ShotToTheDome 7 Posted January 8, 2018 Posted January 8, 2018 (edited) Plugin is fantastic, works like a charm :-). Just one quick question if you have time. What are my options for getting Recordings and/or Live TV thumbnails? The interface looks a tad empty with lots of coloured boxes. Cheers. I'm using mc2xml with schedules direct. I combine all 4 of my SD lineups into one and then import into tvheadend using the External: xmltv module (the one with xmltv.sock that you cat the data into) example screenshot: Edited January 8, 2018 by ShotToTheDome 1
jleckenby 13 Posted January 17, 2018 Posted January 17, 2018 Hi, I seem to have an error where if the channel I am loading doesn’t work for some reason, live tv stops working. It seems to cling to that channel, showing a subscription to it in tvheadend, even with the client turned off. Any other channel doesn’t work and doesn’t register any new subscription. Any ideas?
Luke 42241 Posted January 18, 2018 Posted January 18, 2018 Hi, I seem to have an error where if the channel I am loading doesn’t work for some reason, live tv stops working. It seems to cling to that channel, showing a subscription to it in tvheadend, even with the client turned off. Any other channel doesn’t work and doesn’t register any new subscription. Any ideas? Hi there @@jleckenby, can we please look at an example? Please attach the information requested in how to report a problem. thanks !
jleckenby 13 Posted January 18, 2018 Posted January 18, 2018 Okay, I've attached logs, hope these help. I've attached screenshots of what happens. I select a channel which doesn't load (for whatever reason). It then hangs with a spinner. I can then navigate away but tvheadend still reports the subscription. Starting any other channel doesn't start a new subscription. Hope this is enough! log.txt transcode.txt
jleckenby 13 Posted January 18, 2018 Posted January 18, 2018 (Feature request) Not an essential feature by any means, but it would be great if we could limit the number of concurrent streams per emby user. I have a few users and don't want one person to use up all the tuners.
michael_stonebridge 0 Posted January 19, 2018 Posted January 19, 2018 @@michael_stonebridge Please check the attached version and report if Emby now runs stable in case of network interrupts. Thanks a lot, I tested the attached version (1.1.3.1) for about a week and did not have any crashes so far.
Luke 42241 Posted January 19, 2018 Posted January 19, 2018 Okay, I've attached logs, hope these help. I've attached screenshots of what happens. I select a channel which doesn't load (for whatever reason). It then hangs with a spinner. I can then navigate away but tvheadend still reports the subscription. Starting any other channel doesn't start a new subscription. Hope this is enough! Have you tried just giving it a little time to load?
jleckenby 13 Posted January 20, 2018 Posted January 20, 2018 Yep, never does. And if I quit live tv, it still shows in tvheadend as subscribed till I restart emby.
Luke 42241 Posted January 20, 2018 Posted January 20, 2018 That's strange because the log looks OK. @@Tolotos can you reproduce?
Tolotos 61 Posted January 20, 2018 Author Posted January 20, 2018 .... @@Tolotos can you reproduce? @@Luke Unfotunately yes I'll investigate imediately.
Luke 42241 Posted January 20, 2018 Posted January 20, 2018 @@jleckenby can you provide new log examples with the latest version of emby server? thanks !
Tolotos 61 Posted January 20, 2018 Author Posted January 20, 2018 @@Luke I tried with the latest Emby version. The "GetChannelStream" method is not called from Emby. Any Ideas?
Tolotos 61 Posted January 20, 2018 Author Posted January 20, 2018 Here is the log server-63652072314.txt
Luke 42241 Posted January 20, 2018 Posted January 20, 2018 This log is just a startup log. it doesn't look like there are any playback attempts here. are you sure this is the right one?
