eeidman 0 Posted December 13, 2016 Posted December 13, 2016 (edited) Hi, Emby live tv was configured and working with TVHClient plugin on Ubuntu 16.04 box but recently starting refusing to play. Checking using same tvheadend user and password with another client suggest that it's fine. Not too sure what changed on the server and broke it. Need help to see where to look next. Looks like some sort of issue with ffmpeg. Input #0, matroska,webm, from 'http://192.168.1.4:9981/stream/channelid/856077443?ticket=540D5DF0092C4ABAD0A22B4C4D316F342B5FB899': Metadata: title : RTÉ One encoder : Tvheadend Matroska muxer Duration: N/A, start: 0.000000, bitrate: N/A Stream #0:0(eng): Video: h264 (Main), yuv420p(tv, bt709), 1440x1080 [SAR 4:3 DAR 16:9], 25 fps, 25 tbr, 1k tbn, 50 tbc (default) Stream #0:1(eng): Audio: mp2, 48000 Hz, stereo, s16p, 192 kb/s (default) Stream #0:2(nar): Audio: mp2, 48000 Hz, mono, s16p, 64 kb/s (default) Stream #0:3(eng): Subtitle: subrip (default) [subtitles @ 0x1038fe0] Unable to parse option value "9981/stream/channelid/856077443?ticket=540D5DF0092C4ABAD0A22B4C4D316F342B5FB899" as image size Last message repeated 1 times [subtitles @ 0x1038fe0] Error setting option original_size to value 9981/stream/channelid/856077443?ticket=540D5DF0092C4ABAD0A22B4C4D316F342B5FB899. [Parsed_subtitles_0 @ 0x1038f20] Error applying options to the filter. [AVFilterGraph @ 0xfaaf60] Error initializing filter 'subtitles' with args 'http\://192.168.1.4:9981/stream/channelid/856077443?ticket=540D5DF0092C4ABAD0A22B4C4D316F342B5FB899:si=0' Error opening filters! Log file : http://paste.ubuntu.com/23624460/ FFMPEG : http://paste.ubuntu.com/23624456/ TVHClient : 1.0.6140.39002 tvheadend nightly : 4.1-2355~g1dd2652 emby : 3.0.8500.0 htpc@htpc-kodi:/var/lib/emby-server/logs$ uname -a Linux htpc-kodi 4.4.13-040413-generic #201606072354 SMP Wed Jun 8 03:56:47 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux htpc@htpc-kodi:/var/lib/emby-server/logs$ tvheadend -v tvheadend: version 4.1-2355~g1dd2652 htpc@htpc-kodi:/var/lib/emby-server/logs$ ffmpeg -version ffmpeg version 2.8.8-0ubuntu0.16.04.1 Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.4.0 (Ubuntu 5.4.0-6ubuntu1~16.04.2) 20160609 configuration: --prefix=/usr --extra-version=0ubuntu0.16.04.1 --build-suffix=-ffmpeg --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --cc=cc --cxx=g++ --enable-gpl --enable-shared --disable-stripping --disable-decoder=libopenjpeg --disable-decoder=libschroedinger --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librtmp --enable-libschroedinger --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzvbi --enable-openal --enable-opengl --enable-x11grab --enable-libdc1394 --enable-libiec61883 --enable-libzmq --enable-frei0r --enable-libx264 --enable-libopencv libavutil 54. 31.100 / 54. 31.100 libavcodec 56. 60.100 / 56. 60.100 libavformat 56. 40.101 / 56. 40.101 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 40.101 / 5. 40.101 libavresample 2. 1. 0 / 2. 1. 0 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 2.101 / 1. 2.101 libpostproc 53. 3.100 / 53. 3.100 Also notice that FFMPEG version is set to "Use a custom version" under Transcoder tab. However if I set to "Use System installed version" and save. It reverts back when I restart emby-server. Any ideas? Edited December 13, 2016 by eeidman
Luke 42241 Posted December 13, 2016 Posted December 13, 2016 @@eeidman, it's due to the extra colon : in the tvheadend url. i believe i have this resolved for the next release of emby server. thanks.
eeidman 0 Posted December 13, 2016 Posted December 13, 2016 @eeidman, it's due to the extra colon : in the tvheadend url. i believe i have this resolved for the next release of emby server. thanks. Wow, that was quick. Thanks for the fast response. Is there any workaround while waiting for next release?
