KRA 39 Posted April 10, 2015 Posted April 10, 2015 @@Tolotos I am now able to edit series recordings, however I'm not seeing an option to create a series recording. Also I first unticked saturday from a series recording, it was registered in tvheadend, however when I ticked it again I got an error. (see below). Then I open TV guide to look for option to add series recording, did not find it, went back to the scheduled series recording and ticked saturday again, this time it worked and got registered in tvheadend. Fatal - App: [TVHclient] CreateSeriesTimerAsync: got SeriesTimerInfo: <SeriesTimerInfo> Id: 5908e7318f651def15701bcc2f5a3bba Name: VG Sporten Overview: Priority: 2 ChannelId: 1926255894 ProgramId: Days: Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, StartDate: 4/10/2015 6:22:58 PM EndDate: 4/10/2015 6:22:58 PM IsPrePaddingRequired: True PrePaddingSeconds: 0 IsPostPaddingRequired: True PostPaddingSeconds: 0 RecordAnyChannel: False RecordAnyTime: False RecordNewOnly: False </SeriesTimerInfo> 2015-04-10 18:22:58.5523 Fatal - App: [TVHclient] CreateSeriesTimerAsync: created HTSP message: HTSMessage: <dump> method : addAutorecEntry title : VG Sporten channelId : 1926255894 minDuration : 0 maxDuration : 0 priority : 1 configName : daysOfWeek : 95 approxTime : 1102 startExtra : 0 stopExtra : 0 </dump> 2015-04-10 18:23:27.3868 Error - DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5572.0 Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -programdata /config Operating system: Unix 3.13.0.48 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /config Mono: 3.10.0 (tarball Wed Nov 5 12:50:04 UTC 2014) Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: result System.ArgumentNullException at MediaBrowser.Server.Implementations.HttpServer.HttpResultFactory.GetOptimizedResult[SeriesTimerInfoDto] (IRequest requestContext, MediaBrowser.Model.LiveTv.SeriesTimerInfoDto result, IDictionary`2 responseHeaders) [0x00000] in <filename unknown>:0 at MediaBrowser.Api.BaseApiService.ToOptimizedResult[SeriesTimerInfoDto] (MediaBrowser.Model.LiveTv.SeriesTimerInfoDto result) [0x00000] in <filename unknown>:0 at MediaBrowser.Api.BaseApiService.ToOptimizedSerializedResultUsingCache[SeriesTimerInfoDto] (MediaBrowser.Model.LiveTv.SeriesTimerInfoDto result) [0x00000] in <filename unknown>:0 at MediaBrowser.Api.LiveTv.LiveTvService+<Get>c__asyncB.MoveNext () [0x00000] in <filename unknown>:0 2015-04-10 18:23:27.3903 Error - HttpServer: Error processing request for /mediabrowser/LiveTv/SeriesTimers/6940437878aa9421aaddf8c7258c5a06 *** Error Report *** Version: 3.0.5572.0 Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -programdata /config Operating system: Unix 3.13.0.48 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /config Mono: 3.10.0 (tarball Wed Nov 5 12:50:04 UTC 2014) Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: result ServiceStack.HttpError No Stack Trace Available
KRA 39 Posted April 10, 2015 Posted April 10, 2015 (edited) @@Tolotos regarding the start / stop time. If you don't specify that it should record at any given time it just sets a filter for: start after -15 minutes as of now end before +15 minutes as of now I don't see this as desired in any scenario. Edited April 10, 2015 by KRA
Tolotos 61 Posted April 10, 2015 Author Posted April 10, 2015 @@KRA Can you please send me a screenshot of the tvheadend website showing this timer when it is modified through Emby?
KRA 39 Posted April 10, 2015 Posted April 10, 2015 (edited) 1. Initial series recording set in tvheadend 2. how the recording looks like in emby 3. remove 2 days from schedule in emby 4. how it is changed in tvheadend 5. some more changes done in emby added days back + extra settings 7. result in tvheadend. Edited April 10, 2015 by KRA
Tolotos 61 Posted April 10, 2015 Author Posted April 10, 2015 @@KRA This looks like ok for me. Can you please check now if the timers still working? I saw no priority field in the Emby screen. I changed using fix settings profile to: If priority of Emby != 0 use this else use the settings value. With this workaround you can use the values 1 - 4 (high - lowest) from tvheadend only highest is not possible. Tvheadend lacks also a method of modifying a series timer. I must remove it and create a new one.
Tolotos 61 Posted April 10, 2015 Author Posted April 10, 2015 @@Luke Can you please have a look at the stack trace in post #26. Is this an error of my plugin or caused by another source?
Luke 42239 Posted April 10, 2015 Posted April 10, 2015 not enough info there to tell as the error shown is only at the api level.
