fuzzthekingoftrees 10 Posted April 4, 2015 Posted April 4, 2015 My studio Ghibli is all ripped from blu-ray into mkv. Video is h.264, then there is usually two audio tracks 1st one is Japanese, second one is English. On the web client and in kodi I can choose the second audio track. I can also set my user preferences to always play english if available and that works. On the Samsung app I get the Japanese track 1 regardless of the preferences. When I try to change audio tracks using the tools button on the remote the sub menu for audio doesn't appear. Is audio switching supposed to be working in this version? "MediaStreams":[ {"Codec":"h264","Language":"eng","IsInterlaced":false,"BitRate":8230919,"BitDepth":8,"RefFrames":16,"IsDefault":true,"IsForced":false,"Height":1040,"Width":1920,"AverageFrameRate":23.97602,"RealFrameRate":23.97602,"Profile":"High","Type":"Video","AspectRatio":"1.85:1","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":51,"IsAnamorphic":false,"IsCabac":true}, {"Codec":"dca","Language":"jpn","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":768000,"Channels":2,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"DTS-HD MA","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}, {"Codec":"dca","Language":"eng","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":768000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Profile":"DTS-HD MA","Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}, {"Codec":"srt","Language":"eng","IsInterlaced":false,"IsDefault":true,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Level":0} ]
fuzzthekingoftrees 10 Posted April 6, 2015 Author Posted April 6, 2015 I've been looking at the code behind this. I'm not much of a programmer so it's taking me a little while to get my head around. There seems to be two issues. The first is around chosing the default audio track and I can fix that succesfully but I don't know how or if you want my diff. The second one is when GuiPlayer_Display.updateDisplayedItemsSub() calls GuiPlayer_Transcoding.start() GuiPLayer_Display.playingVideoIndex is undefined. I fixed this by default the video index to 0 if it's undefined, that fixes the audio menu. Then it tries to call GuiPlayer_Display.stopPlayback() rather than GuiPlayer.stopPlayback(). Then there is an issue starting the playback again with the chosen audio track the error is TypeError: 'undefined' is not an object (evaluating 'this.playingMediaSource.Name') I guess this is when calling GuiPlayer_Display.setDisplay() but I don't know enough about GuiPlayer.PlayerData.MediaSources[] to know why it is undefined at this point.
CBers 7554 Posted April 6, 2015 Posted April 6, 2015 Hopefully @@chessdragon136 can give you some pointers.
fuzzthekingoftrees 10 Posted April 6, 2015 Author Posted April 6, 2015 I can see where the problem is, there are some variables that aren't initalised in the current scope. I'll need some input from @@chessdragon136 to see where and how they should be set. 1
chessdragon136 677 Posted April 7, 2015 Posted April 7, 2015 Interesting - I'll take a look when Im not at work
chessdragon136 677 Posted April 7, 2015 Posted April 7, 2015 If possible, can you upload a sample video (short & small!) to my onedrive (instructions in the reporting issues thread) Thanks for your efforts!
fuzzthekingoftrees 10 Posted April 7, 2015 Author Posted April 7, 2015 I uploaded an mkv for you. When I was looking at the code for handling subtitles I noticed there didn't seem to be any logic for handling the default subtitle setting so when I got the English audio working I was still seeing the subtitles which shouldn't be the case if you have subtitle mode set to default.
