dcrdev 255 Posted September 2, 2016 Posted September 2, 2016 Due to an issue I've had to rebuild my server, which has meant re configuring Emby. I've got tvheadend up and running and Kodi is connecting to it fine and pulling through the channel icons. However this addon doesn't wan't to pull through any channel icons, in the log there are loads of entries like this: 2016-09-02 21:56:49.6025 Error App: [TVHclient] HTSConnectionHandler.GetChannelImage() caught exception: The type initializer for 'System.Drawing.GDIPlus' threw an exception. 2016-09-02 21:56:49.6054 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() channelId: 25871743 2016-09-02 21:56:49.6054 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() channelIcon: imagecache/231 2016-09-02 21:56:49.6054 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() WebRequest: http://127.0.0.1:9981/imagecache/231 2016-09-02 21:56:49.6091 Error App: [TVHclient] HTSConnectionHandler.GetChannelImage() caught exception: The type initializer for 'System.Drawing.GDIPlus' threw an exception. 2016-09-02 21:56:49.6103 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() channelId: 35899640 2016-09-02 21:56:49.6103 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() channelIcon: imagecache/284 2016-09-02 21:56:49.6103 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() WebRequest: http://127.0.0.1:9981/imagecache/284 2016-09-02 21:56:49.6154 Error App: [TVHclient] HTSConnectionHandler.GetChannelImage() caught exception: The type initializer for 'System.Drawing.GDIPlus' threw an exception. 2016-09-02 21:56:49.6164 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() channelId: 102213476 I have libgdiplus installed on my system - and libgdiplus.so is under /lib64. I turned on debug logging but it doesn't elaborate any more than the above. Can someone help?
dcrdev 255 Posted September 2, 2016 Posted September 2, 2016 Due to an issue I've had to rebuild my server, which has meant re configuring Emby. I've got tvheadend up and running and Kodi is connecting to it fine and pulling through the channel icons. However this addon doesn't wan't to pull through any channel icons, in the log there are loads of entries like this: 2016-09-02 21:56:49.6025 Error App: [TVHclient] HTSConnectionHandler.GetChannelImage() caught exception: The type initializer for 'System.Drawing.GDIPlus' threw an exception. 2016-09-02 21:56:49.6054 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() channelId: 25871743 2016-09-02 21:56:49.6054 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() channelIcon: imagecache/231 2016-09-02 21:56:49.6054 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() WebRequest: http://127.0.0.1:9981/imagecache/231 2016-09-02 21:56:49.6091 Error App: [TVHclient] HTSConnectionHandler.GetChannelImage() caught exception: The type initializer for 'System.Drawing.GDIPlus' threw an exception. 2016-09-02 21:56:49.6103 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() channelId: 35899640 2016-09-02 21:56:49.6103 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() channelIcon: imagecache/284 2016-09-02 21:56:49.6103 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() WebRequest: http://127.0.0.1:9981/imagecache/284 2016-09-02 21:56:49.6154 Error App: [TVHclient] HTSConnectionHandler.GetChannelImage() caught exception: The type initializer for 'System.Drawing.GDIPlus' threw an exception. 2016-09-02 21:56:49.6164 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() channelId: 102213476 I have libgdiplus installed on my system - and libgdiplus.so is under /lib64. I turned on debug logging but it doesn't elaborate any more than the above. Can someone help? Found the issue mono is looking for libgdiplus in the wrong place, so: ln -s /usr/lib/libgdiplus.so /usr/local/lib/libgdiplus.so Strange I didn't have the issue before I rebuilt the server, all working now though.
eikum 0 Posted September 3, 2016 Posted September 3, 2016 Hi! Love the plugin, but I got some issue.. I guess someone else have the same issue. I dont get any channels up or epg guide, but I only get recordings. Whats wrong?