KRA 39 Posted April 10, 2015 Posted April 10, 2015 (edited) @@KRA This looks like ok for me. Can you please check now if the timers still working? Now ? as in you intended to post a new build ? I'm currently on this one http://emby.media/community/index.php?/topic/20107-tvheadend-plugin-for-emby-beta-1/page-2&do=findComment&comment=196905 EDIT, adding a timer works fine. There is one problem if you look at picture 3, you see that there is set a limit for when the show has to start and end, this should not happen because this is set at a given -15 and +15 minutes from when you did the edit. Edited April 10, 2015 by KRA
Tolotos 61 Posted April 10, 2015 Author Posted April 10, 2015 ... There is one problem if you look at picture 3, you see that there is set a limit for when the show has to start and end, this should not happen because this is set at a given -15 and +15 minutes from when you did the edit. Can you send me the log containing the edit session you did for the pictures. If must find out what happens with the -15 and +15 attributes.
KRA 39 Posted April 10, 2015 Posted April 10, 2015 (edited) Can you send me the log containing the edit session you did for the pictures. If must find out what happens with the -15 and +15 attributes. this is the log when I just edit the days (and it adds the +-15) Fatal - App: [TVHclient] CreateSeriesTimerAsync: got SeriesTimerInfo: <SeriesTimerInfo> Id: bc70a4a0277263c71d54fa3c2ef64a89 Name: VG Sporten Overview: Priority: 1 ChannelId: 1926255894 ProgramId: Days: Sunday, Monday, Tuesday, Thursday, Friday, Saturday, StartDate: 4/10/2015 9:34:58 PM EndDate: 4/10/2015 9:34:58 PM IsPrePaddingRequired: True PrePaddingSeconds: 0 IsPostPaddingRequired: True PostPaddingSeconds: 0 RecordAnyChannel: False RecordAnyTime: False RecordNewOnly: False </SeriesTimerInfo> 2015-04-10 23:34:58.5100 Fatal - App: [TVHclient] CreateSeriesTimerAsync: created HTSP message: HTSMessage: <dump> method : addAutorecEntry title : VG Sporten channelId : 1926255894 minDuration : 0 maxDuration : 0 priority : 1 configName : daysOfWeek : 123 approxTime : 1294 startExtra : 0 stopExtra : 0 </dump> This is the output if I tick "record program at any time" and it doesn't add the time limitation: Fatal - App: [TVHclient] CreateSeriesTimerAsync: got SeriesTimerInfo: <SeriesTimerInfo> Id: b7ad7f5f017ecd0ba20b8491c26f6a10 Name: VG Sporten Overview: Priority: 1 ChannelId: 1926255894 ProgramId: Days: Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, Saturday, StartDate: 4/10/2015 9:38:23 PM EndDate: 4/10/2015 9:38:23 PM IsPrePaddingRequired: True PrePaddingSeconds: 0 IsPostPaddingRequired: True PostPaddingSeconds: 0 RecordAnyChannel: False RecordAnyTime: True RecordNewOnly: False </SeriesTimerInfo> 2015-04-10 23:38:23.2615 Fatal - App: [TVHclient] CreateSeriesTimerAsync: created HTSP message: HTSMessage: <dump> method : addAutorecEntry title : VG Sporten channelId : 1926255894 minDuration : 0 maxDuration : 0 priority : 1 configName : startExtra : 0 stopExtra : 0 </dump> Edited April 10, 2015 by KRA
zozotv 0 Posted April 11, 2015 Posted April 11, 2015 Now every Emby users on the same tvheadend username use. Everyone can use their own tvheadend username? Thank you
Tolotos 61 Posted April 11, 2015 Author Posted April 11, 2015 I don't know how Emby allows different settings for the users. @@Luke is this possible from Emby side? (Best to be configurable at the users dialog?!)
Luke 42239 Posted April 11, 2015 Posted April 11, 2015 the ILiveTvService methods are not user-specific, so we'd have to rework all of that in order to make it possible. so it's not happening right now.
Tolotos 61 Posted April 11, 2015 Author Posted April 11, 2015 Hi all, here is the next version Possible deadlocks removed if tvheadend server is not reachable Due to open points with series timers and to minimize the risk of corrupted recording entries on tvheadend server I removed the code for editing and creating series timers until I have enough information from tvheadend and Emby developers. Radio channels are available Tuner info is available Tolotos TVHeadEnd.zip 2
Tolotos 61 Posted April 11, 2015 Author Posted April 11, 2015 The above version is no available in the catalog.
zozotv 0 Posted April 12, 2015 Posted April 12, 2015 Nice work, thank you. I would like to channel picons.
