ronvp 92 Posted March 30, 2015 Posted March 30, 2015 I reported this before, ever since using the new graphics engine, coverart is creating annoying little white tips on the corners of the folders that are rendered with Sapphire or diamond treatments. NOTE, it is only showing up on folders that have white corners. please see below..
Happy2Play 9814 Posted March 30, 2015 Posted March 30, 2015 I don't use this treatment but Verified in 4.0.8.3. Diamond Sapphire EMS Version 3.0.5557.40000
ebr 16340 Posted March 30, 2015 Posted March 30, 2015 @t.andre / luke - did something happen with IM or the server the past few days to make round corners stop working or change how it works? OR, does the function actually depend on the content being rounded not being white?
Luke 42252 Posted March 30, 2015 Posted March 30, 2015 i would send him a note but no, nothing changed.
ronvp 92 Posted March 30, 2015 Author Posted March 30, 2015 (edited) What versions of everything? All latest alpha versions.. it started when we swapped graphics engines.. so a few weeks back.. It will most likely be a bug in the masking logic..or we forget to first round the corners of the image before applying the mask Edited March 30, 2015 by ronvp
throgmorton 96 Posted June 29, 2016 Posted June 29, 2016 Did this ever get fixed? As I'm noticing the same issue in Emby WMC and Emby Theatre.
Happy2Play 9814 Posted June 29, 2016 Posted June 29, 2016 Very minor but still and issue with images with white backgrounds. Can post other examples if needed. Image size (1000X1426) Diamond Sapphire Dev server Web Client Diamond
throgmorton 96 Posted June 29, 2016 Posted June 29, 2016 yes it did. can you show an example? thanks.I can post a screen when I get back, at first I thought it was something in my code. Maybe I was showing two images on top of one another one modified one not. But it showed up in the default theme and even in theatre. Sent from my iPhone using Tapatalk
throgmorton 96 Posted June 29, 2016 Posted June 29, 2016 Here is a screen shot you can see the white cover sticking out at the corners and the darker covers sticking out in the grey area at the sides of the screen.
throgmorton 96 Posted June 29, 2016 Posted June 29, 2016 A little more noticeable on a blue background....