chessdragon136 677 Posted April 7, 2015 Posted April 7, 2015 Ok I see what I've messed up - basically a while back to try tidy my code i split the GuiPlayer class into GuiPlayer & GuiPlayer_Display, with the display element to handle graphical bits and player to handle the playback elements - it looks like i failed to pass through the playingIndexes in the setDisplay @@fuzzthekingoftrees - Thank you! You have saved sime time - Can you post the default audio selection code, i'd like to see what logic you use. I assume you've seen mine in the versions file. The problem is, unless the audio is the first track i have to transcode it (stream copy actually) As for the subtitle on audio change, no i don't change that currently. Maybe i should. I'll push out a new build in the next 20 mins - i cannot test but im pretty sure im on the mark
fuzzthekingoftrees 10 Posted April 7, 2015 Author Posted April 7, 2015 I'm afraid that doesn't fix it the problem is that when you call GuiPlayer_Transcoding.start() in GuiPlayer_Display.js those indexes are all null so the tools sub options menu for audio doesn't get built. Here's the section of GuiPlayer_Versions.js from line 172, the changes are on 174, then I've just changed the != to == on 200,208 and 213 var AudioLanguagePreferenece = (UserData.Configuration.AudioLanguagePreference !== undefined) ? UserData.Configuration.AudioLanguagePreference : "none"; var PlayDefaultAudioTrack = (UserData.Configuration.PlayDefaultAudioTrack !== undefined) ? UserData.Configuration.PlayDefaultAudioTrack: false; var SubtitlePreference = (UserData.Configuration.SubtitleMode !== undefined) ? UserData.Configuration.SubtitleMode : "Default"; var SubtitleLanguage = (UserData.Configuration.SubtitleLanguagePreference !== undefined) ? UserData.Configuration.SubtitleLanguagePreference : "eng"; FileLog.write("Video : Audio Play Default Track Setting: " + PlayDefaultAudioTrack); FileLog.write("Video : Audio Language Preference Setting: " + AudioLanguagePreferenece); FileLog.write("Video : Subtitle Preference: " + SubtitlePreference); FileLog.write("Video : Subtitle Language: " + SubtitleLanguage); var MediaStreams = MediaSource.MediaStreams; //--------------------------------------------------------------------------- //Find 1st Audio Stream for (var index = 0;index < MediaStreams.length;index++) { var Stream = MediaStreams[index]; if (Stream.Type == "Audio") { indexOfFirstAudio = index; FileLog.write("Video : First Audio Index : " + indexOfFirstAudio); break; } } for (var index = 0;index < MediaStreams.length;index++) { var Stream = MediaStreams[index]; if (Stream.Type == "Video") { videoStreamIfNoDefault = (videoStreamIfNoDefault == 0) ? index : videoStreamIfNoDefault; if (videoIndex == -1 && Stream.IsDefault == true) { videoIndex = index; FileLog.write("Video : Default Video Index Found : " + videoIndex); } } if (Stream.Type == "Audio") { if (PlayDefaultAudioTrack == false) { if (audioIndex == -1 && Stream.Language == AudioLanguagePreferenece) { audioIndex = index; FileLog.write("Video : Audio Language Preference Found : " + audioIndex); } } else { if (audioIndex == -1 && Stream.IsDefault == true) { audioIndex = index; FileLog.write("Video : Default Audio Track Found : " + audioIndex); } } } }
chessdragon136 677 Posted April 7, 2015 Posted April 7, 2015 (edited) Yup my bad - my GuiPlayer_Display hasn't synced properly As for the default audio, i get the change on 174 but the others looks the same as it already is in my code... Edited April 7, 2015 by chessdragon136
fuzzthekingoftrees 10 Posted April 7, 2015 Author Posted April 7, 2015 OK, this is close. I now get the sub tools menu and I can choose the English track. Playback is stopped the log shows Playback : Stopping Video : Video File Analysis Results Video : Codec Compatibility: true : h264 Video : Container Compatibility: true : mkv Video : Resolution Compatibility: true : 1920x1040 Video : BitRate Compatibility: true : 8230919 : 8230919 Video : FrameRate Compatibility: true : 23.97602 Video : Level Compatibility: true : 51 Video : Profile Compatibility: true : High Video : Audio File Analysis Results Video : Codec Compatibility: true : dca Video : Container Compatibility: true : mkv Video : Channel Compatibility: true : 2 Video : Transcode Status : Stream Copy - Audio Not First Track Video : URL : http://192.168.69.124:8096/mediabrowser/Videos/1fa4cf133bb130cd82d98ae4c52ef719/Stream.ts?VideoStreamIndex=0&AudioStreamIndex=2&VideoCodec=copy&AudioCodec=copy&MediaSourceId=1fa4cf133bb130cd82d98ae4c52ef719&api_key=c0cebf9d7bb74a6f8416d76321d6c737&DeviceId=BDCAAKYFDB4FQ Playback : Player Initialised Common.API.Plugin.setOffScreenSaver() id: Emby TypeError: 'undefined' is not an object (evaluating 'this.playingMediaSource.Name') it looks like when GuiPlayer_Transcoding.start() is called GuiPlayer_Display.playingMediaSourceIndex has no value The other patch is working fine though, you can see the default video and audio tracks are being found Video : Audio Play Default Track Setting: true Video : Audio Language Preference Setting: eng Video : Subtitle Preference: Default Video : Subtitle Language: eng Video : First Audio Index : 1 Video : Default Video Index Found : 0 Video : Default Audio Track Found : 1
chessdragon136 677 Posted April 8, 2015 Posted April 8, 2015 ok when I get to a computer tonight I'll rework the code so it calls a function back in guiplayer as opposed to passing all these indexes through - that was the plan originally I think I just forgot and enables the tools menu before checking! Sorry