ryantiger658 5 Posted April 13, 2015 Posted April 13, 2015 Thanks so much for working on this! I love having MB running on my Linux server, and It will be great to have Live TV too! I am having trouble getting the tuners to show up. I have TVHeadEnd setup with my HDHomerun. I am able to access the channels from Kodi, but I am having trouble with the TVHeadEnd plugin. It seems like the error relates to this from the logs: 2015-04-13 15:43:24.4149 Info - App: ScheduledTasksWebSocketListener Begin transmitting over websocket to 38.105.67.26:74552015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/605,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/189,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/587,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/479,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/587,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/479,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/593,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/689,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/593,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/689,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/593,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/677,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/593,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/689,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/593,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/605,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/593,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/587,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/551,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/587,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/551,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/587,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/551,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/587,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/551,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/533,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/533,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/533,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/533,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/533,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/533,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/533,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/533,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/533,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/533,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/533,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/533,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/189,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/587,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/189,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/587,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/479,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/677,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/479,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/677,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/599,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/479,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/599,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/479,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/599,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/479,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/551,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/479,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/551,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/189,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/551,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/189,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/551,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/189,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/593,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/689,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/593,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/689,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/593,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/689,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/593,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/599,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/593,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/599,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/593,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR1/599,028 kHz'2015-04-13 15:43:24.4212 Error - App: [TVHclient] TunerDataHelper.buildTunerInfos: Can' build tuner name from 'HDHR2/677,028 kHz'2015-04-13 15:43:26.3415 Info - App: ScheduledTasksWebSocketListener stop transmitting over websocket to 38.105.67.26:7455 I have tried changing the tuner name, but still no luck. Thoughts? Ryan
zozotv 0 Posted April 14, 2015 Posted April 14, 2015 TVheadend plugin freezes often. Not to start playback. To reset after running again
Luke 42239 Posted April 14, 2015 Posted April 14, 2015 It's not a freeze - the live stream is now opened before the video player shows up, not after. i need to add a loading dialog so that you know what's going on.
