Smaky 131 Posted March 31, 2015 Posted March 31, 2015 I have found myself having to navigate to the plug-ins tab in the control pannel very often just to have the ´refresh box sets´ to fire. I think it would be better if this is set as a Scheduled Task (as ofther plug-ins have) to control this task. This will help have all the scheduled stuff (or on-demand ones if you don´t want a schedule for the refresh thing) in a single pane. Ritght now I have to go there and then back into the scheduled tasks to fire a library refresh to have the collections update. 2
ebr 16342 Posted March 31, 2015 Posted March 31, 2015 What is occurring that is causing you to need to fire the process manually? The plug-in responds to any additions or deletions of movies to your library already so that's why there is no scheduled task.
Smaky 131 Posted April 1, 2015 Author Posted April 1, 2015 Hmmm interesting, I continuously add movies to my library and found that it is not until I manually click on the plug-in button that the collections get updated. Even after library rescans the collections will not be updated unless I manually trigger it.
saj 14 Posted June 6, 2015 Posted June 6, 2015 I would like to see that feature also because the automatic updating of box sets does not happen for me either. I just had to run it manually, as usual, to have it update for two new movies I added.
Smaky 131 Posted June 11, 2015 Author Posted June 11, 2015 Indeed... this behavior continues to be present. Seems the boxsets are not being updated during normal library scans.
techywarrior 689 Posted June 11, 2015 Posted June 11, 2015 Just had the same issue. I added a movie, metadata manager shows the TMBD collection ID (and it matches the other movies in the collection) yet it wasn't added to the collection. On the other hand, a month ago I added some movies and they DID automatically get added to collections but in those cases they were completely new collections. Maybe that has something to do with it.
roberthleeii 62 Posted June 19, 2015 Posted June 19, 2015 I too am seeing this issue. Mine use to auto update when I added a movie but now I thing my self having to run the task to get it to update.