Luke 42241 Posted September 3, 2016 Posted September 3, 2016 Can this be removed: https://github.com/MediaBrowser/Emby.Plugins/blob/edb60012771ffde29583fcf4f22ae0171ae55eb5/TVHeadEnd/HTSConnectionHandler.cs#L186 Gdi is not guaranteed to be available on all platforms. It's best to just leave the original image untouched.
Tolotos 61 Posted September 3, 2016 Author Posted September 3, 2016 @@Luke I added this as i don't know the image type. If it is possible to leave the txpe empty Ithe convert can be removed. Gesendet von iPhone mit Tapatalk
Luke 42241 Posted September 3, 2016 Posted September 3, 2016 Just hardcode it to jpg, it will probably be OK.
Tolotos 61 Posted September 4, 2016 Author Posted September 4, 2016 Ok, I'll change it when I'm at home in a few days. Gesendet von iPhone mit Tapatalk
hijinx 4 Posted September 4, 2016 Posted September 4, 2016 (edited) Hi Tolotos. I found what is the problem with channel icons for me. My icons are served from external server (dropbox... for now), but the emby tvh plugin seems to assume the icons will be served from the tvh server. Hence it treats the URL served from tvh as a URI and concatenates the tvh server IP. e.g: http://192.168.1.5:9981/https://dl.dropboxusercontent.com/u/4727830/channelicons/film4plus1.png more from the logs: 2016-09-04 05:18:04.5858 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() channelId: 1017449986 2016-09-04 05:18:04.5858 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() channelIcon: https://dl.dropboxusercontent.com/u/4727830/channelicons/film4plus1.png 2016-09-04 05:18:04.5858 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() WebRequest: http://192.168.1.5:9981/https://dl.dropboxusercontent.com/u/4727830/channelicons/film4plus1.png 2016-09-04 05:18:04.5890 Error App: [TVHclient] HTSConnectionHandler.GetChannelImage() caught exception: The remote server returned an error: (404) Not Found. 2016-09-04 05:18:04.5898 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() channelId: 1150963642 2016-09-04 05:18:04.5898 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() channelIcon: https://dl.dropboxusercontent.com/u/4727830/channelicons/film4.png 2016-09-04 05:18:04.5898 Info App: [TVHclient] HTSConnectionHandler.GetChannelImage() WebRequest: http://192.168.1.5:9981/https://dl.dropboxusercontent.com/u/4727830/channelicons/film4.png 2016-09-04 05:18:04.5922 Error App: [TVHclient] HTSConnectionHandler.GetChannelImage() caught exception: The remote server returned an error: (404) Not Found. Is there any way to tell the plugin to use the URL served from TVH as is? cheers! Edited September 4, 2016 by hijinx
Luke 42241 Posted September 4, 2016 Posted September 4, 2016 Ok, I'll change it when I'm at home in a few days. Gesendet von iPhone mit Tapatalk What you can do is try to determine the format from the extension in the image URL. If there is no extension then just hardcode it to jpg.
Tolotos 61 Posted September 10, 2016 Author Posted September 10, 2016 (edited) @@Luke @@hijinx @@dcrdev A new version (1.0.6097.29930) is in the catalog which handles the URL issue and the GDI usage. If the icon name contains a image type as suffix (e.g. .jpg or .png) the image stream from TVH is used direct. If no suffix is available GDI is used to create PNG as before. If the TVH feature of picons is used the image url looks like "imagecache/7826" which makes it not possible to check the image type. In my configuration PNG files are delivered - hard coding to format XY is not what I want to add. If there is no GDI available on the server please use image URL's with correct suffixes (no picons). Edited September 10, 2016 by Tolotos
yoshito 1 Posted September 14, 2016 Posted September 14, 2016 HiYesterday i update emby to version 3.0.7100.0. Since this time the plugin of TvHeadEnd doesn't work. the plugin is loading all time, but the tvheadend are running without problems.I don't know problem. Can you help me?Thanks
Luke 42241 Posted September 14, 2016 Posted September 14, 2016 Hi Yesterday i update emby to version 3.0.7100.0. Since this time the plugin of TvHeadEnd doesn't work. the plugin is loading all time, but the tvheadend are running without problems. I don't know problem. Can you help me? Thanks Hi there, welcome. Sorry to hear about this. Can you please describe the problem in a little more detail? Thanks.
