Gerrit507 24 Posted February 26, 2018 Posted February 26, 2018 Make sure you're running the latest version of emby server. Well, I'm running 3.2.7.0 because 3.3.0.0 is instantly crashing on my ubuntu machine... I'll give you the logfiles soon. By the way I've made a merge request for a fix of the threading issue: https://github.com/MediaBrowser/Tvheadend/pull/3
Gerrit507 24 Posted February 26, 2018 Posted February 26, 2018 (edited) Ok it seems like the crash with version 3.3.0.0 is caused by the tvheadend plugin. I've tried it with 3.2.7, 3.2.9 and my build. As soon as I configure the plugin and restart the site comes up for few seconds and then emby crashes. Same goes for the latest beta version. edit: It's working up to the beta version 3.2.7.6, so whatever change is causing the crash has to be after that server-63655212871.txt server-63655213271.txt Edited February 26, 2018 by Gerrit507
Luke 42241 Posted February 26, 2018 Posted February 26, 2018 Thanks. And your pull request resolves those?
Gerrit507 24 Posted February 26, 2018 Posted February 26, 2018 (edited) Thanks. And your pull request resolves those? No sadly it doesn't but it will fix the threading issue. When I was coding it, I didn't even knew that the issue with new version was related with the tvheadend plugin. There had to be some change in the server, which is causing incompatibility with the tvheadend plugin. Sadly the logs are not very helpful. If I had to guess I would blame the new recording section on the homescreen. Edited February 26, 2018 by Gerrit507
Luke 42241 Posted February 26, 2018 Posted February 26, 2018 Just a guess but you may want some logging here to see how far it gets: https://github.com/MediaBrowser/Tvheadend/blob/master/TVHeadEnd/HTSConnectionHandler.cs#L106
Gerrit507 24 Posted February 26, 2018 Posted February 26, 2018 Ok the problem is likely that the plugin is attempting to establish a connection in the LiveTVService constructor, that ultimately traces to here: https://github.com/MediaBrowser/Tvheadend/blob/master/TVHeadEnd/HTSConnectionHandler.cs#L64 I have always advised against doing any work in the constructor such as that. Another class should be added to the project that implements IServerEntryPoint, and call the init method during IServerEntryPoint.Run. I've deleted all recordings from tvheadend and then updated emby to 3.3.0.0 and it's not crashing anymore. So the issue was definetly related to the recordings. Do you think your suggestion would fix that?
Luke 42241 Posted February 26, 2018 Posted February 26, 2018 No, ignore my suggestion. It's not doing what I thought it was, so that's why i deleted the posting.
Gerrit507 24 Posted February 26, 2018 Posted February 26, 2018 No, ignore my suggestion. It's not doing what I thought it was, so that's why i deleted the posting. Ok, nervermind. I'm just testing around and as soon as I have a recording in tvheadend, then run the sync in emby and enter the recording section, emby is crashing. When I delete the recording it's fine again. Still nothing useful in the logs. I'm clueles at the moment...
himisk71 4 Posted February 26, 2018 Posted February 26, 2018 Sice ~3.2.15 (when the recordindings going to a a seperate link on the main page) i have not had recordings. tvheadend recordings/other/ is empty. maybe related to the crash entry in my log?
Gerrit507 24 Posted February 26, 2018 Posted February 26, 2018 Sice ~3.2.15 (when the recordindings going to a a seperate link on the main page) i have not had recordings. tvheadend recordings/other/ is empty. maybe related to the crash entry in my log? The new recording section was a change in the server, not in the plugin. When I was able to reach the recordings, it also had only an empty Others folder.
michael_stonebridge 0 Posted February 26, 2018 Posted February 26, 2018 I've just reinstalled Emby and switched to the Docker version and I'm unable to get the logos. The logos were working fine before. The message I get when I try to view the thumbnail from Emby is "Unauthorized" Same here. Channel-Icons point to ``/emby/Items/<hash>/Images/Primary``, but those URL give Internal Server Errors (500) or Unauthorized (401). Is there a way to rebuild all channels? I can't force it to redowload the channel logos. It would be great if Emby would follow some sort of versioning guidelines. At this point even minor releases can change routines that are exposed to plugins. It would be great to keep those stable between major releases.
Gerrit507 24 Posted February 26, 2018 Posted February 26, 2018 Same here. Channel-Icons point to ``/emby/Items/<hash>/Images/Primary``, but those URL give Internal Server Errors (500) or Unauthorized (401). Is there a way to rebuild all channels? I can't force it to redowload the channel logos. It would be great if Emby would follow some sort of versioning guidelines. At this point even minor releases can change routines that are exposed to plugins. It would be great to keep those stable between major releases. Same issue here. I've recently added some new logos but they are not showing up. The logs say that the plugin is calling GetChannelImage but not GetChannelImageUrl, this might be the issue.
michael_stonebridge 0 Posted February 26, 2018 Posted February 26, 2018 Same issue here. I've recently added some new logos but they are not showing up. The logs say that the plugin is calling GetChannelImage but not GetChannelImageUrl, this might be the issue. Great catch! For me the logos are not stored in the metadata folder of Emby (for example metadata/livetv/<hash>/metadata/poster.png). If I add the logo manually, then it works. So does not seem to be a permission issue, but rather still a problem of the plugin not fetching the logo.
Luke 42241 Posted February 26, 2018 Posted February 26, 2018 Are recordings still blank? Is so can you provide a server log from trying to access them? Thanks.