Tolotos 61 Posted January 21, 2018 Author Posted January 21, 2018 (edited) Yes Edit: I did a fresh installation of 3.2.70 added a log as first line in the method "GetChannelStream" started Emby server started play on a channel as soon as they was display in the web gui After the klick a spinning wheel was displayed and no logs. Neighter from emby kernel nor the plugin log. Edited January 21, 2018 by Tolotos
fc7 123 Posted January 21, 2018 Posted January 21, 2018 (edited) Starting with Emby 3.2.70.0 using the plugin feature that allows to detect multi audio track and subtitles in live tv streams is broken. The problem seems to be that a method was removed from the server code: System.MissingMethodException: Method 'MediaBrowser.Controller.MediaEncoding.MediaInfoRequest.set_InputPath' not found. Here you have the full exception and log while trying to play a channel using the TVH plugin and the feature mentioned above, enabled: 2018-01-21 10:28:08.585 Info HttpServer: HTTP POST https://emby01:8920/Items/ea4233cc37dc77c7605f93bc6aec0022/PlaybackInfo?UserId=668038acfab52e12250818ef610e97c5&StartTimeTicks=0&AutoOpenLiveStream=true&MaxStreamingBitrate=140000000. UserAgent: Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0 2018-01-21 10:28:08.591 Info App: User policy for Fernando. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2018-01-21 10:28:08.591 Info App: Profile: Unknown Profile, Path: http://192.168.7.31:8096, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2018-01-21 10:28:08.591 Info App: Profile: Unknown Profile, No direct play profiles found for Path: http://192.168.7.31:8096 2018-01-21 10:28:08.591 Info App: Profile: Unknown Profile, Path: http://192.168.7.31:8096, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2018-01-21 10:28:08.591 Info App: Profile: Unknown Profile, No direct play profiles found for Path: http://192.168.7.31:8096 2018-01-21 10:28:08.591 Info App: Profile: Unknown Profile, Path: http://192.168.7.31:8096, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2018-01-21 10:28:08.591 Info App: Profile: Unknown Profile, No direct play profiles found for Path: http://192.168.7.31:8096 2018-01-21 10:28:08.592 Info App: Opening channel stream from TVHclient LiveTvService, external channel Id: 339698383 2018-01-21 10:28:08.592 Info App: [TVHclient] Support for live TV subtitles and multiple audio tracks is enabled. 2018-01-21 10:28:08.596 Error HttpServer: Error processing request *** Error Report *** Version: 3.2.70.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 3.10.0.693 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.8.1 (Stable 4.8.1.0/22a39d7 Wed May 3 17:39:37 UTC 2017) Processor count: 4 Program data path: /var/lib/emby-server Application directory: /usr/lib/emby-server/bin System.MissingMethodException: Method 'MediaBrowser.Controller.MediaEncoding.MediaInfoRequest.set_InputPath' not found. at System.Runtime.CompilerServices.AsyncTaskMethodBuilder.Start[TStateMachine] (TStateMachine& stateMachine) [0x00031] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at TVHeadEnd.LiveTvService.ProbeStream (MediaBrowser.Model.Dto.MediaSourceInfo mediaSourceInfo, System.String probeUrl, System.String source, System.Threading.CancellationToken cancellationToken) [0x00044] in <49de90bb4b2a45678fb0ff34e41532f6>:0 at TVHeadEnd.LiveTvService+<GetChannelStream>d__26.MoveNext () [0x001f4] in <49de90bb4b2a45678fb0ff34e41532f6>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.LiveTv.LiveTvManager+<GetLiveStream>c__async4.MoveNext () [0x00204] in <730a104ef6c8470ebc4f70071ce76249>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.LiveTv.LiveTvMediaSourceProvider+<OpenMediaSource>c__async1.MoveNext () [0x00109] in <730a104ef6c8470ebc4f70071ce76249>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.Library.MediaSourceManager+<OpenLiveStream>c__async4.MoveNext () [0x00128] in <730a104ef6c8470ebc4f70071ce76249>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.MediaEncoding.Api.MediaInfoService+<OpenMediaSource>d__14.MoveNext () [0x00099] in <9b83e01f8da34f4a9b7792752b0d08b1>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.MediaEncoding.Api.MediaInfoService+<GetPlaybackInfo>d__17.MoveNext () [0x004a4] in <9b83e01f8da34f4a9b7792752b0d08b1>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.MediaEncoding.Api.MediaInfoService+<Post>d__19.MoveNext () [0x00075] in <9b83e01f8da34f4a9b7792752b0d08b1>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.Services.ServiceExecGeneral+<Execute>c__async0.MoveNext () [0x0015f] in <730a104ef6c8470ebc4f70071ce76249>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>c__async1.MoveNext () [0x0016b] in <730a104ef6c8470ebc4f70071ce76249>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>c__async0.MoveNext () [0x00770] in <730a104ef6c8470ebc4f70071ce76249>:0 System.MissingMethodException at System.Runtime.CompilerServices.AsyncTaskMethodBuilder.Start[TStateMachine] (TStateMachine& stateMachine) [0x00031] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at TVHeadEnd.LiveTvService.ProbeStream (MediaBrowser.Model.Dto.MediaSourceInfo mediaSourceInfo, System.String probeUrl, System.String source, System.Threading.CancellationToken cancellationToken) [0x00044] in <49de90bb4b2a45678fb0ff34e41532f6>:0 at TVHeadEnd.LiveTvService+<GetChannelStream>d__26.MoveNext () [0x001f4] in <49de90bb4b2a45678fb0ff34e41532f6>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.LiveTv.LiveTvManager+<GetLiveStream>c__async4.MoveNext () [0x00204] in <730a104ef6c8470ebc4f70071ce76249>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.LiveTv.LiveTvMediaSourceProvider+<OpenMediaSource>c__async1.MoveNext () [0x00109] in <730a104ef6c8470ebc4f70071ce76249>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.Library.MediaSourceManager+<OpenLiveStream>c__async4.MoveNext () [0x00128] in <730a104ef6c8470ebc4f70071ce76249>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.MediaEncoding.Api.MediaInfoService+<OpenMediaSource>d__14.MoveNext () [0x00099] in <9b83e01f8da34f4a9b7792752b0d08b1>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.MediaEncoding.Api.MediaInfoService+<GetPlaybackInfo>d__17.MoveNext () [0x004a4] in <9b83e01f8da34f4a9b7792752b0d08b1>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.MediaEncoding.Api.MediaInfoService+<Post>d__19.MoveNext () [0x00075] in <9b83e01f8da34f4a9b7792752b0d08b1>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.Services.ServiceExecGeneral+<Execute>c__async0.MoveNext () [0x0015f] in <730a104ef6c8470ebc4f70071ce76249>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>c__async1.MoveNext () [0x0016b] in <730a104ef6c8470ebc4f70071ce76249>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>c__async0.MoveNext () [0x00770] in <730a104ef6c8470ebc4f70071ce76249>:0 2018-01-21 10:28:08.596 Info HttpServer: HTTP Response 500 to 192.168.7.44. Time: 12ms. https://emby01:8920/Items/ea4233cc37dc77c7605f93bc6aec0022/PlaybackInfo?UserId=668038acfab52e12250818ef610e97c5&StartTimeTicks=0&AutoOpenLiveStream=true&MaxStreamingBitrate=140000000 @@Luke, was the method removed? Any workaround to achieve the same? This feature is a must have for me. I live in a country where TV is broadcasted in different languages, etc. Without this feature I cannot use subtitles or change the audio language while watching Live TV. BTW this was working fine until 3.2.60.0. Thanks. Edited January 21, 2018 by fc7
fc7 123 Posted January 21, 2018 Posted January 21, 2018 It seems the method was removed in commit 209749d. Any suggestions on how to workaround this and get the feature to work again?
Tolotos 61 Posted January 21, 2018 Author Posted January 21, 2018 (edited) It seems the method was removed in commit 209749d. Any suggestions on how to workaround this and get the feature to work again? Hi @@fc7, In the above commit the Path was replaced with the MediaSouceInfo type. Normally you can change the code in the ProbeStream method like this //InputPath = probeUrl, MediaSource = mediaSourceInfo, Unfortunately are the changes not available in the NuGet packages I get with Update-Package (3.3.20). @@Luke which NuGet versions must be used for the 3.2.70 version of Emby? Maybe this will show how the current problems are located. -- Tolotos Edited January 21, 2018 by Tolotos
Luke 42241 Posted January 21, 2018 Posted January 21, 2018 @@Tolotos, what are you actually trying to do?
Tolotos 61 Posted January 23, 2018 Author Posted January 23, 2018 @@Luke I try to compile a version of the plugin which is able to run with the 3.2.70 version of Emby. The "method not found error" and the investigations of @@fc7 shows that the API was changed for 3.2.70 but there is no NUGET package available with the new API. Therefor the current errors can't be solved until a 3.2.70 compatible API is available.
Tolotos 61 Posted January 23, 2018 Author Posted January 23, 2018 System.MissingMethodException: Method 'MediaBrowser.Controller.MediaEncoding.MediaInfoRequest.set_InputPath' not found. The "InputPath" attribute of class "MediaInfoRequest" is available in NUGET version 3.3.20 but not in the 3.2.70 version of Emby.
Tolotos 61 Posted January 23, 2018 Author Posted January 23, 2018 To get informations about different audio streams and subtitles (languages) out of a stream. MediaInfoRequest req = new MediaInfoRequest { MediaType = MediaBrowser.Model.Dlna.DlnaProfileType.Video, InputPath = probeUrl, Protocol = MediaProtocol.Http, ExtractChapters = false, VideoType = VideoType.VideoFile, }; MediaInfo info = await _mediaEncoder.GetMediaInfo(req, cancellationToken).ConfigureAwait(false);