Luke 42241 Posted December 13, 2016 Posted December 13, 2016 You can disable subtitles for your emby user by clicking your user icon in the top right and configuring playback settings.
eeidman 0 Posted December 14, 2016 Posted December 14, 2016 You can disable subtitles for your emby user by clicking your user icon in the top right and configuring playback settings. That worked when accessing through a web browser. Not too sure if it was working through the Emby android app. Didn't have enough time to debug last night. But I'm back up and running which is the main thing. Thanks for your help with this.
echo4golf 0 Posted January 27, 2017 Posted January 27, 2017 (edited) It works Arthur! Hardware and Software: Emby Server 3.1.5 on a Dell PE2900 with Ubuntu 16.04.1 HDHR3-US w' latest firmware Schedules Direct TVHeadEnd 4.09-16 Weirdness: I had issues getting the guide to work. I had channels as soon as I got TVHeadEnd working, and set up the plugin, but no guide. The last thing that I tried before it started working was to install the tuner and guide info into Emby-Server in addition to the already-configured plugin. Everything started working at that point. I removed the plugin and restarted Emby-Server. Channels and guide in LiveTV still worked. I stopped TVHeadEnd, restarted Emby-Server and no schedules or channels in LiveTV. Restarted both (still no plugin) and voila! Channels and Schedules reappeared. I'm not clear what's going on but it's working. Can anyone enlighten me? I'd like to write this up as a how-to. Thanks! Jerry echo4golf Edited January 27, 2017 by echo4golf
gl3nn 0 Posted January 28, 2017 Posted January 28, 2017 Hey guys, If someone wouldn't mind could they give a quick write up on how to configure the tvheadend plugin? I have setup tvheadend which is confirmed working in combination with oscam. Now I'm having trouble connecting tvheadend to emby. Greetings gl3nn
Luke 42241 Posted January 28, 2017 Posted January 28, 2017 Hi @@gl3nn can please describe the difficulty you're having? Thanks !
echo4golf 0 Posted January 28, 2017 Posted January 28, 2017 @@gl3nn, Do you have TVHeadEnd up and running? Jerry Echo4Golf
gl3nn 0 Posted January 29, 2017 Posted January 29, 2017 (edited) @@Luke & @@echo4golf Yes I have setup TVheadend and confirmed working. After that I installed the tvhclient plugin and restarted the server. After that I configured the plugin with port 9981 and 9982 which are also the ports for the tvheadend server. But after that I cant get it to be working in conjuction with live tv. Greetings gl3nn Edit:with configured the plugin I mean I went into the app settings and put the settings there. Edit2: god ******. I run Emby in a docker on Unraid. When i restarted the docker from the interface it magically worked. Now my problem is that the streams won't play. Maybe if i give it some time it will start working but at the moment I see a tuner getting set to the channel but no image and only a loading image in Emby. Both on the Web and emby theater Edit3: ***** my father had pulled the smart card out of the reader too watch tv and didn't tell me.... that explains alot Edited January 30, 2017 by gl3nn
echo4golf 0 Posted January 29, 2017 Posted January 29, 2017 You might want to check that your channels (Configuration>Channels/EPG) in TVHeadEnd are set up with tags. The tags must be either SDTV, HDTV, or Radio in order to be picked up by the plugin.
chattojimnow 9 Posted February 3, 2017 Posted February 3, 2017 Ok i hope this hasnt been addressed but ive worked out on synology how to have tvheadend show the icon (picon) for the tv chanel but when i go into emby everything works exept for the icon.... am i missing something. Or is it just not supported yet?
