holdestmade 11 Posted April 1, 2015 Posted April 1, 2015 Just updated to the new EMBY addon and using standard Arctic Zephyr Skin (None-MB)Was wondering why if I press i for info on a movie, the dialog only appears on movies that have not been partly watched or started ?I've tried to switch to confluence but this still happens.Is there any way to override this as I have been briefly starting movies to try out the new addon and now none of the ones I started will show the info dialog.Maybe there's a way to change the movies to non resume ?Thanks in advance
im85288 1493 Posted April 1, 2015 Posted April 1, 2015 It does not help you but I am not experiencing this on Arctic Zephyr. It did sound like an interesting bug, but I could not reproduce it. I wonder if others are experiencing the same as you..
Dpickles 0 Posted April 2, 2015 Posted April 2, 2015 It does not help you but I am not experiencing this on Arctic Zephyr. It did sound like an interesting bug, but I could not reproduce it. I wonder if others are experiencing the same as you.. I'm having the exact same problem and also using your version of Arctic Zephyr. I actually did a complete fresh install to see if it would fix the problem and didn't have any luck. Thanks
riffy 32 Posted April 3, 2015 Posted April 3, 2015 With .10 the info button now works for me on Movies. It did not before.
holdestmade 11 Posted April 5, 2015 Author Posted April 5, 2015 (edited) I have 0.0.15 installed and is still not working on some movies Edited April 5, 2015 by holdestmade
xnappo 1611 Posted April 5, 2015 Posted April 5, 2015 Can you try to find a pattern to when it is not working please?
holdestmade 11 Posted April 6, 2015 Author Posted April 6, 2015 Sure, it's only on resumable movies. Strangely on another PC it works fine. Both got same installs and same versions and done a reinstall to check.
holdestmade 11 Posted April 7, 2015 Author Posted April 7, 2015 Have narrowed it down to 5 movies so moved them, deleted all the metadata in the folder and then moved them back and updated the library, still the same ! Is there any cache I should delete also ?
xnappo 1611 Posted April 7, 2015 Posted April 7, 2015 If they are *not* in progress movies, can you do me a favor and paste the 'plot' field from the web client?
