecGeneral.<Execute>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__74.MoveNext() 2018-04-06 19:05:24.515 Info HttpServer: HTTP Response 500 to 192.168.1.20. Time: 27ms. http://192.168.1.20:8096/emby/Items/90a9bc525aa862af2d20df17cea47a87/PlaybackInfo?UserId=287bc76afe6c434fb72d0dbac7add193&StartTimeTicks=0&AutoOpenLiveStream=true&MaxStreamingBitrate=4000002
Gerrit507 24 Posted April 6, 2018 Posted April 6, 2018 done, but same error: Loglevel debug: enabled 2018-04-06 18: 57: 47.806 htsp: Got connection from 192.168.1.20 2018-04-06 18: 57: 47,825 htsp: 192.168.1.20: Identified as user 'admin' (unverified) 2018-04-06 18: 57: 47.825 htsp: 192.168.1.20 [admin]: Welcomed client software: TVHclient4Emby-3.3.1.0 (HTSPv20) 2018-04-06 18: 57: 47,833 htsp: 192.168.1.20 [admin | TVHclient4Emby-3.3.1.0]: Identified as user 'admin' 2018-04-06 18: 57: 47,833 htsp: 192.168.1.20 [admin | TVHclient4Emby-3.3.1.0]: Updated Privileges see the log https://pastebin.com/7JUJ9Bzr Still the same. No access over the plugin instead the built-in emby m3u tuner is used and throws an exception.
Iorifly 15 Posted April 6, 2018 Posted April 6, 2018 I took everything I restarted, every time. I cleaned the folder C: \ Users \ angel \ AppData \ Roaming \ Emby-Server \ cache Etc. I think I'll stick with the m3u option. It does not work on the web, but it works on the iphone ..
Gerrit507 24 Posted April 6, 2018 Posted April 6, 2018 (edited) I took everything I restarted, every time. I cleaned the folder C: \ Users \ angel \ AppData \ Roaming \ Emby-Server \ cache Etc. I think I'll stick with the m3u option. It does not work on the web, but it works on the iphone .. See the attached screenshot. The excpetion you get can only be thrown when using: BaseTunerHost HdHomerun M3UTunerHost It's just impossible for the tvheadend plugin. Edited April 6, 2018 by Gerrit507
Iorifly 15 Posted April 6, 2018 Posted April 6, 2018 Problem was solved with the help of the friend @ Gerrit507 It was only necessary for me to follow the steps he said, and then to have the tasks updated .... Thank you for your help!!! @ Gerrit507
Iorifly 15 Posted April 7, 2018 Posted April 7, 2018 @@Luke, I did the procedures that @@Gerrit507 indicated. and then I went into the tasks of the emby, and asked to update the live tv "refresh guide". And then it updated and worked.
nague 5 Posted April 12, 2018 Posted April 12, 2018 Since last Emby for Android TV app update (1.5.66g), live TV from TVHeadend plugin source is no longer working : I have to wait the "no audio / no video" warning message and press "YES". Is this a known issue ? Please note that live TV is still working great on others clients (web, android).
Luke 42241 Posted April 12, 2018 Posted April 12, 2018 Since last Emby for Android TV app update (1.5.66g), live TV from TVHeadend plugin source is no longer working : I have to wait the "no audio / no video" warning message and press "YES". Is this a known issue ? Please note that live TV is still working great on others clients (web, android). @@nague, can you please attach the emby server log? thanks.
DeBaschdi 0 Posted April 16, 2018 Posted April 16, 2018 (edited) @Iorifly try this in tvheadend web ui : (german) konfiguration ----> Allgemein ------> Authentication type: "Both plain and digest" @@Luke whats about the missing channel icons ? still no new emby version. Edited April 16, 2018 by DeBaschdi