Tolotos 61 Posted April 14, 2015 Author Posted April 14, 2015 The tunername information has no function related. Tvheadend delivers the tuner name together with other information as one string. Breaking the parts is not easy as it looks like there are different versions of which information is chained together in the tvheadend code. My strings looks like STV0367 DVB-C DVB-T (adapter 0)/KBW: 370,000 kHz/zdf.kultur CXD2837 DVB-C DVB-T/T2 (adapter 3)/KBW: 370,000 kHz/zdf.kultur You version is HDHR1/599,028 kHz I tried to split back words at the '/' into 3 parts but your string is missing the tv-channel part. I think it is not possible to calculate the tuner name so I disabled the tuner info in the new version (available in the repo). Are you able to see the channels, EPG, recordings? Can you watch a live stream, a recorded stream?
zozotv 0 Posted April 14, 2015 Posted April 14, 2015 2015-04-14 08:12:10.5958 Info - Main: Emby Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -programdata /var/lib/mediabrowser Operating system: Unix 3.13.0.46 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/mediabrowser Mono: 3.10.0 (tarball Wed Nov 5 12:50:04 UTC 2014) Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe2015-04-14 08:12:10.7677 Info - App: Application version: 3.0.5572.02015-04-14 08:12:10.8273 Info - App: Application configuration: {"EnableUPnP":true,"PublicPort":8096,"PublicHttpsPort":8920,"HttpServerPortNumber":8096,"HttpsPortNumber":8920,"EnableHttps":false,"EnableUserSpecificUserViews":false,"EnableInternetProviders":true,"IsPortAuthorized":true,"SeasonZeroDisplayName":"Specials","SaveLocalMeta":false,"EnableLocalizedGuids":true,"EnableLibraryMetadataSubFolder":true,"PreferredMetadataLanguage":"hu","MetadataCountryCode":"HU","SortReplaceCharacters":[".","+","%"],"SortRemoveCharacters":[",","&","-","{","}","'"],"SortRemoveWords":["the","a","an"],"MinResumePct":5,"MaxResumePct":90,"MinResumeDurationSeconds":300,"RealtimeMonitorDelay":30,"EnableDashboardResponseCaching":true,"EnableDashboardResourceMinification":true,"MergeMetadataAndImagesByName":true,"EnableStandaloneMetadata":true,"ImageSavingConvention":"Compatible","MetadataOptions":[{"ItemType":"Book","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Movie","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Disc","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Media Browser Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Series","ImageOptions":[{"Type":"Backdrop","Limit":2,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Media Browser Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicAlbum","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Disc","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Media Browser Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicArtist","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Art","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Media Browser Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Season","ImageOptions":[{"Type":"Backdrop","Limit":0,"MinWidth":1280}],"DisabledMetadataSavers":["Media Browser Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Episode","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Media Browser Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicVideo","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Media Browser Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Video","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Media Browser Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]}],"EnableAutomaticRestart":true,"EnableRealtimeMonitor":true,"PathSubstitutions":[],"ServerName":"zozotv","UICulture":"hu","PeopleMetadataOptions":{"DownloadActorMetadata":true,"DownloadDirectorMetadata":true,"DownloadProducerMetadata":false,"DownloadWriterMetadata":false,"DownloadComposerMetadata":false,"DownloadOtherPeopleMetadata":false,"DownloadGuestStarMetadata":false},"FindInternetTrailers":true,"InsecureApps8":["Chromecast","iOS","Unknown app","MediaPortal","Media Portal","iPad","iPhone","Roku","Windows Phone"],"SaveMetadataHidden":false,"ContentTypes":[],"EnableAudioArchiveFiles":false,"EnableVideoArchiveFiles":false,"EnableDebugLevelLogging":false,"EnableAutoUpdate":true,"SystemUpdateLevel":"Release","LogFileRetentionDays":3,"RunAtStartup":false,"IsStartupWizardCompleted":true,"CachePath":""}2015-04-14 08:12:10.8357 Info - App: Loading MediaBrowser.Channels.Adult.Beeg, Version=1.0.5448.33320, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.8357 Info - App: Loading TVHeadEnd, Version=1.0.5579.39300, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.8357 Info - App: Loading MediaBrowser.Api, Version=3.0.5572.0, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.8357 Info - App: Loading MediaBrowser.WebDashboard, Version=3.0.5572.0, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.8357 Info - App: Loading MediaBrowser.Model, Version=3.0.5572.0, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.8357 Info - App: Loading MediaBrowser.Common, Version=3.0.5572.0, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.8357 Info - App: Loading MediaBrowser.Controller, Version=3.0.5572.0, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.8357 Info - App: Loading MediaBrowser.Providers, Version=3.0.5572.0, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.8357 Info - App: Loading MediaBrowser.Common.Implementations, Version=3.0.5572.0, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.8357 Info - App: Loading MediaBrowser.Server.Implementations, Version=3.0.5572.0, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.8357 Info - App: Loading MediaBrowser.MediaEncoding, Version=3.0.5572.0, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.8357 Info - App: Loading MediaBrowser.Dlna, Version=3.0.5572.0, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.8357 Info - App: Loading