Gerrit507 24 Posted February 26, 2018 Posted February 26, 2018 (edited) Are recordings still blank? Is so can you provide a server log from trying to access them? Thanks. Yes they are, there is only an empty "Others" folder, and for me it crashes the whole server. Don't know about the others. You can see the logs I posted last night but afaik there was nothing helpful in there only that the log stops after getting the recordings. Great catch! For me the logos are not stored in the metadata folder of Emby (for example metadata/livetv/<hash>/metadata/poster.png). If I add the logo manually, then it works. So does not seem to be a permission issue, but rather still a problem of the plugin not fetching the logo. 2018-02-26 17:55:23.945 Info HttpClient: GET http://192.168.179.11:9981/imagecache/578 2018-02-26 17:55:23.961 Error HttpServer: Error processing request *** Error Report *** Version: 3.3.0.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.32 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: Unauthorized at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsync>d__17.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Manager.ProviderManager.<SaveImage>d__33.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Library.LibraryManager.<ConvertImageToLocal>d__191.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Drawing.ImageProcessor.<ProcessImage>d__29.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Api.Images.ImageService.<GetImageResult>d__24.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceExecGeneral.<Execute>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__74.MoveNext() MediaBrowser.Model.Net.HttpException at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsync>d__17.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Manager.ProviderManager.<SaveImage>d__33.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Library.LibraryManager.<ConvertImageToLocal>d__191.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Drawing.ImageProcessor.<ProcessImage>d__29.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Api.Images.ImageService.<GetImageResult>d__24.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceExecGeneral.<Execute>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__74.MoveNext() There are errors tranlating the tvh logos to local images... I think the issue is that they are accessed without any login information. Edited February 26, 2018 by Gerrit507
Gerrit507 24 Posted February 26, 2018 Posted February 26, 2018 I've created a new user with blank username in tvh, who can access the webinterface from my local network. I can get the channel logos from my web browser without auth prompt. Emby now throws a null pointer exception: 2018-02-26 18:50:13.729 Debug App: ConvertImageToLocal item 1a38f91b-cb89-af6a-ef54-6f150f84efcc - image url: http://192.168.179.11:9981/imagecache/628 2018-02-26 18:50:13.729 Info HttpClient: GET http://192.168.179.11:9981/imagecache/628 2018-02-26 18:50:13.733 Error HttpServer: Error processing request *** Error Report *** Version: 3.3.0.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.32 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.ArgumentNullException: Value cannot be null. Parameter name: mimeType at MediaBrowser.Providers.Manager.ImageSaver.<SaveImage>d__8.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Manager.ProviderManager.<SaveImage>d__33.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Library.LibraryManager.<ConvertImageToLocal>d__191.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Drawing.ImageProcessor.<ProcessImage>d__29.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Api.Images.ImageService.<GetImageResult>d__24.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceExecGeneral.<Execute>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__74.MoveNext() System.ArgumentNullException at MediaBrowser.Providers.Manager.ImageSaver.<SaveImage>d__8.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Manager.ProviderManager.<SaveImage>d__33.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Library.LibraryManager.<ConvertImageToLocal>d__191.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Drawing.ImageProcessor.<ProcessImage>d__29.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Api.Images.ImageService.<GetImageResult>d__24.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceExecGeneral.<Execute>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__74.MoveNext()
Luke 42241 Posted February 26, 2018 Posted February 26, 2018 Does that url have a content type response header?
Gerrit507 24 Posted February 26, 2018 Posted February 26, 2018 Does that url have a content type response header? This is the source code of the url: <html><head><meta name="viewport" content="width=device-width, minimum-scale=0.1"><title>628 (220×132)</title></head><body style="margin: 0px; background: #0e0e0e;"><img style="-webkit-user-select: none;background-position: 0px 0px, 10px 10px;background-size: 20px 20px;background-image:linear-gradient(45deg, #eee 25%, transparent 25%, transparent 75%, #eee 75%, #eee 100%),linear-gradient(45deg, #eee 25%, white 25%, white 75%, #eee 75%, #eee 100%);" src="http://192.168.179.11:9981/imagecache/628"></body></html>
Gerrit507 24 Posted February 26, 2018 Posted February 26, 2018 (edited) ok well that's not an image file That's typical tvheadend style Here you have a sample of my "picons" Edited February 26, 2018 by Gerrit507
Luke 42241 Posted February 26, 2018 Posted February 26, 2018 I'm afraid I don't quite understand? In any event Emby will need a plain image url that returns jpg, png, etc. Does tvheadend have that?
Gerrit507 24 Posted February 26, 2018 Posted February 26, 2018 (edited) I'm afraid I don't quite understand? In any event Emby will need a plain image url that returns jpg, png, etc. Does tvheadend have that? Well the browser shows it as a plain image at least. I think the issue is that it doesnt come with any file ending. For example my picons are all png but when I open that link and "save as..." it gives me a file without ending, so you'd have to guess what file type it is... I don't think that tvheadend has that... Edited February 26, 2018 by Gerrit507
Luke 42241 Posted February 26, 2018 Posted February 26, 2018 it doesn't need a file extension in the url, just a content-type response header.
Gerrit507 24 Posted February 26, 2018 Posted February 26, 2018 it doesn't need a file extension in the url, just a content-type response header. Would it need to have a subtype like "image/png" or would "image" suffice? If so, I would just assume image content-type "image" as default in this method.
Luke 42241 Posted February 26, 2018 Posted February 26, 2018 No it needs image/png, image/jpeg, etc. We don't try and detect what kind of image it is.
