rblu19 3 Posted April 4, 2015 Posted April 4, 2015 After upgrading the server to version 3.0.5772.0, a new problem emerged for me. This problem mainly manifested itself in MB Theater,but my attempts to use the web player ended with the same result. Every movie I had added prior to the update worked fine, but not all of the ones I added after worked. I usually convert the audio to flac with Makemkv, the same program I use to rip the movies from disc (sounds the same, takes up slightly less space and lags less on my system), but in this case some of the conversions wouldn't work (some would, though), and one movie (Throne of Blood) didn't work even before the conversion. All the other's worked if I was using the straight blu-ray rip, but not the converted-to-flac version. The converted version would lead to a black screen/freeze frame of part of the last video played, with the overlay on top. Since the files all worked perfectly in vlc, I have to presume it's an mb problem. Since the logs contained transcoding logs (which in my memory do not usually appear), I'll presume it has something to do with that. Two runs through to give material for logs (dash + # at end of log designates run): Run 1) Play Throne of Blood (the one that wouldn't even work before the conversion), Then play the pre-converted version of Salmon Fishing in the Yemen (that one plays perfectly, so it's sort of a control) Run 2) Play flac version of Salmon Fishing in the Yemen only (same result as Throne of Blood) server-63563765115-1.txt server-63563765705-2.txt theater-63563765368-1.txt theater-63563765866-2.txt transcode-2922b1ee-9d1c-4317-9f59-a76fb0ead3b1-2.txt transcode-f08a4d27-3fc5-4243-94f2-e7880ff37a04-1.txt