yoshito 1 Posted September 14, 2016 Posted September 14, 2016 (edited) Hi The pluging lost configuracion. I reconfigured and works fine. Thanks and sorry Edited September 14, 2016 by yoshito
saed 6 Posted September 25, 2016 Posted September 25, 2016 Hello first congratulate you on the operation of the entire system. I have little time using it and I'm delighted. My little problem is with channel logos. Recently in my country "Spain" have been updated logos of many channels in my tvheadend I see the new logos but Emby still see the old. Might you help me? thank you very much
Tolotos 61 Posted September 26, 2016 Author Posted September 26, 2016 You must delete the icons from emby cache manually. I think the path on my windows system is like <userHome>\AppData\Roaming\cache\tv??? Stop emby, deleted the TV cache folder and restart emby. After some time the new icons are reloaded from tvheadend and displayed. -- Tolotos
dcrdev 255 Posted September 26, 2016 Posted September 26, 2016 You must delete the icons from emby cache manually. I think the path on my windows system is like <userHome>\AppData\Roaming\cache\tv??? Stop emby, deleted the TV cache folder and restart emby. After some time the new icons are reloaded from tvheadend and displayed. -- Tolotos He probably needs to clear the icon cache in Tvheadend too.
saed 6 Posted September 28, 2016 Posted September 28, 2016 (edited) You must delete the icons from emby cache manually. I think the path on my windows system is like <userHome>\AppData\Roaming\cache\tv??? Stop emby, deleted the TV cache folder and restart emby. After some time the new icons are reloaded from tvheadend and displayed. -- Tolotos Hello, installation is made under ubuntu, which would be the route to clear cache? thanks Edited September 28, 2016 by saed
Tolotos 61 Posted September 28, 2016 Author Posted September 28, 2016 Try a search in - /var/lib/emby/cache - /var/lib/emby-server/cache - /var/lib/media-browser/cache I think one of these path are correct. I have currently only my Windows server available.
saed 6 Posted September 29, 2016 Posted September 29, 2016 (edited) Try a search in - /var/lib/emby/cache - /var/lib/emby-server/cache - /var/lib/media-browser/cache I think one of these path are correct. I have currently only my Windows server available. thank you very much solved. the route: /var/lib/emby-server/cache Edited September 29, 2016 by saed
Rhy_Llew 0 Posted October 3, 2016 Posted October 3, 2016 Could it be possible to include an option for the TVHeadend webroot in the plugin? For example I have my tvheadend server displayed at <server_ip>:9981/tvheadend for reverse proxy reasons, however I cannot seem to set this path in the plugin. The plugin does not work until the webroot is removed (which I need active for the reverse proxy). Thanks
Tolotos 61 Posted October 4, 2016 Author Posted October 4, 2016 Could it be possible to include an option for the TVHeadend webroot in the plugin? For example I have my tvheadend server displayed at <server_ip>:9981/tvheadend for reverse proxy reasons, however I cannot seem to set this path in the plugin. The plugin does not work until the webroot is removed (which I need active for the reverse proxy). Thanks Please try the attached version and report. TVHeadEnd.zip