jlp2097 0 Posted April 6, 2017 Posted April 6, 2017 (edited) Hi, my emby log is full (really full!) of entries from tvhclient with entries like this: 2017-04-06 00:39:04.2832 Info App: [TVHclient] GetEventsResponseHandler.handleResponse: start value of event larger query stop value - skipping! Query start UTC dateTime: 4/5/2017 9:39:01 PM Query end UTC dateTime: 4/12/2017 9:39:01 PM Event start UTC dateTime: 4/27/2017 9:10:00 AM HTSMessage: <dump> eventId : 454399 channelId : 2125087850 start : 1493284200 stop : 1493286900 title : Karussell des Lebens subtitle : Die Streuobstwiese description : Die Streuobstwiese episodeId : 454400 nextEventId : 454401 </dump> Is this something I need to worry about or a bug in tvhclient? Edited April 6, 2017 by jlp2097
Tolotos 61 Posted April 7, 2017 Author Posted April 7, 2017 In the case you added it is "normal". Emby asks the plugin to gic the EPG data for one week Query start UTC dateTime: 4/5/2017 9:39:01 PM Query end UTC dateTime: 4/12/2017 9:39:01 PM The tvheadend server delivers always all EPG data he have. Therefor the plugin filters the entries and log which entry will be not delivered to emby Event start UTC dateTime: 4/27/2017 9:10:00 AM As far as i know you can setup the period of EPG fetching in tvhedend server. If you don't need 4 week data set the prefetch count to 8 days.
fc7 123 Posted April 21, 2017 Posted April 21, 2017 @Tolotos: is the plugin compatible with TVH 4.2.1? I'm thinking about upgrading from 4.0.10 but I would prefer not to break plugin compat. Any thoughts?
fc7 123 Posted April 21, 2017 Posted April 21, 2017 (edited) Ok. I just went ahead and upgraded TVH from 4.0.10 to 4.2.1. I'm running Emby 3.2.13.0 (latest stable). So far I found no new issues. Everything seems to be working as before the TVH upgrade. DVB TV channel (with video) will playback just fine in Firefox but DVB Radio channel (audio only) will load the playback bottom bar (as when playing music) but it will not start playback and the time will remain 00:00. This is a known issue since Emby 3.2.5 and above. Update: just confirm that even EPG data is flowing fine from TVH to Emby. Edited April 22, 2017 by fc7
jteeuw 0 Posted April 28, 2017 Posted April 28, 2017 Hi , I have te following problem : The Cannel list is empty and Guide is empty , I can see the recorded programs but I try to play a program that i recorded i get the following 2017-04-28 09:32:50.501 htsp: 172.17.0.1 [ emby ]: Welcomed client software: TVHclient4Emby-3.2.13.0 (HTSPv20) 2017-04-28 09:32:50.504 htsp: 172.17.0.1 [ emby | TVHclient4Emby-3.2.13.0 ]: Identified as user 'emby' 2017-04-28 09:32:50.504 htsp: 172.17.0.1 [ emby | TVHclient4Emby-3.2.13.0 ]: Privileges updated 2017-04-28 09:33:55.125 http: 172.17.0.1: HTTP/1.1 GET /dvrfile/2063234672 -- 500 Emby version : Versie 3.2.13.0 TvH plugn : 1.0.6145.42056 Tvheadend : 4.1-2541~g41fa62d87
Tolotos 61 Posted April 28, 2017 Author Posted April 28, 2017 (edited) Error 500 is "Internal server error". Internal means the TVHeadend server have this error. Maybe this are access rights for the tvh (or the user tvheadend run with) user on the server. Please check the logged path: /dvrfile/20.... Edited April 28, 2017 by Tolotos
