Possible to hide separate view from view strip?
Aussiedroid
I have a separate collection of documentaries (mix of movie & tv xmls in separate folder on my drive). I have excluded these from appearing in the movies and tv views, but when I do this it adds it as another custom view (just a list of files not the fancy like movie/tv ones).
I was wondering if it is possible to hide those, so I can just access the media from the folder view instead?
Or is there a way I can create a 3rd view like a movies or tv just for my documentaries?
Many Thanks.
Aussiedroid
Maybe I should word this another way then...
Can I add something to the folder view without it appearing in any other view or strip?
Thank you.