saed 6 Posted October 6, 2016 Posted October 6, 2016 Hi. since upgrade to the latest version of Emby, I can not see the channels through tvheadend. I get the following error "There was an error playing the video. Please Ensure there is an open tuner availalble. " any ideas? It seems to be some authorizations? Deputy log. http://192.168.22.140:8096/emby/videos/92f834310e8dc99d70f8620d11186ce5/stream.mkv?DeviceId=18dcf90e7284823e6b9fdca14f014c6ded3487ac&MediaSourceId=18&VideoCodec=h264&AudioCodec=mp3,aac&AudioStreamIndex=-1&VideoBitrate=326616510&AudioBitrate=192000&MaxAudioChannels=6&Level=51&Profile=high&PlaySessionId=a70c4155b8ae4b36a56bc9f0494ed6c9&api_key=deb26063afa3495e8cd70319fe02099a&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b_41c95b6de5174f82acbc56fe82d0a2f8_18&CopyTimestamps=true&EnableSubtitlesInManifest=false {"Protocol":"Http","Id":"18","Path":"http://192.168.22.140:9981//stream/channelid/1912827356?ticket=A4E21793B1109BA5D2F98973ECF1D2A684C672FE","Type":"Default","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":false,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":true,"LiveStreamId":"1a755974de5dc3461dc6ecae8ddec68b_41c95b6de5174f82acbc56fe82d0a2f8_18","MediaStreams":[{"NalLengthSize":"0","IsInterlaced":true,"BitRate":8000000,"IsDefault":false,"IsForced":false,"Type":"Video","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false},{"DisplayTitle":"","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":8000000,"RequiredHttpHeaders":{}} /usr/bin/ffmpeg -fflags +genpts -i "http://192.168.22.140:9981//stream/channelid/1912827356?ticket=A4E21793B1109BA5D2F98973ECF1D2A684C672FE"-sn -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -vf "yadif=0:-1:0" -pix_fmt yuv420p -preset superfast -crf 23 -b:v 8000000 -maxrate 8000000 -bufsize 16000000 -vsync -1 -profile:v high -level 41 -map_metadata -1 -threads 0 -codec:a:0 libmp3lame -ac 2 -ab 192000 -af "aresample=async=1" -y "/var/lib/emby-server/transcoding-temp/7e3ff0685bcab149ad56013a93b496fe.mkv" ffmpeg version N-79139-gde1a0d4 Copyright © 2000-2016 the FFmpeg developers built with gcc 4.8 (Ubuntu 4.8.4-2ubuntu1~14.04.1) configuration: --extra-libs=-ldl --prefix=/opt/ffmpeg --mandir=/usr/share/man --enable-avresample --disable-debug --enable-nonfree --enable-gpl --enable-version3 --enable-libopencore-amrnb --enable-libopencore-amrwb --disable-decoder=amrnb --disable-decoder=amrwb --enable-libpulse --enable-libfreetype --enable-gnutls --enable-libx264 --enable-libx265 --enable-libfdk-aac --enable-libvorbis --enable-libmp3lame --enable-libopus --enable-libvpx --enable-libspeex --enable-libass --enable-avisynth --enable-libsoxr --enable-libxvid --enable-libvidstab libavutil 55. 19.100 / 55. 19.100 libavcodec 57. 30.100 / 57. 30.100 libavformat 57. 29.101 / 57. 29.101 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 40.102 / 6. 40.102 libavresample 3. 0. 0 / 3. 0. 0 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [http @ 0x3e065a0] HTTP error 401 Unauthorized http://192.168.22.140:9981//stream/channelid/1912827356?ticket=A4E21793B1109BA5D2F98973ECF1D2A684C672FE:Server returned 401 Unauthorized (authorization failed) Greetings,
chvb 1 Posted October 6, 2016 Posted October 6, 2016 Hello, ive got a problem to playback any channel. I'm using this Version of TvHeadend: HTS Tvheadend 4.1-2249~g747ed01 When i try to start a channel there comes an error: no free Tuner If updated from TVH 4.09 to this newer Version. Thanks for any reply.
Tolotos 61 Posted October 6, 2016 Author Posted October 6, 2016 (edited) The plugin is only tested with the stable TVHeadend 4.0.9. @@chvb @@saed Can you please post the complete Emby log? Edited October 6, 2016 by Tolotos
