Luke 42234 Posted March 31, 2015 Posted March 31, 2015 When connecting to the web socket, please add two new query string parameters to the url ?api_key={authenticationtoken}&deviceId={deviceId} Once you do this, you can then remove the "Identification" message that you normally send afterwards. It will not be needed anymore. This change is backwards compatible so your current connectivity will still function as-is. Wiki: https://github.com/MediaBrowser/MediaBrowser/wiki/Web-Socket