MediaBrowser.LocalMetadata, Version=3.0.5572.0, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.8357 Info - App: Loading MediaBrowser.XbmcMetadata, Version=3.0.5572.0, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.8357 Info - App: Loading MediaBrowser.IsoMounting.Linux, Version=1.0.5131.24779, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.8357 Info - App: Loading MediaBrowser.Server.Mono, Version=3.0.5572.0, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.8357 Info - App: Loading MediaBrowser.Server.Startup.Common, Version=3.0.5572.0, Culture=neutral, PublicKeyToken=null2015-04-14 08:12:10.9484 Info - SqliteUserRepository: Sqlite 3.8.2 opening /var/lib/mediabrowser/data/users.db2015-04-14 08:12:10.9872 Info - SqliteItemRepository: Sqlite 3.8.2 opening /var/lib/mediabrowser/data/chapters.db2015-04-14 08:12:10.9922 Info - SqliteItemRepository: Sqlite 3.8.2 opening /var/lib/mediabrowser/data/mediainfo.db2015-04-14 08:12:10.9999 Info - SqliteFileOrganizationRepository: Sqlite 3.8.2 opening /var/lib/mediabrowser/data/fileorganization.db2015-04-14 08:12:11.0063 Info - AuthenticationRepository: Sqlite 3.8.2 opening /var/lib/mediabrowser/data/authentication.db2015-04-14 08:12:11.0158 Info - SyncRepository: Sqlite 3.8.2 opening /var/lib/mediabrowser/data/sync14.db2015-04-14 08:12:11.0839 Info - ImageProcessor: ImageMagick version: ImageMagick 6.9.0-10 Q8 x86_64 2015-03-17 http://www.imagemagick.org2015-04-14 08:12:11.1237 Info - App: FFMpeg: /var/lib/mediabrowser/ffmpeg/20150124/ffmpeg2015-04-14 08:12:11.1237 Info - App: FFProbe: /var/lib/mediabrowser/ffmpeg/20150124/ffprobe2015-04-14 08:12:11.1290 Info - ActivityRepository: Sqlite 3.8.2 opening /var/lib/mediabrowser/data/activitylog.db2015-04-14 08:12:11.1347 Info - SqliteDisplayPreferencesRepository: Sqlite 3.8.2 opening /var/lib/mediabrowser/data/displaypreferences.db2015-04-14 08:12:11.1395 Info - SqliteItemRepository: Sqlite 3.8.2 opening /var/lib/mediabrowser/data/library.db2015-04-14 08:12:11.1451 Info - SqliteProviderInfoRepository: Sqlite 3.8.2 opening /var/lib/mediabrowser/data/refreshinfo.db2015-04-14 08:12:11.1506 Info - SqliteUserDataRepository: Sqlite 3.8.2 opening /var/lib/mediabrowser/data/userdata_v2.db2015-04-14 08:12:11.1567 Info - SqliteNotificationsRepository: Sqlite 3.8.2 opening /var/lib/mediabrowser/data/notifications.db2015-04-14 08:12:11.3324 Info - HttpServer: Calling ServiceStack AppHost.Init2015-04-14 08:12:12.5826 Info - ServiceStackHost: Initializing Application took 1550,565ms2015-04-14 08:12:12.5960 Info - ServerManager: Loading Http Server2015-04-14 08:12:12.5986 Info - HttpServer: Adding HttpListener prefix http://+:8096/2015-04-14 08:12:12.5986 Info - HttpServer: Adding HttpListener prefix https://+:8920/2015-04-14 08:12:12.6076 Info - HttpServer: attempting to load pfx: /var/lib/mediabrowser/ssl/cert_9c31b7884ea5475c8687970fc5996297.pfx2015-04-14 08:12:12.8933 Info - App: [TVHclient] LiveTvService.createHTSConnection()2015-04-14 08:12:12.9639 Info - App: Core startup complete2015-04-14 08:12:13.0093 Info - Dlna: SSDP service started2015-04-14 08:12:14.0269 Info - App: HttpClientManager GET: http://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog2015-04-14 08:12:14.5337 Info - App: HttpClientManager GET: http://www.mb3admin.com/admin/service/MB3ServerNotifications.json2015-04-14 08:12:15.5242 Info - App: HttpClientManager POST: http://www.mb3admin.com/admin/service/registration/validate2015-04-14 08:12:15.7062 Info - App: HttpClientManager POST: https://connect.mediabrowser.tv/service/Servers?id=d8a2b91e65646d03f7b0ff31494b7ce62015-04-14 08:12:15.8934 Info - App: HttpClientManager GET: https://connect.mediabrowser.tv/service/ServerAuthorizations?serverId=d8a2b91e65646d03f7b0ff31494b7ce62015-04-14 08:12:15.9640 Info - App: StartupTrigger fired for task: Scan media library2015-04-14 08:12:15.9640 Info - App: StartupTrigger fired for task: Check for application updates2015-04-14 08:12:15.9640 Info - App: StartupTrigger fired for task: Check for plugin updates2015-04-14 08:12:15.9649 Info - App: Queueing task PluginUpdateTask2015-04-14 08:12:15.9649 Info - App: Queueing task RefreshMediaLibraryTask2015-04-14 08:12:15.9649 Info - App: Queueing task SystemUpdateTask2015-04-14 08:12:15.9659 Info - App: StartupTrigger fired for task: Refresh Guide2015-04-14 08:12:15.9659 Info - App: Queueing task RefreshChannelsScheduledTask2015-04-14 08:12:15.9665 Info - App: Executing Check for plugin updates2015-04-14 08:12:15.9707 Info - App: HttpClientManager GET: http://www.mb3admin.com/admin/service/MB3Packages.json2015-04-14 08:12:15.9712 Info - App: Executing Check for application updates2015-04-14 08:12:15.9733 Info - App: HttpClientManager GET: http://www.mb3admin.com/admin/service/MB3Packages.json2015-04-14 08:12:15.9733 Info - App: Executing Refresh Guide2015-04-14 08:12:15.9771 Info - App: Executing Scan media library2015-04-14 08:12:15.9823 Info - App: Validating media library2015-04-14 08:12:15.9935 Info - App: [TVHclient] HTSConnectionAsync.open: socket connected.2015-04-14 08:12:15.9957 Info - App: [TVHclient] HTSConnectionAsync.authenticate: start2015-04-14 08:12:16.0196 Info - App: [TVHclient] HTSConnectionAsync.authenticate: authenticated = True2015-04-14 08:12:16.0196 Info - App: [TVHclient] LiveTvService.ensureConnection: connection established True2015-04-14 08:12:16.5738 Error - App: Error in Live TV Service Provider *** Error Report *** Version: 3.0.5572.0 Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -programdata /var/lib/mediabrowser Operating system: Unix 3.13.0.46 