careca 11 Posted April 4, 2015 Posted April 4, 2015 When using the Kodi addin, I see the following error on Kodi.log (DSPlayer build) smb://<user>:<password>@server/<path>/<filename.mkv> DSPlayer fails to play the video (with any renderer choice) 12:06:04 T:924 ERROR: CFGLoader::InsertSourceFilter Failed to load file in the splitter/source12:06:04 T:924 ERROR: CFGLoader::LoadFilterRules Failed to insert the source filter12:06:04 T:924 ERROR: CFGManager::RenderFileXbmc Failed to load filters rules12:06:04 T:924 ERROR: CDSPlayer::Process - Failed creating DS GraphBut when the path is passed like smb://server/<path>/<filename.mkv> it works just fine.I asked the DSPlayer developer to look at it, but perhaps there is something to consider from Emby side as well - would be an option to have the addin setup the different source locations and with that drop the need to pass the login information with every file? This is the workaround I have setup right now. no name/password in the Emby addon, all sources set (with proper name/password) in Kodi. PS: Reason for using the DSPlayer version of Kodi is the brand new integration with MadVR! see the topic here. http://forum.kodi.tv/showthread.php?tid=223175
spon 26 Posted April 21, 2015 Posted April 21, 2015 I am having exactly the same issue. When I switch to DVDPlayer in Emby, the problem goes away, but I can't get anything to play using DSPlayer. careca - could you provide a link to your post in the Emby forums? I'd like to follow the progress there as well. Thanks!
mguebert 10 Posted May 19, 2015 Posted May 19, 2015 I experienced a similar issue when calling an external player. The fix was to removed the account and password in the emby add in. If the user in Windows already has access to the movies locations on the server or PC it will now pass the file as \\server\folder\file