jteeuw 0 Posted April 28, 2017 Posted April 28, 2017 (edited) This is the log file , ( when i paste the url in a browser i get a 500 internal server error , kodi plays the recording fine ) 2017-04-28 11:18:07.4234 Info App: Opening recording stream from TVHclient LiveTvService, external recording Id: 2063234672 2017-04-28 11:18:07.4256 Info App: [TVHclient] Support for live TV subtitles and multiple audio tracks is enabled. 2017-04-28 11:18:07.4274 Info App: [TVHclient] Probe stream for Recording 2017-04-28 11:18:07.4274 Info App: [TVHclient] Probe URL: http://emby:password@192.168.1.200:9981/dvrfile/2063234672 2017-04-28 11:18:07.4291 Info MediaEncoder: /usr/bin/ffprobe -i "http://emby:password@192.168.1.200:9981/dvrfile/2063234672"-threads 0 -v info -print_format json -show_streams -show_format 2017-04-28 11:18:07.4717 Error MediaEncoder: Error in WaitForExit 2017-04-28 11:18:07.4717 Info MediaEncoder: Killing ffmpeg process 2017-04-28 11:18:07.4727 Error MediaEncoder: Error killing process *** Error Report *** Version: 3.2.13.0 Command line: /usr/lib/emby-server/MediaBrowser.Server.Mono.exe -programdata /config -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe Operating system: Unix 4.9.19.0 64-Bit OS: True 64-Bit Process: True Mono: 4.6.1 (Stable 4.6.1.3/abb06f1 Mon Oct 3 07:51:42 UTC 2016) Processor count: 4 Program data path: /config Application directory: /usr/lib/emby-server System.InvalidOperationException: No process is associated with this object. at System.Diagnostics.Process.EnsureState (System.Diagnostics.Process+State state) [0x0001e] in <6c7c03f48a9747c8a644da4f63a34480>:0 at System.Diagnostics.Process.EnsureState (System.Diagnostics.Process+State state) [0x00037] in <6c7c03f48a9747c8a644da4f63a34480>:0 at System.Diagnostics.Process.GetProcessHandle (System.Int32 access, System.Boolean throwIfExited) [0x00089] in <6c7c03f48a9747c8a644da4f63a34480>:0 at System.Diagnostics.Process.GetProcessHandle (System.Int32 access) [0x00000] in <6c7c03f48a9747c8a644da4f63a34480>:0 at System.Diagnostics.Process.Kill () [0x00002] in <6c7c03f48a9747c8a644da4f63a34480>:0 at (wrapper remoting-invoke-with-check) System.Diagnostics.Process:Kill () at Emby.Common.Implementations.Diagnostics.CommonProcess.Kill () [0x00000] in <03972079d9624fd9b6aafe44e9dc95af>:0 at MediaBrowser.MediaEncoding.Encoder.MediaEncoder.StopProcess (MediaBrowser.MediaEncoding.Encoder.MediaEncoder+ProcessWrapper process, System.Int32 waitTimeMs) [0x00051] in <1b7193002c1d4003ba671ee3969524b4>:0 System.InvalidOperationException at System.Diagnostics.Process.EnsureState (System.Diagnostics.Process+State state) [0x0001e] in <6c7c03f48a9747c8a644da4f63a34480>:0 at System.Diagnostics.Process.EnsureState (System.Diagnostics.Process+State state) [0x00037] in <6c7c03f48a9747c8a644da4f63a34480>:0 at System.Diagnostics.Process.GetProcessHandle (System.Int32 access, System.Boolean throwIfExited) [0x00089] in <6c7c03f48a9747c8a644da4f63a34480>:0 at System.Diagnostics.Process.GetProcessHandle (System.Int32 access) [0x00000] in <6c7c03f48a9747c8a644da4f63a34480>:0 at System.Diagnostics.Process.Kill () [0x00002] in <6c7c03f48a9747c8a644da4f63a34480>:0 at (wrapper remoting-invoke-with-check) System.Diagnostics.Process:Kill () at Emby.Common.Implementations.Diagnostics.CommonProcess.Kill () [0x00000] in <03972079d9624fd9b6aafe44e9dc95af>:0 at MediaBrowser.MediaEncoding.Encoder.MediaEncoder.StopProcess (MediaBrowser.MediaEncoding.Encoder.MediaEncoder+ProcessWrapper process, System.Int32 waitTimeMs) [0x00051] in <1b7193002c1d4003ba671ee3969524b4>:0 Edited April 28, 2017 by jteeuw
himisk71 4 Posted June 7, 2017 Posted June 7, 2017 When i add a channel as favorite, you didnt see this channel on the favorite site. Is this something not implemented yet or have i something wrong?
Tolotos 61 Posted June 11, 2017 Author Posted June 11, 2017 When i add a channel as favorite, you didnt see this channel on the favorite site. Is this something not implemented yet or have i something wrong? Favorites are handled in Emby not in the plugin. I have the same behavior. @@Luke are TV channels supported as Favorites?
Luke 42241 Posted June 11, 2017 Posted June 11, 2017 Correct. It's something we can look at for a future update, thanks.