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/mediabrowser Mono: 3.10.0 (tarball Wed Nov 5 12:50:04 UTC 2014) Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe Invalid URI: The URI scheme is not valid. System.UriFormatException at System.Uri.Parse (UriKind kind, System.String uriString) [0x00000] in <filename unknown>:0 at System.Uri.ParseUri (UriKind kind) [0x00000] in <filename unknown>:0 at System.Uri..ctor (System.String uriString, Boolean dontEscape) [0x00000] in <filename unknown>:0 at System.Uri..ctor (System.String uriString) [0x00000] in <filename unknown>:0 at System.Net.WebRequest.Create (System.String requestUriString) [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.GetRequest (MediaBrowser.Common.Net.HttpRequestOptions options, System.String method, Boolean enableHttpCompression) [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[MediaBrowser.Common.Net.HttpResponseInfo].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsync>c__async1.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[MediaBrowser.Common.Net.HttpResponseInfo].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.LiveTv.ChannelImageProvider+<GetImage>c__async0.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[MediaBrowser.Controller.Providers.DynamicImageResponse].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Providers.Manager.ItemImageProvider+<RefreshFromProvider>c__async1.MoveNext () [0x00000] in <filename unknown>:0 2015-04-14 08:12:16.5813 Error - App: Error in Live TV Service Provider *** Error Report *** Version: 3.0.5572.0 Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -programdata /var/lib/mediabrowser Operating system: Unix 3.13.0.46 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/mediabrowser Mono: 3.10.0 (tarball Wed Nov 5 12:50:04 UTC 2014) Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe Invalid URI: The URI scheme is not valid. System.UriFormatException at System.Uri.Parse (UriKind kind, System.String uriString) [0x00000] in <filename unknown>:0 at System.Uri.ParseUri (UriKind kind) [0x00000] in <filename unknown>:0 at System.Uri..ctor (System.String uriString, Boolean dontEscape) [0x00000] in <filename unknown>:0 at System.Uri..ctor (System.String uriString) [0x00000] in <filename unknown>:0 at System.Net.WebRequest.Create (System.String requestUriString) [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.GetRequest (MediaBrowser.Common.Net.HttpRequestOptions options, System.String method, Boolean enableHttpCompression) [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[MediaBrowser.Common.Net.HttpResponseInfo].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsync>c__async1.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[MediaBrowser.Common.Net.HttpResponseInfo].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.LiveTv.ChannelImageProvider+<GetImage>c__async0.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[MediaBrowser.Controller.Providers.DynamicImageResponse].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Providers.Manager.ItemImageProvider+<RefreshFromProvider>c__async1.MoveNext () [0x00000] in <filename unknown>:0 2015-04-14 08:12:17.2097 Info - App: Check for plugin updates Completed after 0 minute(s) and 1 seconds2015-04-14 08:12:17.2097 Info - App: Check for application updates Completed after 0 minute(s) and 1 seconds2015-04-14 08:12:17.2201 Info - ServerManager: Sending web socket message ScheduledTaskEnded2015-04-14 08:12:17.2201 Info - ServerManager: Sending web socket message ScheduledTaskEnded2015-04-14 08:12:18.0265 Error - HttpServer: Error in SharpWebSocket: An exception has occurred while receiving a message.2015-04-14 08:12:18.5266 Info - App: HttpClientManager GET: http://bot.whatismyipaddress.com/2015-04-14 08:12:20.7595 Info - App: HttpClientManager POST: http://www.mb3admin.com/admin/service/registration/ping2015-04-14 08:12:21.5497 Info - App: HttpClientManager POST: https://connect.mediabrowser.tv/service/Servers?id=d8a2b91e65646d03f7b0ff31494b7ce62015-04-14 08:12:22.0303 Info - App: HttpClientManager GET: https://connect.mediabrowser.tv/service/ServerAuthorizations?serverId=d8a2b91e65646d03f7b0ff31494b7ce62015-04-14 08:12:23.0340 Info - App: StartupTrigger fired for task: Refresh Channels2015-04-14 08:12:23.0340 Info - App: Queueing task RefreshChannelsScheduledTask2015-04-14 08:12:23.4492 Info - App: Scan media library Completed after 0 minute(s) and 7 seconds2015-04-14 08:12:23.4492 Info - ServerManager: Sending web socket message ScheduledTaskEnded2015-04-14 08:12:23.4960 Info - App: Executing Refresh Channels2015-04-14 08:12:23.5016 Info - App: Refresh Channels Completed after 0 minute(s) and 0 seconds2015-04-14 08:12:23.5016 Info - ServerManager: Sending web socket message ScheduledTaskEnded2015-04-14 08:12:23.6172 Info - LibraryMonitor: Watching directory /var/lib/mediabrowser/data/playlists2015-04-14 08:12:23.6172 Info - LibraryMonitor: Watching directory /var/lib/mediabrowser/data/collections2015-04-14 08:12:23.6172 Info - LibraryMonitor: Watching directory /var/lib/mediabrowser/data/camerauploads2015-04-14 08:12:23.6418 Info - LibraryMonitor: Watching directory /var/lib/mediabrowser/root2015-04-14 08:12:23.6455 Info - LibraryMonitor: Watching directory /media/hdd/movies2015-04-14 08:12:23.6748 Info - LibraryMonitor: Watching directory /media/hdd/torrent/completed2015-04-14 08:12:23.7734 Error - HttpServer: Error in SharpWebSocket: An exception has occurred while receiving a message.2015-04-14 08:12:27.8720 Info - App: Opening channel stream from TVHclient, external channel Id: 4226318952015-04-14 08:12:28.1441 Info - App: Live