iam4uk 26 Posted April 12, 2015 Posted April 12, 2015 I've done the work to eliminate my [boxset] folder structuring, and applied both the Auto Box Set Plugin and much manual correction/addition to make Collections within the Metadata. Behavior is as expected. And it appears consistent device-to-device. Further, it matters not whether the metadata came from the plugin or manual addition. Thanks.
iam4uk 26 Posted April 12, 2015 Posted April 12, 2015 Where are the metadata files and images specific to each collection stored on the server, so that a user can manually adjust them via Windows Explorer?
Happy2Play 9814 Posted April 12, 2015 Posted April 12, 2015 Where are the metadata files and images specific to each collection stored on the server, so that a user can manually adjust them via Windows Explorer? C:\Users\username\AppData\Roaming\MediaBrowser-Server\data\collections
iam4uk 26 Posted April 12, 2015 Posted April 12, 2015 Thanks, Happy. Ironic that each subfolder in that data\collections folder is suffixed [boxset].
