newfiend 22 Posted April 3, 2015 Posted April 3, 2015 Is anyone else having a problem with the Configuration Backup Plugin Failing? Mine keeps reporting failed after each backup attempt... Thanks, newfiend~
Solution CBers 7535 Posted April 3, 2015 Solution Posted April 3, 2015 Seems to be working OK here. http://emby.media/community/index.php?/topic/739-how-to-report-a-problem 1
newfiend 22 Posted April 3, 2015 Author Posted April 3, 2015 Ok well I'm officially an idiot.. I changed my folder name from Media Browser to Emby (where I store my backups) on my HTPC and forgot to change the backup directory path located in the Emby server Configuration Backup settings. So the path was no longer correct... *sigh* Sorry. Thanks for the confirmation that it works as it should CBers! Now If I can get my brain fixed we'll be all set..lol newfiend~ 2
