Emby for Kodi - will not start
I problem getting the new Emby for Kodi to work
i have tried it on two separate PC's both fresh install off kodi 14.2 only the emby repo and emby plugin installed
and i get the same error on both :-(
anyone have any clue to what i do wrong ??
14:24:33 T:10436   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                             - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
                                            Error Type: <type 'exceptions.ImportError'>
                                            Error Contents: No module named KodiMonitor
                                            Traceback (most recent call last):
                                              File "C:\Users\H�kon\AppData\Roaming\Kodi\addons\plugin.video.emby\service.py", line 13, in <module>
                                                import KodiMonitor
                                            ImportError: No module named KodiMonitor
                                            -->End of Python script error report<--
Edited by hnelson
xnappo
@@hnelson - did you ever get this resolved?
@@xnappo
Nope still no go. Just updated too the 0.15 version, still the same error on start up and when i try to start it manually inside kodi
Edited by hnelson
Angelblue05
Can you post the full log? Thanks
sure  kodi.log ver 0,15 kodi.log ver 0,17
Edited by hnelson
Angelblue05
Weird. It's on Windows? Can you go to the appdata > Roaming > Kodi > addon > plugin.video.emby > resources > libs > Verify if there's a Kodi monitor? Or can you try to delete the addon folder, and redownload with the repo again? Hopefully this will help somehow. Let us know.
yes it's on windows, r.txt this is what's in appdata > Roaming > Kodi > addon > plugin.video.emby > resources > libs >
Edited by hnelson
Angelblue05
Could it be the special character in the path?  :unsure:
  • Like 1
Ok i made an new user with non Nordic character and now it started as intended
so it seems not to like the Æ Ø Å characters in the nordic languages  :(
  • Like 1
Guest