stream info: {"Protocol":"Http","Id":"0","Path":"http://127.0.0.1:9981/stream/channelid/422631895?ticket=9080D7F95D745942C64916158FD193F8388D4F45","Type":"Default","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":true,"LiveStreamId":"41c95b6de5174f82acbc56fe82d0a2f8_0","MediaStreams":[{"IsInterlaced":true,"IsDefault":false,"IsForced":false,"Type":"Video","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false},{"IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false}],"PlayableStreamFileNames":[],"Formats":[],"RequiredHttpHeaders":{}}2015-04-14 08:12:28.2997 Info - App: /var/lib/mediabrowser/ffmpeg/20150124/ffmpeg -fflags +genpts -i "http://127.0.0.1:9981/stream/channelid/422631895?ticket=9080D7F95D745942C64916158FD193F8388D4F45" -sn -codec:v:0 libvpx -force_key_frames expr:gte(t,n_forced*5) -vf "yadif=0:-1:0,scale=min(iw\,720):trunc(ow/dar/2)*2" -pix_fmt yuv420p -speed 16 -quality good -profile:v 0 -slices 8 -crf 10 -qmin 0 -qmax 50 -maxrate:v 872001 -bufsize:v (872001*2) -b:v 872001 -vsync vfr -map_metadata -1 -threads 3 -codec:a:0 libvorbis -ab 128000 -af "aresample=async=1" -y "/var/lib/mediabrowser/transcoding-temp/3383cb9aa676281e441819ca2d83e4f5.webm" 2015-04-14 08:12:38.1897 Error - App: Error streaming media. The client has most likely disconnected or transcoding has failed. *** Error Report *** Version: 3.0.5572.0 Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -programdata /var/lib/mediabrowser Operating system: Unix 3.13.0.46 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/mediabrowser Mono: 3.10.0 (tarball Wed Nov 5 12:50:04 UTC 2014) Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe Write failure System.IO.IOException at System.Net.Sockets.NetworkStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.ResponseStream.InternalWrite (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.ResponseStream.Write (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in <filename unknown>:0 at MediaBrowser.Api.Playback.Progressive.ProgressiveFileCopier.CopyToInternal (System.IO.Stream source, System.IO.Stream destination, Int32 bufferSize) [0x00000] in <filename unknown>:0 at MediaBrowser.Api.Playback.Progressive.ProgressiveFileCopier.StreamFile (System.String path, System.IO.Stream outputStream) [0x00000] in <filename unknown>:0 at MediaBrowser.Api.Playback.Progressive.ProgressiveStreamWriter.WriteToInternal (System.IO.Stream responseStream) [0x00000] in <filename unknown>:0 InnerException: System.Net.Sockets.SocketException The socket has been shut down at System.Net.Sockets.Socket.Send (System.Byte[] buf, Int32 offset, Int32 size, SocketFlags flags) [0x00000] in <filename unknown>:0 at System.Net.Sockets.NetworkStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) [0x00000] in <filename unknown>:0 2015-04-14 08:12:38.2093 Error - HttpServer: Error in HttpListenerResponseWrapper: Write failure *** Error Report *** Version: 3.0.5572.0 Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -programdata /var/lib/mediabrowser Operating system: Unix 3.13.0.46 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/mediabrowser Mono: 3.10.0 (tarball Wed Nov 5 12:50:04 UTC 2014) Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe Write failure System.IO.IOException at System.Net.Sockets.NetworkStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.ResponseStream.InternalWrite (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.ResponseStream.Close () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.HttpServer.SocketSharp.Extensions.CloseOutputStream (SocketHttpListener.Net.HttpListenerResponse response, ILogger logger) [0x00000] in <filename unknown>:0 InnerException: System.Net.Sockets.SocketException The socket has been shut down at System.Net.Sockets.Socket.Send (System.Byte[] buf, Int32 offset, Int32 size, SocketFlags flags) [0x00000] in <filename unknown>:0 at System.Net.Sockets.NetworkStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) [0x00000] in <filename unknown>:0 2015-04-14 08:12:38.2102 Error - HttpAsyncTaskHandler: Error occured while Processing Request: Write failure *** Error Report *** Version: 3.0.5572.0 Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -programdata /var/lib/mediabrowser Operating system: Unix 3.13.0.46 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/mediabrowser Mono: 3.10.0 (tarball Wed Nov 5 12:50:04 UTC 2014) Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe Write failure System.IO.IOException at System.Net.Sockets.NetworkStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.ResponseStream.InternalWrite (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.ResponseStream.Write (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in <filename unknown>:0 at ServiceStack.Formats.HtmlFormat.SerializeToStream (IRequest request, System.Object response, IResponse httpRes) [0x00000] in <filename unknown>:0 at ServiceStack.HttpResponseExtensionsInternal.WriteErrorToResponse (IResponse httpRes, IRequest httpReq, System.String contentType, System.String operationName, System.String errorMessage, System.Exception ex, Int32 statusCode) [0x00000] in <filename unknown>:0 at ServiceStack.ServiceStackHost.OnUncaughtException (IRequest httpReq, IResponse httpRes, System.String operationName, System.Exception ex) [0x00000] in <filename unknown>:0 at ServiceStack.HostContext.RaiseUncaughtException (IRequest httpReq, IResponse httpRes, System.String operationName, System.Exception ex) [0x00000] in <filename unknown>:0 at ServiceStack.HttpResponseExtensionsInternal.WriteToResponse (IResponse response, System.Object result, ServiceStack.Web.ResponseSerializerDelegate defaultAction, IRequest request, System.Byte[] bodyPrefix, System.Byte[] bodySuffix) [0x00000] in <filename unknown>:0 at ServiceStack.HttpResponseExtensionsInternal.WriteToResponse (IResponse httpRes, IRequest httpReq, System.Object result, System.Byte[] bodyPrefix, System.Byte[] bodySuffix) [0x00000] in <filename unknown>:0 at ServiceStack.HttpResponseExtensionsInternal.WriteToResponse (IResponse httpRes, IRequest httpReq, System.Object result) [0x00000] in <filename unknown>:0 at ServiceStack.Host.RestHandler+<>c__DisplayClass5.