CamArrow 1 Posted April 19, 2015 Posted April 19, 2015 @@CamArrow You are not using the correct username. You need to use your user name found on your Emby server. Not the Emby Connect/forums username. Try it, and let me know! Edit: The error message will be adjusted eventually to reflect the real situation. They are the same forums = CamArrow server = CamArrow admin = CamArrow
Angelblue05 4132 Posted April 19, 2015 Posted April 19, 2015 They are the same forums = CamArrow server = CamArrow admin = CamArrow Weird because in the server response it says your user account is Jon.
CamArrow 1 Posted April 19, 2015 Posted April 19, 2015 (edited) it sychs with Jon but I log into everything else with CamArrow. I changed the user name after the initial creation. Edited April 19, 2015 by CamArrow
Angelblue05 4132 Posted April 19, 2015 Posted April 19, 2015 it sychs with Jon but I log into everything else with CamArrow. I changed the user name after your initial creation. Emby connect is not a supported feature at the moment. Maybe in the future, once we get things stabilized.
CamArrow 1 Posted April 19, 2015 Posted April 19, 2015 well, this is the first time I've been able to use Kodi outside of my server. so I am just glad to be able to use it for the first time. thanks for your help 1