<ProcessRequestAsync>b__0 (System.Object response) [0x00000] in <filename unknown>:0 at ServiceStack.Host.Handlers.ServiceStackHandlerBase.HandleResponse (System.Object response, System.Func`2 callback, System.Func`2 errorCallback) [0x00000] in <filename unknown>:0 InnerException: System.Net.Sockets.SocketException The socket has been shut down at System.Net.Sockets.Socket.Send (System.Byte[] buf, Int32 offset, Int32 size, SocketFlags flags) [0x00000] in <filename unknown>:0 at System.Net.Sockets.NetworkStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) [0x00000] in <filename unknown>:0 2015-04-14 08:12:39.4739 Info - App: Killing ffmpeg process for /var/lib/mediabrowser/transcoding-temp/3383cb9aa676281e441819ca2d83e4f5.webm2015-04-14 08:12:40.0357 Info - App: Deleting partial stream file(s) /var/lib/mediabrowser/transcoding-temp/3383cb9aa676281e441819ca2d83e4f5.webm2015-04-14 08:12:40.0371 Info - App: FFMpeg exited with code 02015-04-14 08:12:42.9615 Info - App: StartupTrigger fired for task: Log file cleanup2015-04-14 08:12:42.9615 Info - App: Queueing task DeleteLogFileTask2015-04-14 08:12:42.9615 Info - App: Executing Log file cleanup2015-04-14 08:12:42.9650 Info - App: Log file cleanup Completed after 0 minute(s) and 0 seconds2015-04-14 08:12:42.9652 Info - ServerManager: Sending web socket message ScheduledTaskEnded2015-04-14 08:13:03.7682 Info - App: Refresh Guide Completed after 0 minute(s) and 47 seconds2015-04-14 08:13:03.7682 Info - ServerManager: Sending web socket message ScheduledTaskEnded2015-04-14 08:13:03.8683 Error - HttpServer: Error in SharpWebSocket: An exception has occurred while receiving a message.2015-04-14 08:13:12.9603 Info - App: StartupTrigger fired for task: Cache file cleanup2015-04-14 08:13:12.9603 Info - App: Queueing task DeleteCacheFileTask2015-04-14 08:13:12.9603 Info - App: Executing Cache file cleanup2015-04-14 08:13:13.8769 Info - App: Cache file cleanup Completed after 0 minute(s) and 0 seconds2015-04-14 08:17:12.9639 Info - App: StartupTrigger fired for task: Convert media2015-04-14 08:17:12.9639 Info - App: Queueing task SyncConvertScheduledTask2015-04-14 08:17:12.9639 Info - App: Executing Convert media2015-04-14 08:17:12.9708 Info - App: Convert media Completed after 0 minute(s) and 0 seconds2015-04-14 08:17:12.9713 Info - ServerManager: Sending web socket message ScheduledTaskEnded2015-04-14 08:18:37.0422 Info - Dlna: DLNA Session created for PCH-A110 (00-06-DC-43-1D-7D) - NMT2015-04-14 08:18:38.0204 Info - App: HttpClientManager POST: http://www.mb3admin.com/admin/service/registration/ping2015-04-14 08:22:08.5012 Info - App: HttpClientManager POST: http://www.mb3admin.com/admin/service/registration/ping2015-04-14 08:22:08.5183 Info - Dlna: DLNA Session created for Squeezebox Mobil - Squeezebox 3
zozotv 0 Posted April 14, 2015 Posted April 14, 2015 (edited) I can not click on the play button. Emby reboot after re-working properly Edited April 14, 2015 by zozotv
ryantiger658 5 Posted April 14, 2015 Posted April 14, 2015 The tunername information has no function related. Tvheadend delivers the tuner name together with other information as one string. Breaking the parts is not easy as it looks like there are different versions of which information is chained together in the tvheadend code. My strings looks like STV0367 DVB-C DVB-T (adapter 0)/KBW: 370,000 kHz/zdf.kultur CXD2837 DVB-C DVB-T/T2 (adapter 3)/KBW: 370,000 kHz/zdf.kultur You version is HDHR1/599,028 kHz I tried to split back words at the '/' into 3 parts but your string is missing the tv-channel part. I think it is not possible to calculate the tuner name so I disabled the tuner info in the new version (available in the repo). Are you able to see the channels, EPG, recordings? Can you watch a live stream, a recorded stream? No, all that I can see is a blank page. There are no additional errors in the logs (I can upload the full logs if you would like). Is there something I have configured incorrectly in TVH? I have a channel number and name for every station I have available. I did setup a recording from the TVH server, and that poped up in the Recordings section of the live TV. But other than that, it is all blank. Thanks for your help, Ryan
Tolotos 61 Posted April 14, 2015 Author Posted April 14, 2015 The first and the second exception came from Emby during the try to load the images for the channels. Do you have setup channel icons in tvheadend? If the entered URL reachable from a web browser? It should looks like this: The third exception is raised from ffmpeg. My plugin gives the tvheadend URL of the stream to Emby. LOG: 2015-04-14 08:12:28.1441 Info - App: Live stream info: {"Protocol":"Http","Id":"0","Path":"http://127.0.0.1:998...ttpHeaders":{}} Do you use a firewall or something else on your system?
zozotv 0 Posted April 14, 2015 Posted April 14, 2015 (edited) I have picon for all channels. Working with Plex theadend plugin, and working with tvheadend own player (ip:9981/tv.html) and working with android TVHclient Edited April 14, 2015 by zozotv
